Odd starting issue, 355 help needed | FerrariChat
Discussion in '348/355' started by SWIFTVISION, Jul 9, 2008.
  1. SWIFTVISION
    SWIFTVISION Karting
    Jul 22, 2007
    98
    Portland, OR
    Ok,
    99 355 spider.
    Detailed the car for 3 hours and then no lights on dash, won't start. Jump start works. Next day I get a new battery put in. 24hours later, middle of day, same thing, no lights, no start. Wait 5 minutes and starts right up. End of the same day, same thing, no dash lights, no start. Jump start starts it right up. Whats going on here????
    Are the same hot solinod problems and bullet connectors problems from the 348 the same on the 355? Is this a charging system failure? Seems really odd and random.
  2. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Sounds like a bad ground to me. :):)
  3. SWIFTVISION
    SWIFTVISION Karting
    Jul 22, 2007
    98
    Portland, OR
    How would I check for that? Should I have the battery terminals replaced?
  4. eyboro
    eyboro Formula Junior
    989
    Chicago
    Eitan
    Sounds like your alternator is gone.
  5. SWIFTVISION
    SWIFTVISION Karting
    Jul 22, 2007
    98
    Portland, OR
    #5 SWIFTVISION, Jul 9, 2008
    Then why would it work after waiting 5 minutes? And the rest of the day (about 3 more hours with stops).
  6. PAP 348
    Dec 10, 2005
    100,224
    Pap
    #6 PAP 348, Jul 9, 2008
    Yes, check them first and ensure they are clean and tight. :):)
    Could have an issue with battery power from the battery area. The jump terminals are in the rear. I would give those terminals a really good once over on the battery. If they are tight, give the battery leads a little shake and see if the car loses battery power then. You may have a broken wire in there somewhere. :):)
    Has your 355 got an isolator by any chance? An alarm maybe? :):)
    I forget where the ground strap is in the engine bay in the 355's. Hopefully a 355 expert will chime in and help me here. :):)
    I dont think the alt is shot. :):)
    Sounds like its losing battery power for some reason, while the car is sitting there. :):)
  7. eyboro
    989
    Chicago
    Eitan
    This is how the alternator behaves before it dies.
  8. SWIFTVISION
    SWIFTVISION Karting
    Jul 22, 2007
    98
    Portland, OR
    #8 SWIFTVISION, Jul 9, 2008
    Are these something that is rebuilt or replaced? The car has that weird alarm thing. The one you have to push and wait till you hear 2 beeps before it starts. There is a battery charger someone hooked up to the front but I don't have the charger/connector. The radio is hard wired for what ever reason. I did not leave it on.
    I drove the car 600 miles the first 4 days with no problems. Then Sunday it went dead at the end of a long day of driving.
    Monday new battery and lots of driving. Then Tuesday it went dead at the end of a long day of driving.
  9. PAP 348
    Dec 10, 2005
    100,224
    Pap
    :eek::eek:
    They can be rebuilt. A few threads in here showing how to do so. :):)
    Or you can just replace. ;);)
    But I would do the simple checks first. They are also free tests. :D:D
    You can also borrow an amp meter and multimeter to check alternator output. Or take your car to a good auto-elec to check the charging system for you. But I do not think that is your issue mate.
  10. PAP 348
    Dec 10, 2005
    100,224
    Pap
    VERY hard to diagnose over the internet, but we will give it a go.
    Is there anyway you can turn off that alarm? That may be your problem right there mate. ;);)
  11. SWIFTVISION
    SWIFTVISION Karting
    Jul 22, 2007
    98
    Portland, OR
    There are NO warning lights, no battery low lights, nothing...
  12. f355spider
    f355spider F1 World Champ
    18,053
    You might want to call Tonkin's service dept and ask for direction, but I would investigate whether you are getting power to the ignition switch, and if power is coming out of it as well. Could be a problem there.
  13. SWIFTVISION
    SWIFTVISION Karting
    Jul 22, 2007
    98
    Portland, OR
    Anything to do with the TSB on upgrading the grounding strap on the alternator? Does this apply to 99's?
  14. kingsdare
    kingsdare Karting
    Oct 24, 2006
    132
    California
    David King
    Do you have a battery kill switch? This is a common cause of these type problems.
  15. SWIFTVISION
    SWIFTVISION Karting
    Jul 22, 2007
    98
    Portland, OR
    I have no idea...only had car 6 days.
  16. SWIFTVISION
    SWIFTVISION Karting
    Jul 22, 2007
    98
    Portland, OR
    #16 SWIFTVISION, Jul 9, 2008
    Oh, the radio (hard wired) and overhead and door lights work durring this "outage". No dash lights or motor equipment powering up though. The alarm works too and unlocks/locks the doors.
  17. kingsdare
    kingsdare Karting
    Oct 24, 2006
    132
    California
    David King
    Oh boy... Time to start checking all the ground and terminal connections. Sounds like you have something loose somewhere.
    Get out the old voltmeter and test light and start having fun. I would start with the ground connections and then go to the plug at the ignition switch. Of course the alarm can't be ruled out either.
  18. SWIFTVISION
    SWIFTVISION Karting
    Jul 22, 2007
    98
    Portland, OR
    Service Italy of Vegas, who did the PPI, says the electrical system is fine. Blaims the people who put the battery in....or loose conection at the battery disconnect.
  19. PAP 348
    Dec 10, 2005
    100,224
    Pap
    So you have power there then? Radio/door lights and the alarm still works also. :eek::eek:
    Perhaps start checking fuses and relays mate. You maybe have a faulty relay there that sticks sometimes. :):)
  20. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Of course they would say that....:rolleyes::rolleyes:
  21. f355spider
    18,053
    Applies to ALL years of 355, but unlikely your problem. Just the same, I would check for the strap, and if it has not been upgraded, either buy it from the dealer, or simply make one out of 10ga wire, and some crimp connectors.
  22. f355spider
    18,053
    You understand you must disable the alarm before starting each time? The immobilizer activates after 2 minutes with the key out. After that, you must push the alarm fob, and hear the "beep beep" before the starter will crank.
