Odometer running unusal 89 328GTS | FerrariChat
Discussion in 'Technical Q&A' started by Black-328GTS, Sep 5, 2006.
  1. Black-328GTS
    Black-328GTS Rookie
    Aug 20, 2006
    26
    Augusta, Georgia
    Mehdi Sheibani
    Today I was driving when all sudden the speedometer pegged high and stopped but the odometer kept running unusually fast. The odometer kept running even when I stopped the car and sitting idle. This is pretty bizarre; the odometer kept running until I turned the engine off. As soon as I cranked the car the odometer will keep turnning fast. Before getting home all sudden the speedometer and the odmeter start working normally. Has anyone experienced this? Or can anyone explain how could this happen??
  2. stephenofkanza
    stephenofkanza Formula Junior
    Mar 5, 2005
    542
    Kansas
    Stephen LeRoy Sherma
    My 81 308's odometer crawls when the sar is stoped an not moving with the
    engine running. The lst time I drove it when goinig over a seam in the road (just enough to unsettle the car at speed but not a jolt, the speedometer dropped from 70 to 40 then back to 70, the tack did not falter.
    Differnt but in the same area.
    Maybe somebody has an idea that will help us both.
    stephen
  3. f355spider
    f355spider F1 World Champ
    18,054
    Start with replacing the speedometer sender, it is screwed into the top of the transaxle...has a wire pigtail sticking out of it. Unplug is from the pigtail, should at least stop the miles accumulating, until you get a new one. Daniel at Ricambi has them in stock.
    Dave
  4. Black-328GTS
    Black-328GTS Rookie
    Aug 20, 2006
    26
    Augusta, Georgia
    Mehdi Sheibani
    #4 Black-328GTS, Jun 13, 2007
  5. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    So did that fix the problem or have you not driven it to check yet?
    Jeff
  6. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,825
    Cerritos, CA.
    Is this sensor responsible for both speedo and odo?
  7. Hank the Crank
    Jun 14, 2007
    5
    Miami, FL.
    Eddie Sapin
    #7 Hank the Crank, Jun 14, 2007
    We've used this shop for over 15 years; they do good work, fair prices, fast "turn-a-round," too. Yeah they don't have a "website," but clocks, Speedo’s tachs is what their about. 10 years ago I sent them a tachometer out of a 1937 Bugatti, and they repaired it quickly as if it came out of a Buick! Very cool the way the shaft of the Bugatti extends into the cabin left of the "Steering Wheel," (right hand drive) and at the top is a Lucas Magneto, but inside the engine compartment is a belt made of leather attached to the tach with an "idler pulley," for tension (after you "crank start it up!).
    As for your car; if the odometer is functional there's a gear internally that's not! These guys do good work, and can (if you really care how fast you’re going) request it be "Federally Certified!" Show that to the next "Highway Patrolman you meet!" If you get a speeding ticket, and the officer fails to bring his certification (caught by shadowing you), or forgot his certification of the GUN, and his "accreditation up to date," on how to use it, you walk! But you must ask for these documents as the State doesn't have to help you get out of a ticket. Ignorance of the Law is no excuse... (I may get that as a tattoo some day). Hope this helps you as they have us!
    Later,
    Hank
    Speedometer & Clock Company. 2337 S Michigan Ave. Chicago, IL 60616 (312) 842-6378.
  8. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    The sensor operates both the speedometer and the odometer. The circuit can fail such that either one stops working properly.
    The symptom described above is one indicating significant electrical noise in the 12V circuit somewhere. This usually comes from the alternator going bad. In my original design for a replacment board for the speedometer my 12V input filtering was not adequate, giving those same symptoms, esp. when cranking the engine.
    I would start by checking connections such as the engine ground and the other beautifully hidden and disguised grounds throughout the car :)
    And thanks for reminding me how much I miss my 1969 1750GTV! Owned it for the fisrt 10 years of its life, what a blast to drive :)
    Gerrit
  9. Black-328GTS
    Black-328GTS Rookie
    Aug 20, 2006
    26
    Augusta, Georgia
    Mehdi Sheibani
    Yes it did fix the problrm both speedo and odometer. I have driven it for a while now.
  10. Black-328GTS
    Black-328GTS Rookie
    Aug 20, 2006
    26
    Augusta, Georgia
    Mehdi Sheibani
    Yes, it is for both.
  11. f355spider
    18,054
    Wow, you waited 9 months to correct the problem? Did you just drive it with the sendor disconnected?
  12. Black-328GTS
    Black-328GTS Rookie
    Aug 20, 2006
    26
    Augusta, Georgia
    Mehdi Sheibani
    Yes Dave, but the problem was intermittent at first. Also, the sensor was underneath of the car and I would never go under the car with floor jack. I disconnected and replaced it on the same day since I had to take it to a shop to do the work. The pigtail had so much gong on it that I could not disconnected with the floor jack.
  13. Black-328GTS
    Black-328GTS Rookie
    Aug 20, 2006
    26
    Augusta, Georgia
    Mehdi Sheibani
    This is puzzling?? The speedo problem is back!!! After driving the car for less than two months and about 320 miles the speedometer running problem is back. The speed sensor or the “impulse generator” was purchased from Ricambi and it was specific for this model. Any idea of what might be the problem??
  14. peterdavid911
    peterdavid911 Formula 3
    Apr 9, 2012
    1,340
    London, UK
    Peter
    I have a similar problem. The odometer is fine (and only works when the car is moving) but the speedo needle shows something like 20mph when I could be doing 50mph. Is this the impulse generator problem and does anyone know the part number please? Its a 1987 UK spec 3.2.
    Many thanks.
    Peter
  15. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    Yet another thread showing not to trust the odometer reading.......too easy to disconnect or drive not connected.....fixed but not fixed, old thread. Cool GTV, though, my other dream car......
