OEM 308 qv distributor cap and rotor | FerrariChat
Discussion in '308/328' started by GaryvH, Aug 8, 2020.
  1. GaryvH
    GaryvH Rookie
    Dec 1, 2003
    16
    Pittsburgh
  2. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,032
    Should have Magneti Marelli cast into the top on original. Since NLA, you get what you can, and if they work, all is good. Interesting about screw slot. Sounds like a small QA bug.
    Also - your wires say LUCAS on them? I thought CAVIS was what Ferrari used.
    How we love them so!
  3. Island Guy
    Island Guy Karting
    Feb 20, 2020
    134
    Island Guy
    Reproduction caps
    Lucas wires in OEM red sheathing, not factory by any stretch of the imagination
    2-valve style rotors, not correct for a QV
    And those extenders are ancient...
  4. GaryvH
    GaryvH Rookie
    Dec 1, 2003
    16
    Pittsburgh
    Thank you for the info. I will replace the rotors. What do you think about the caps? Should I replace them along with the extenders? Best places to get both?
    This forum is wonderful for us backyard mechanics.
  5. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    OMG Lucas wires from an old Jaguar??? Sorry distributor caps were way overpriced. Try Superformance UK and as for the extenders, time to eliminate them all and go with this method. Be sure to reuse the red sleeves and red boots. This wire setup is similar to the one used on the F40
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    $600 for a non OEM cap is a bit expensive but ... they do need to make a bit of profit on the parts. $400 would be very fair.
  7. GaryvH
    GaryvH Rookie
    Dec 1, 2003
    16
    Pittsburgh
    Thanks for the help. I like the idea of using kingsbourne wires. They seem to meet every criteria. And eliminating the extenders is very clever. I might try to use the old extenders unless you guys think they are past their prime. So my plan: buy the wire, use the old boots (they look ok), use the sleeves (ok too), keep the distributor caps and try to get the little brass screw out, and replace the rotors.
    Thoughts?
  8. GaryvH
    GaryvH Rookie
    Dec 1, 2003
    16
    Pittsburgh
    Or send them to Dave Helms and have him sort it out but I like the idea of doing it myself.
    That's one of the reason we buy these cars.
  9. yelcab
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    I see all screws with slots. Which one does not have the slot?
  10. GaryvH
    GaryvH Rookie
    Dec 1, 2003
    16
    Pittsburgh
    In the first picture it's the bottom right, in the second picture it's the top right. There is no slot to get a screw driver on it.
    I might order a couple more. I don't think they make the originals any more. Has anyone dealt with superperformance in the UK. They seem very reasonable but I'm concerned about shipping, delivery time, and duty. I know it's in several threads but any suggestion in the US?
    I have dealt with Rutland before but that was a while ago.
  11. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,671
    Argent/Brasil
    Guido
    The screws can be tightened so hard deliverd new, so removing them the slots can be damaged.They do this on purpose...not to loose the screw, but more important, you brake it and have to buy an other one !:D
  12. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    I just ordered from Superformance two weeks ago and my parts arrived in one week. I was surprised how fast. ELIMINATE the extenders, they are problematic
  13. GaryvH
    GaryvH Rookie
    Dec 1, 2003
    16
    Pittsburgh
    Ok, thank you jlc308. All the parts to do it came from Kingsboure?
  14. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    Yes however some of the part numbers may have changed because I did this about 10 years ago and still going strong. Kongsborne should have everything
  15. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    I bought caps from Superformance and they have been okay but a few of the wells were not deep enough. The pin still contacted the end of the wire but not enough to hold it securely. You can measure the depth of the wells with a caliper and it's easy to increase with a 3/8 inch drill so that the pins will secure the wires. If you do this yourself you can keep the pins from the old caps as spares
  16. GaryvH
    GaryvH Rookie
    Dec 1, 2003
    16
    Pittsburgh
    kcabpilot, Thank you. Did you get them recently. It seems they might have a problem with quality control. Is there another option for this caps in the us. I would imagine these days most of these come from the same source and superformance has very good prices. I was going to get the caps, rotors, and distributor seals from them.
    jil308, I will call kingboure today to check on the numbers.
    you guys are a wealth of information and I appreciate it.
  17. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    I got them about two years ago and yes there is a quality control issue with most aftermarket parts. I believe however that original caps are NLA so you have to deal with it. The depth of the lead wells was not such an insurmountable problem. The fit and tolerances between rotor and contacts seem to be okay as they have been working fine. I've got about five thousand miles on them.
  18. GaryvH
    GaryvH Rookie
    Dec 1, 2003
    16
    Pittsburgh
    I just ordered them from Allferrariparts in Cleveland, $207/each and they assured me they are OEM.
    Thank you
  19. RodC328gts
    RodC328gts Formula Junior
    Aug 17, 2021
    458
    Mexico
    Rod C
    will this work for a 1988 328GTS?
  20. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    Yes
    RodC328gts likes this.
  21. RodC328gts
    Aug 17, 2021
    458
    Mexico
    Rod C
    Thank you.
    I couldn’t find the part numbers you mentioned. Will need to check the images.
    As well it seems they only sell Beru ignition wire Bulk - huge
  22. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    328 extenders should not cause troubles. They are not resistive. I used 328 extenders on QV with no issues.
  23. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    Part numbers most likely changed, I did this 12 years ago and still running strong and smooth. Maybe call their 800 number and inquire
