OEM Enzo Key Blank for 360?? | Page 12 | FerrariChat
Discussion in '360/430' started by Joe Mac, Feb 25, 2007.
  1. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    That is a shame.
    It's plastic and I don't think you'll ever match that perfectly.
    I'd make them buy you a new key unless a replacement shell is available.
  2. Roger E
    Roger E Karting
    Apr 4, 2007
    60
    Can anyone tell me please where to get one - or something better than the ' stock ' 360 key ?
    Thanks !
  3. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Go through what some of us did to avoid the above-mentioned scratches.
    Call Wynn las Vegas, order a key, and go through the process outlined in this thread.
  4. racerf360
    racerf360 Karting
    Mar 18, 2007
    82
    Mitch
    I bought one from Jimmy540's website. Damn pricy and it works like a charm! Paid a crisp $500. Got it cut from my local locksmith for 3 dollars. Not bad!
  5. racerf360
    racerf360 Karting
    Mar 18, 2007
    82
    Mitch
    I ordered the key in 04/10 and the key arrived yesterday. I know Jimmy still sells these ENZO keys on ebay, here's the website I purchased from
    http://www.jimmy540i.com/enzokeygallery.html
    Needless to say, nice item and I'm happy with it plus Jimmy left me a note to post regarding to the key.
  6. garybryan
    garybryan Karting
    Nov 6, 2006
    173
    Denver
    wow, after reading all this i feel like should get a crack pipe & smoke my way to lala land. i was one of those suckers that bought a key from jimmi, had it cut at ace. it works well & i do agree it seems a little cheap but my ***** was the cost. when at wynn's, the key there seemed to be same but for $190.00 uncut. if jimmi says there real & there not, give him the boot. the key works for me. i'm sure if i see jimmi as seller on ebay in the future, i won't buy.
  7. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    The key from Wynn is a cut key. It has to be reworked.
    However, it's still far cheaper that from the famous eBay seller.
  8. rbf41000
    rbf41000 Formula Junior
    Nov 21, 2005
    698
    Delray Beach FL
    Russell
    I dropped my unpainted ferrari store key on the concrete ground the otherday and the unpaint chipped off.
    Russell
  9. arnaget
    arnaget Formula Junior
    Nov 4, 2003
    553
    New York
    Jason
    Mitch,
    I hope you received my message back to you a few weeks ago? -- I thought you were going to buy one from me (it would have been cheaper, for sure!).
    Best..
  10. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Yes but the Jimmy experience last so much longer!
  11. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Just got my $190 Wynn key...let the modifying begin!!!
  12. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Drum Roll Please!
    We have e-nough, e-mail, and now e-poxy!!!!
    Best of luck.
  13. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    #288 UConn Husky, Apr 13, 2007
    E-liminate the e-poxy for me...I wanted the option to remove it at some point just in case (for my next Ferrari!). So instead just copied the contour of the original key and re-inserted with some silicone sealer to help hold it. And for weight tossed in 2 nickels and a dime taped together. Voila!!!
  14. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I am impressed.
    Very nicely done!
  15. wantaferrari
    wantaferrari Rookie
    Dec 30, 2006
    47
    Does anybody know the correct part number for the ENZO key from Wynn's? I would like to follow the modifications but won't pay 600.00
    Scott
  16. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,842
    Jupiter, FL
    Paul Bianco
    this was the best suugestion yet.
  17. VTChris
    VTChris F1 World Champ
    Aug 21, 2005
    13,259
    #292 VTChris, Jun 30, 2007
    Ask and you shall receive :)
  18. Jimmy540i
    Jimmy540i Formula 3
    2,494
    Los Angeles / NYC
    www.Jimmy540i.com
    good luck :)
  19. Jimmy540i
    Jimmy540i Formula 3
    2,494
    Los Angeles / NYC
    www.Jimmy540i.com
    you beat me to it :)
  20. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    #295 vm3, Jul 26, 2007
  21. duskybird
    duskybird F1 World Champ
    12,708
    29 Electoral Votes
    Bill B.
    That looks great! Does the horse come off?
  22. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    +1 I'd love to know how you masked, or removed, the horse.
    Frank
  23. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    1. Pry off the glued-on horse with a precision screwdriver, the type with a rotatable head. It comes off easily with a little force without damage.
    2. Use a sharp hobby knife to carefully trim off any raised edges of the remaining glue in the recessed area for the horse. If this is not done, the recess will become smaller after painting.
    2. Sand the silver paint with 400 grit sandpaper and wipe it clean.
    3. Cover the key shaft with tape.
    4. Spray on 2 light coats of white primer. Gray primer will make the red paint come out too dark. Allow the paint to dry to the touch between coats. A blowdryer can be used to speed the drying.
    5. Spray on 6 or more light coats of red paint. Dry it between coats. The last coat should be thicker to achieve a smooth shiny surface, but not too thick to avoid sagging and running.
    6. Bake it in an oven for 30 minutes. The lowest temperature of my oven is 190. I let it warm up for a minute to about 150 and shut it off.
    7. Glue the horse back on with cement. Use just enough for good adhesion, but not too much to avoid making the cement squeeze out. Do not use instant glue, since glue vapor may cause clouding on the paint.
    The entire process only takes about an hour. It is a simple, fun, and satisfying little project!
    Please post your results :)
  24. AlgaeHater
    AlgaeHater Formula Junior
    Sep 22, 2004
    321
    Bellevue, WA
    Great DIY! Could you please list the type of paint and primer that you used? Pretty please??
  25. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    #300 vm3, Jul 27, 2007
    I used a general purpose spray primer from a hardware store, and a Tamiya "Italian Red" spray paint from a hobby store, although any "Bright Red" general purpose spray paint from a hardware store also works.
    Use a cement that works on metal, since the horse is metal.
    You can buy all the materials with one trip to a hardware store for less than $10.
    To avoid scratching and chipping the paint, I use a nylon string to attach the remote to the key and do not attach other keys to it. The knot is glued to prevent it from untying.
    Have fun!
