For Sale - OEM Scuderia Suspension for 360, Stradale, F430 | FerrariChat
For Sale OEM Scuderia Suspension for 360, Stradale, F430
Discussion in 'Ferrari Parts & Collectibles' started by a/d/s, Apr 24, 2019.
  1. a/d/s
    a/d/s Rookie
    Sep 20, 2013
    16
    U.S,
    For F430, Stradale or 360 Modena
    This kit is the factory original suspension from the 430 Scuderia, used for less than 800 miles.
    The kit contains the front and rear springs, the rear springs are very light (Titanium) for unsprung weight reduction.
    The front and rear sway bars are included as well, the bushings for the 2 sway bars are included.
    These parts cost in excess of $8,000.
    You can use the stock shocks in the 360, Stradale or F430 with this suspension.
    This suspension lowers the ride height, and provides a stiffer and more flat car on low and high speed turns.
    This suspension was developed by Ferrari as a track-capable but also street-capable suspension. This is not a full race setup, but the OEM Scuderia system.
    Installation takes less than 5 hours once the car is on the rack with the wheels removed, no need to disassemble hubs, just remove struts (3 bolts each),remove top hat, swap springs, attach hat, reinstall.
    Have the car corner weighed and re-aligned after installation.
    Price: $3,000
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    perified and Makuono like this.
  2. f355spider
    f355spider F1 World Champ
    18,044
    All four springs should be titanium. I just double checked on my 430 Scuderia, and they are titanium at all four corners.
  3. a/d/s
    a/d/s Rookie
    Sep 20, 2013
    16
    U.S,
    These came out of a 2009 430 Scuderia. Part# 256954. Some Scuderias shipped with Steel front springs and others with Titanium springs. No idea which ones are stiffer. The rear springs in all of them were Titanium. The ones in my ad are made of steel.
  4. f355spider
    18,044
    Did some searching, you are correct sir! I see this on the Algar parts look up for the 430 Scuderia:
    256954 (2 each) SPRING -Steel- -Alternative solution-
    I would suspect the springs are the same with the exception of weight.
  5. jg360
    jg360 Formula Junior
    Feb 8, 2018
    320
    New Jersey
    John Gurrieri
  6. a/d/s
    a/d/s Rookie
    Sep 20, 2013
    16
    U.S,
    Yes, it is still available. I haven't been too active on trying to sell this stuff. I need to list a bunch more of Ferrari parts collecting dust in my garage.
  7. ihavearedferrari
    ihavearedferrari F1 Rookie
    Nov 23, 2007
    3,316
    Adam
    So f430 and scud/16m springs are directly compatible with standard 360 suspension?
  8. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    Do you know if these springs will work on a 355?
  9. SFFerrari
    SFFerrari Karting
    Jul 21, 2013
    224
    San Francisco
    LanceD
    Intriguing ... i see its been a few years since these were posted. So am curious if the set is still available??
  10. f355spider
    18,044
    I do not
