Officer won't pass Scuderia for State Inspection | FerrariChat
Discussion in '360/430' started by murph550, Jan 13, 2011.
  1. murph550
    murph550 Rookie
    Dec 10, 2007
    25
    Baltimore
    I am in the process of trying to get a Maryland State Inspection done on a 2009 430 Scuderia, but this one state trooper refuses to pass the car without a documented "rotor discard weight". The only spec we have been able to obtain from dealers is the initial width of the rotor, not the weight at which they should be replaced. Note, these are the ceramic rotors. Does anybody have any info that may be of help?
  2. Challengehauler
    Challengehauler Formula 3
    Jul 28, 2008
    1,315
    NE Connecticut
    DB
    I have a 599 rotor in front of me. Printed on the "hat" is 6480 g which is the throw away weight I think.....that being said, I weighed the rotor (and it was severely damaged through track use) and it now shows 6350 grams.
    Tell the officer that the discard weight is laser etched into the hat. The wheel will most likely need to be removed to see it.
    I will weigh a new rotor in a moment to verify if the printed weight is different from the unused weight.
  3. murph550
    murph550 Rookie
    Dec 10, 2007
    25
    Baltimore
    Thank you so much. If possible would you mind providing the new and throwaway weights for the rear rotors as well?
    Alex
  4. Challengehauler
    Jul 28, 2008
    1,315
    NE Connecticut
    DB
    I don't have any Scud rotors here other than what is on a pre-owned. Let me check with FoSF and see if they have any.
  5. Challengehauler
    Jul 28, 2008
    1,315
    NE Connecticut
    DB
    All they have is a set of used rears. They show 4492 grams printed.
    May want to call your dealer and see if they have any new/used in stock and get them to tell you what the printed weight is.
    Sorry I can't be of more help. Sales would kill me if I took a scud off the floor. I went out to look at it, but cannot see the etching. (covered by the wheel)
    Dan
  6. kaamacat
    kaamacat Formula 3
    Jun 13, 2004
    1,623
    Cumming GA
    BobR
    I am curious. What is the use "rotor discard weight" used for?
  7. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Like the 'minimum thickness' found on a steel rotor, the discard weight is that which is deemed unuseable, as such shops will/should not reinstall to vehicles..
  8. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    For my 2009 Scuderia this is what I have:
    Front: New weight: 6,224g (13.7215 lbs). Thickness 35.5 mm
    Minimum weight: 6,124g (13.4011 lbs)
    Rear: New weight 4,520g (9.9649 lbs). Thickness 33.5mm
    Minimum weight: 4,465g (9.8436 lbs)
    CCB rotors wear by weight, and they also heat cycle (like race compound tires).
    Do you mind sharing the name of the Police officer? I might know him and I could email him.
    This information is printed on each rotor. The weights above include the hats, I put both front and rear rotors on a bathroom scale, and they read 13.5 and 10 lbs respectively.
    If the Maryland Police officer needs to verifiy the weight, they need to do so in a calibrated scale (the ones used by jewelers work), because we are looking at differences of 0.22 lbs, something negligible.
    Unfortunately, this is the only documented way to verify the conditions of CCB rotors (applies to all Ferraris with CCB since the Stradale up to today's F458 and GTO).
    These weight marks are in all the CCB rotors on production cars today, Audi, Porsche, Lamb, Ferrari, Aston, all these cars use Brembo CCB.
  9. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    What the F does the weight of a GD rotor have to do with passing inspection for tags on a one-year old car????:eek:
    All I do for my 355 is take it to DEQ and they hook the emissions test up to the car. If you pass you get your tags...
  10. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    20,435
    Northern CA
    Yin
    That sounds like a pretty thorough state inspection. :eek: Is he actually going to take the rotors off and weigh them? Will he be responsible for any damage if he mishandles them?
  11. mikebrinda
    mikebrinda Formula Junior
    627
    There's thorough behavior, and there's ridiculous behavior. This is ridiculous behavior. Absurd.
  12. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    thoroughly ridiculous behavior...
  13. teak360
    teak360 F1 World Champ
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
    Absurd requirement. Colorado use to have "safety inspections" that were required every year. Any licensed inspection station (a guy with a garage and a socket set) could be an "inspector". They finally got rid of the requirement for safety inspections and it affected the accident rate approximately 0 percent.
  14. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    I was thinking the same thing.
  15. Streetking
    Streetking Formula Junior
    Jan 20, 2005
    263
    Austin, TX.
    SW
    With some of the POS cars driving around everyday, you would think they would pass a 1 year old Scud..
  16. alcc
    alcc Karting
    Sep 2, 2010
    183
    Santa Barbara, CA.
    Beyond absurd. Something else at work here.
  17. Doctor7474
    Doctor7474 Formula Junior
    Jun 20, 2010
    367
    Hoover Al,former Atl
    Doctor
    Glad I will never live in the north east. Stupid laws that are nothing more than revenuing for the local govt's nothing more, nothing less.
    I lived in Atlanta from birth until 2 years ago (32 years) they have emissions tests no safety, I now live in Birmingham due to work. I will always keep an AL address, no vehicle laws (that are enforced) or inspections at all here, and close to no other laws here. Freedom is great.
  18. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    It's amazing to me that he even knows that these are CCBs and the way to measure wear is via weights. But beyond that, it's ridiculous to demand to weigh them to pass inspection, especially on such a new car. Do they remove the rotors? Are they qualified and will they agree not to damage them or reimburse you if they do?
    It seems unlikely they would even have a scale of sufficient sensitivity and accuracy. Based on the weights above, the difference of 4520-4465=55g 55g is about a shade less than 2 ounces. That is about the weight of a ping pong ball or 12 sheets of paper!
  19. donv
    donv Two Time F1 World Champ
    26,125
    Portland, Oregon
    Don
    That's because you live in Oregon! Better yet, in most places in Oregon, all you do is go online and type in your credit card number, and then check your mailbox.
  20. RobD
    RobD Formula 3
    Nov 10, 2003
    1,182
    +1
  21. kaamacat
    kaamacat Formula 3
    Jun 13, 2004
    1,623
    Cumming GA
    BobR
    Very cool information.......... never too late to learn something. (I had also seen where some disc's have a imbedded "dot" in them as a wear indicator......... is that true on all, and if so can that be used vs weight?) Or is possibly weight used as a determining factor in not only wear but safety....?
  22. dc-spyder
    dc-spyder Rookie
    Jul 16, 2009
    47
    Washington, DC
    Welcome to the State of Maryland. There are more absurd things in this state than I have fingers and toes to count them on....
    I'm also trying to find a place to do an inspection on a pretty new 458.
  23. scycle2020
    scycle2020 F1 Rookie
    Jan 26, 2004
    3,477
    potomac
    We call it the Peoples Republic of Maryland. The people in communist China have far great freedom than we do here in Maryland. And never mind the 9% plus state and local income tax we pay not to mention elimination of all tax deductions on incomes above $100,000 ! Sorry, I forgot to mention state 15% estate tax on top of any federal estate tax. Please forgive the rant, i just had to vent. Anyway, this is the most absurd inspection on an essentially new, very safe car!!!
  24. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    Definitely staying away from there!
  25. Living4life
    Living4life Formula Junior
    Jun 29, 2008
    263
    How do the scuderia rotors differ from the f430 challenge ones?
    I have measurements from some after being used on challenge rotors at: 36.3mm front thickness and 34.6 in the rear thickness
