'Official' F12M Rumours and Launch | Page 4 | FerrariChat
Discussion in 'F12/812' started by Traveller, Oct 4, 2016.
  1. Caeruleus11
    Caeruleus11 F1 World Champ
    11,474
    Funny because I don't like the Aston gauges, they rotate in different directions and the numbers are small. And I don't mind seeing the frame bracing on the Astons- its just a fact that you need to add more support to the frame when you have this large opening. Sure the Ferraris don't seem to need this, but it wouldn't bother me one bit if they did. I don't really care for strict digital reproductions of analogue gauges, though I don't mind it when they are done with some kind of new age flare. Again, just personal preference. Really all that matters is how it drives, sounds and looks. If those are all superlative, then you could have Aston gauges that spin backwards with LP640 fonts and I wouldn't care! :) (I'm confident Ferrari will get it right).
  2. Randyslovis
    Randyslovis Formula Junior
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    Having had an instrument cluster go wonky in my 458, I have mixed feelings about these TFT dashes. I can deal with the "new" technology if it looks right. But, when a failure occurs that would have cost me 18K had it not been a warranty repair, I am reluctant to endorse Ferrari using this technology. I would be much more comfortable if they used analog gauges that seem to fail much less. Perhaps they will contract with someone in the future who can build more reliable ones. My dealer has had 2 or 3 including mine. I am sure Honda/Toyota have had fewer failures.
    Best
  3. Caeruleus11
    11,474
    Even the analog gauges now are digital. I suspect they are also susceptible to failure and probably fairly expensive to replace a well. It sure would have been in my 599 when the tach failed- turns out the entire package- tach, speedo, TFT screen are all one unit. Fortunately we found someone who could repair it for a fraction of the cost of new- and with better parts.
  4. DavidJames1
    DavidJames1 Formula 3
    Mar 6, 2010
    1,779
    Bangkok, Thailand
    Aside from the Aston Martin, any more updates on expected spec/design features for the F12M?
  5. ml321
    ml321 Formula Junior
    Aug 26, 2008
    254
    London/Munich
    +1
    nervous about the display cluster - recently had to shut down battery as one of the screens just went white and did not come back on even after multiple restarts (as so often battery shut off luckily solved the issue)
    generally not sure how I feel about the new Ferrari models without a warranty - luckily not sth to worry about for another 8 years or so
  6. manya81
    manya81 Formula Junior
    Apr 8, 2008
    399
    Robert
  7. Camlet1
    Camlet1 Formula 3
    May 3, 2014
    2,085
    Thanks. Is it my imagination, are the rear light clusters the same/similar to the Lusso?
  8. crinoid
    crinoid F1 Veteran
    9,902
    LaCrinoid
    Wow. This IS intriguing !!!
  9. deltona
    deltona Formula 3
    Aug 7, 2009
    1,386
    Justin
    That's the first thing i thought when i saw the video.
  10. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    Something very different going on behind the rear quarter lights judging by the way there appears to be almost a void or intake there? The material is loose in front, then appears to be supported, and then loose behind. Also clearly a strong ducktail and it would appear the tdf exhaust boxes are carried over, at least for now. At the front, it appears like the flow to the aero bridges starts either side of the headlights?
    As we thought, very different and far more than a mid life.
  11. deltona
    deltona Formula 3
    Aug 7, 2009
    1,386
    Justin
    Although we knew it, it's still comforting to hear the familiar V12 NA sound :)
  12. Milanno
    Milanno Formula Junior
    Feb 23, 2012
    949
  13. Camlet1
    Camlet1 Formula 3
    May 3, 2014
    2,085
  14. Scraggy
    Scraggy Formula 3
    Apr 2, 2012
    2,068
    England
    Scraggy
    Yes I had three 599s including two HGTE and one F12.
  15. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,551
    ESP
    Bas
    +1 great work
    I've very excited about the return of quad rear lights....:cool:
  16. patekswiss
    patekswiss Formula 3
    Mar 31, 2014
    1,174
    New York City
    Lorenzo
    Hope it will be along the lines of the GT3 RS, because that system is just spectacularly good. Holy moly.
  17. Traveller
    Apr 10, 2009
    6,323
    Tim
    #92 Traveller, Oct 26, 2016
  18. TSOYBELIS
    TSOYBELIS F1 World Champ
    Nov 30, 2005
    11,735
    Athens, Greece
    SPYROS
  19. Caeruleus11
    11,474
    Very nice Scraggy!
    Also very interesting about the F12M discussion. I guess time will prove it all. Thanks to you all for the detective and rendering work!
  20. Caeruleus11
    11,474
    Often times the companies use the same supplier for these systems so I suppose there is a chance it could be the same or similar but with Ferrari's special magic (programming). Very excited to learn more. Its always fun to see a new Ferrari model and then have the discussion.
  21. otakki
    otakki Formula 3
    1,634
    Return of the twin taillights era. The current single taillight still looks great to me.
  22. Solid State
    Solid State F1 World Champ
    10,477
    Maximus Decimus Meridius
    First thought is a Superamerica-style upper rear treatment. Possibly no hatchback. Rear looks like a cross between tdf and 488. Front obviously more open like tdf. Possibly no aero brigde (hopefully) and definitely different hood treatment. All just slightly above conjecture at this point obviously.
  23. Milanno
    Feb 23, 2012
    949
    Guys, thank you for kind words regarding that render, but lets be honest, that was horrible quality render :D It was very fast response on Camlet1 interesting idea!
    Now I`ve made new adjustments so we can take proper look on twin taillights idea! Since this is first stage render where I lined up all elements, I will wait for future posts so I could get some inspiration for rear difusor and for side profile of car.
    F12M in red
    http://s14.postimg.org/3v0g2ak7l/Ferrari_F12_M_by_Milanno_01.jpg
    F12M in black
    http://s14.postimg.org/hpyqkremp/Ferrari_F12_M_by_Milanno_02.jpg
  24. jbdmd
    jbdmd Formula 3
    Sep 30, 2007
    1,147
    Phoenix
    Doc Jay
  25. Traveller
    Apr 10, 2009
    6,323
    Tim
    Great work but I think the changes are far more radical than your renders. Just look at the extent of the camo on this mule, especially the rear. I cannot remember seeing such a cloaked evolution.
