Oh Boy - Gummed up brake fluid clogging stuff everywhere... (360) | FerrariChat
Discussion in 'Technical Q&A' started by Wayne 962, Nov 26, 2021.
  1. Wayne 962
    Wayne 962 Formula Junior
    503
    2000 Ferrari 360 Modena.
    So, another issue that seems to be somewhat unique to Ferrari - the gummed up brake fluid problem. Here's another thread that discusses the problem:
    https://www.ferrarichat.com/forum/threads/360-brake-fluid.283758/
    Prior to reading the thread, I tried to pressure bleed the system. No brake fluid came out of the outer side of the front right caliper, so I removed the bleeder screw, and for sure, it was all completely clogged in there (inside the caliper). After poking it free with a drill bit, I then tried to pressure bleed the system, and that didn't work at all - now nothing came out of the entire right front caliper. I asked a gazillion people with dozens of years of experience in the industry, and none of them had heard of this Ferrari brake fluid gum-up BS. This is after replacing the transmission heat exchanger last year (another issue semi-unique to Ferrari). Still, the car is awesome and working on this stuff builds character, right?
    So, the plan is to remove all of the brake components and clean everything out, one-by-one. What a pain in the ass. This would be:
    - All four calipers
    - Master cylinder
    - ABS block
    - All the steel / hard lines
    So, the calipers are basically Brembo calipers that can be cleaned out and rebuilt fairly easily. Likewise the master cylinder can be taken apart and cleaned. The master cylinder appears to be similar to the Audi A4 one, so should not be a problem. But, the main problem is the ABS block. So, how does one clean that out effectively? After spending *hours* on the Internet looking for an answer, it doesn't seem like there is a good one. I could flush the block, and then manually operate each of the small valves with an electromagnet placed on each one. I have the hydraulic diagram so that I can figure out what the paths are and how to do it. But that seems like it would take a long time, and I'm not 100% sure I would be able to get all of the fluid out.
    Questions for the people who have experienced this issue before:
    - What is the best chemical to use to clean out this old gummed up fluid? First thought would be brake cleaner, but I'm not 100% sure. We don't want anything that will interact badly with any new brake fluid and also don't want anything that could potentially damage the seals.
    - With respect to the ABS block, the unit is separated into two parts - the motor/valve assembly, and the ECU electronic part that bolts onto it. On this thread here: https://www.ferrarichat.com/forum/threads/360-brake-issues-suggestions.371140/ user 360trev mentioned the following:
    "PS. You can swap the ABS ECU and re-use the ABS pump/actuators from ANY Bosch ABS 5.3 equipped car [hundreds of models] which makes this a much cheaper fix than buying Ferrari part numbers [the ecu will be fine]."
    This appears to be a likely truth based upon my inspection of the various hydraulic maps, electronics, and also just by simply comparing photos of the Ferrari 360 block to ones for an Audi A4 or similar car. They do appear to be exactly the same for the BOSCH 5.3 ABS system. I know that you can take the computer assembly off and swap it on other cars, so I'm assuming it would work in this case. It would be nice to hear from someone who has done that already though with success.
    Any thoughts or additional insight would be appreciated.
    -Wayne
  2. Turbopanzer
    Turbopanzer F1 World Champ
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    What type of brake fluid? If not silicone.....hot water.
  3. Fcar tech
    Fcar tech Karting
    Oct 22, 2021
    108
    Always nearby
    XXXX
    The crossover pipe at the bottom of the caliper is plugged. Remove it and clear it out. (Very common)
    There are 2 bleeder screws on the caliper. Start with this, then go from there.. it should bleed. New dot 4 to flush out. It should all come out through the bleeders.
  4. Wayne 962
    503
    Seems to be whatever fluid was in there originally? I'm not sure if anyone changed it before I got the car? No clue, but I'm assuming that, since this is a common problem with the OEM / original fluid?
    I think I mentioned in the original post, but I've already pressure bled it, and now the entire caliper is completely clogged (both nipples, doesn't move the piston any more). I.E. non-operational...
    Thx
    -Wayne
  5. raemin
    raemin Formula 3
    Jan 16, 2007
    2,339
    Lyon (FR)
    R. Emin
    #5 raemin, Nov 27, 2021
    That's the sort of neglect I would expect in one of my old Renault, but not on a Ferrari...
    Maybe you should try soaking the mechanical parts parts in an ultrasonic cleaner (some do have powerful heating elements). In order to play it safe I would just buy the cleaner itself and use break fluid as the liquid. BF may damage the cleaner but will avoid contamination. For the lines, as a last resort you could try a can of automatic transmission cooler line cleaner, but it would be much more safe to flush these with an air compressor.
    As far as dismantling the master cylinder, that's the sort of work I would not perform on a high performance car. Did it in on of my 43hp old rig though. Just my 2 cents.
    From personal experience, a dry system is a royal pain to refill (compared to a regular flush).
  6. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    919
    Georgia
    Mark Gronsbell
    This has been reported with the original Shell brake fluid not being changed on a regular basis. Therefore, suspect it is more a Shell brake fluid problem plus neglect than Ferrari problem. Brake fluid is supposed to be changed yearly as per the Ferrari maintenance schedule.
    windsock and Fcar tech like this.
  7. JL350
    JL350 Karting
    Jan 20, 2013
    215
    You should only use the recommended brake fluid specification in the system, do not put foreign material into the system as you may create other issues. Is you have filled up the callipers with gummy brake fluid it may be best to take them apart to clean them and maybe even put a rebuild kit through them.
    Also an issue with old rubber hoses in brake lines is that the can swell and close up, usually seen with the unusual problem of the brakes not releasing. But time may be up for the hoses anyway and they are due for replacement.
    Certainly best to find and clear the blockage, to my mind starting at the calliper end and cleaning back towards the master cylinder is the best way. The worst fluid will be closest to the calliper, but I would want good fluid through out the system and to know for sure that no blockages remained.
    Fcar tech likes this.
  8. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,948
    The Cold North
    Tom
    Clean out the cross over tube on all 4 calipers. This is just not a Ferrari issue. It is an issue across the board with all cars that use this style caliper. Zero need to disassemble anything else in the system once you get flow through the calipers from all 8 bleeder screws.
    Draw out as much old fluid as possible from the brake master and replace with new. Draw out the new fluid once again as much as possible. Return fresh fluid back into the master to the correct level.
    USE A PRESSURE BLEEDER. Run at least 2 liters through the system..one liter through the rear..and one liter through the front. That should be enough to completely flush the system of old fluid and replace with new. Going any further then that is shopping for problems that do not exist.
    The only other item I would recommend to replace while doing this would be the brake hoses on all 4 corners. Mainly due to age.
    JL350, 2NA and flash32 like this.
  9. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    I had the same issue with my 360. Performed all the steps tbakowsky was kind enough to post.
    In addition, I replaced the brake reservoir with a new part from Euro-Spares if I recall correctly. Some theorize the gummy buildup is the shell fluid reacting with the plastic. No idea if correct or not but mine had a white gummy substance at the bottom. Part is low cost and easy to install.
  10. Wayne 962
    503
    I went back to check the paperwork on the car - the fluid was last changed in 2014, about seven years ago. They used this Shell Donax UB stuff. It seems to be an unwise factory choice (most of these factory "choices" have to do with branding deals the OEMs cut with manufacturers). I've got some years of experience (I've written a few how-to books on Porsches and BMWs) - I asked around - only one of my colleagues has ever heard of this particular "gelling" problem (on a 993 that sat for many years). All of this gelling after only seven years? Heck, I have a car in my garage right now that hasn't been run in 38 years, and the brake fluid is still viscous and fine. DOT 3 versus DOT 4 of course, but still. A brief amount of research on the Interwebs seems to be reveal that some of the "high performance" fluid used in race vehicles has had some similar issues. Maybe someone mixed fluids at one time in the car's past history. Unknown for sure.
    Fcar tech - the issue is not so much cleaning out the one or two spots in the calipers where it's clogged - it's making sure that the entire system is clean and clear. Simply hitting the "trouble spots" will not assure that this crap is cleaned out of the rest of the system?
    I'm basically looking for suggestions from people who have done this before on what type of cleaner to use. Something needs to be gentle on the seals and components yet strong enough to dissolve this gel crap?
    -Wayne
  11. Wayne 962
    503
    This is indeed good advice, but since using the power bleeder, I'm not getting any flow to either one of the bleeder screws at the front right caliper. This leads me to believe the clog is now located upstream from the caliper. I indeed have new brake hoses that we will be installing. It will be interesting to check to see the condition of the hoses, and to see if the pressure bleeder is pushing fluid through to the hose connection. If not, then the entire system is clogged?
    -Wayne
  12. Wayne 962
    503
    Indeed, that is also good advice. I have already ordered a new reservoir from the dealer (some websites are saying that they are no longer available - this dealer had one on the shelf).
    Again, my concern is - if the brake calipers (and the reservoir) are all gummed up with stuff, then why wouldn't the ABS block be in a similar condition? It doesn't seem wise to simply clean out the calipers, master cylinder, reservoir, lines, etc, and ignore the condition of the ABS block?
    I did order a Foxwell tool yesterday that I will have in addition to the Xdiag tool in my toolchest. According to their website, this tool now supports individual wheel bleeding / actuation valves within the ABS system. Who knows if it actually will work indeed, but for $150, it's worth a try. Perhaps if I can bleed system repeatedly using the tool to actuate each valve, then I can have some confidence that the valve block is not clogged? An NOS block from an Audi A4 can be had for about $300 or so, and it would appear that the BOSCH 5.3 ABS blocks are all identical for the cars that use this system?
    -Wayne
  13. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Follow what tbakowsky recommended. I would not recommend disassembling the master or any part of the ABS. If you do, you may never have a driveable car again. Replacing the brake hoses would be the first step. It might be where the real problem is. Do not introduce any fluid into the system other than fresh DOT4 fluid.
    tomberlin and tbakowsky like this.
  14. Wayne 962
    503
    Hmm, on the surface that comment seems a bit extreme - not a newbie here - I have indeed written a few how-to books on Porsches and BMWs ("101 Projects for Your Porsche 911" and "How to Rebuild and Modify Porsche 911 Engines"), etc. ABS systems, computers, and the like are not unfamiliar. At the end of the day, this BOSCH ABS 5.3 system is pretty much identical to the one used on many other makes and one can always replace components in the car that have been contaminated.
    Having said that, it would be unfortunate to have to replace more than is needed in fixing this. The plan is to flush the system as much as possible and measure the output / pressures coming out of each port of the ABS system to see if they are equal / unclogged. Right now, there is zero pressure at the front right caliper. When I get back into town (Monday), I'll disconnect everything and start cleaning. I've got multiple power and vacuum bleeder tools, so between those and a gallon of DOT 4, this is probably a good start.
    Indeed, that is my gut as well. However, no one seems to know if pushing fluid through the system will be enough to clear out any blockages, particularly in the ABS valve block?
    Thanks,
    Wayne
  15. Fcar tech
    Fcar tech Karting
    Oct 22, 2021
    108
    Always nearby
    XXXX
    Are all 4 calipers fully blocked? You only mention right front.
    Open flex lines and see in fluid runs out.. it should. I highly doubt the entire system is fully blocked.
    I have done May of these cars with this issue, even seen fine metallic shavings come out of the calipers, and the cars are still fine after the 2 litres or so of new fluid though the system.
    These guys have given you some great advice.
  16. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,551
    San Carlos, CA
    Mitchell Le
    I am not giving any advice to Wayne Dempsey....
  17. Wayne 962
    503
    Thanks everyone for the feedback and advice. As I mentioned previously, I asked a whole bunch of my colleagues from the Porsche/BMW/Audi world, and none of them have heard of this (except for one that happened with a 993). This seems to be a somewhat unique issue related to these Ferrari cars. Someone previously smartly pointed out that they think it has something to do with the brake fluid reservoir interacting with the brake fluid. This is a pretty good guess in my opinion, as the brake components used in the rest of the system are pretty much standard off-the-shelf components used in plenty of other cars. The calipers are Brembo, I believe, the BOSCH ABS valve block is the same as used on other ABS 5.3 systems, the master cylinder is nearly identical to the Audi A4 one - the only thing that is different is the brake reservoir.
    To answer the question about the other calipers - I've been away on Thanksgiving break and I'm heading back today, so I haven't had a moment to check. Besides, as soon as the inside of the caliper got clogged, I immediately stopped what I was doing because it became apparent that more "gel" was getting pushed down to the caliper and I didn't want to further clog anything else. Again, my largest concern is making sure that the ABS valve block is not clogged and gummed up - I not sure there's any way to determine this, and I certainly don't want to push any gel into the ABS block.
    This thread from 2010 has some good thoughts: https://www.ferrarichat.com/forum/threads/360-brake-fluid.283758/#post-139580938
    In particular, this comment:
    So, based upon what I've read here (thanks for the input), and what I know about these systems, here is my plan of attack to fix this:
    1- I will empty and disconnect the reservoir from the master cylinder and then remove it. I have a replacement one on order. If there is some type of weird interaction between the brake fluid and the reservoir plastic, then perhaps the newer reservoir is manufactured out of newer materials. It's unlikely to be an NOS (New Old Stock) unit from the year 2000.
    2- I'll install the new reservoir and then fill it with fresh new brake fluid (regular off-the-shelf stuff). Then I will disconnect the master cylinder from the ABS Block and bleed the old fluid out of the master cylinder. I'll take photos of what comes out. This should hopefully clean the system out from reservoir to ABS block. Then I will reconnect it to the ABS block.
    3- I'll remove all of the rubber brake hoses from each corner of the car. I have replacements for these regardless - they appear to have a date stamp of April 2000, so I believe they are original to the car.
    4- I'll pull each caliper off of the car and take it over to the bench to inspect and clean it. The front right one was a complete disaster, and none of them are bleeding from the outer bleed nipple, so I'm assuming they are all gummed up inside. These are somewhat standard Brembo calipers (see here: https://www.ferrarichat.com/forum/threads/where-can-you-purchase-caliper-rebuild-kits-for-a-360.434047/) so I'll probably opt to replace the seals while I'm poking around and making sure they are clean.
    5- I'll blow out (compressed air) and clean out all of the metal lines just to make sure there is no gel in there clogging things up.
    6- Reassemble and bleed the whole system again.
    7- Bleed out the ABS valve block. The Foxwell tool supposedly has support for bleeding each individual caliper, but I haven't tried it yet for that purpose. With the gel contaminating the system, I want to make sure any old fluid or any old gel clumps are out of the ABS circuits. The only way to do this is to flush the circuits that are activated by the valves in the system. Even then, I'm not sure how one would know if they are clear or not. Simply flushing fluid through the system without activating the valves will replace the fluid in the main part of the system, but not the ABS valve block passages.
    Thanks again for all the suggestions. Again, I find it very odd that nearly no one from the Porsche-side of the world has ever heard of anything like this. Another Ferrari peculiarity!
    -Wayne
  18. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    It sounds more like someone mixed DOT 3/4 with DOT 5, rather than an inherent problem with the brake system components.
    You can't mix those fluids.
  19. raemin
    raemin Formula 3
    Jan 16, 2007
    2,339
    Lyon (FR)
    R. Emin
    You're probably right, but it could also be any petroleum based product mistakenly added to the brake system: mineral break fluid does not play well the these. As an experiment : just put a drop of oil based paint in BF and you will see how it turns into "Italian salad dressing" in no time. DOT5, Oil, power steering fluid, transmission fluid, etc. would not react as fast as paint but would still make a mess.
    For what it's worth a user reported jelly when mixing Motul RBF600 with Castrol SRF (https://www.ft86club.com/forums/showthread.php?t=108400). Maybe that some of these racing fluids do not mix well when old?
  20. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    Wayne Dempsey, The books you have written are absolutely invaluable to the Porsche community. A credit to you Sir. I'm certain you will sort your fluid blockage issues. Some brands of fluid crystallise with age. Many thanks for your air cooled experience. Reminds me of David Visard. Men who knew it all.
    GTO Joe likes this.
  21. Wayne 962
    503
    Wow, thanks for all the kinds words, but I hardly know it all (unless you're my wife or kids who accuse me of that all the time). Seriously, the books and stuff I've written over the years are compilations of all of the knowledge that I've learned from other really, really smart and experienced people. People who may have not been the best writers or photographers, or may have just been grumpy and crappy communicators. One of my talents, if you can call it that, is culling the info from that community and figuring out how to put it down into words and pictures so that non-engineers and non-mechanics can easily punch out projects. Exhibit A is me asking for assistance here - I have no problems asking questions on stuff I've never encountered before!
    Thanks,
    Wayne
  22. asanyfuleno
    asanyfuleno Rookie
    Nov 12, 2021
    32
    Brackley, UK
    Mike Edwards
    Another vote here for an ultrasonic cleaning bath for the ABS unit.
  23. f355spider
    f355spider F1 World Champ
    18,044
    You must be new to Ferrari....yes the reservoir is very likely NOS...if they ever run out of them, that may be it, and they never make them again...
    2NA likes this.
  24. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    I have had great success cleaning the gel from the reservoirs. So don't throw it out, it may be very valuable one day when they are no longer available.
    I have found that the gel fluid is an issue with whatever fluid Ferrari was using from the factory. This has been a problem from very early on. I see it less and less as the fluid has been changed to something else over the years. I still see this issue on cars that have had very little maintenance over the years.
    Wayne appears to be on track for a complete resolution of his issues. Cheers.
  25. Wayne 962
    503
    On the contrary, not new to Ferrari and not new to the parts business either. Nowadays, automotive manufacturers are making small-batch quantities of parts like these when needed. Based upon my inspection of the part and the box that it came in, this one looks fairly new in construction. I'm not sure exactly *when* Ferrari transitioned to the grey box for parts supplies, but I believe that is the current incarnation of "the box" (see attached image). Frankly, I prefer the bright yellow.
    The date stamp on the one that came out of the car says "99", which fits the fact that the car is a 2000 model year. This one says "10", so it looks like it's at least manufactured 11 years later. Looks like this only fits the 360 too, so they likely had a batch made about 5-6 years after the car was out of production? Possibly due to so many people replacing them! The reservoir is "plastic welded" shut and is impossible to open up to clean out. For what it's worth, the cap has a date stamp of "03".
    -Wayne
