oil...agian! | FerrariChat
oil...agian!
Discussion in '360/430' started by bmw550i, Aug 16, 2010.
  1. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    ok this has been beat bloody to death on here I know but im over due for an oil change in my 430 ..... what are you guys using /or recomend instead of shell .....?
  2. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    Curious as well. Shell is 25.70/qt at my dealer. Just had second annual done.
  3. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    I'm going to go with Valvoline I think. .fully synthetic in my 430
  4. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    most european formulas from any maker are good enough
  5. JoshECS
    JoshECS Formula Junior
    433
    Ashburn,VA
    Josh Hill
    Please don't ever use "good enough" and engine oils in the same remark. Many of us strongly recommend using Redline brand oils. They're great products and reasonably priced at approx. $11 qt.
    There are countless differences in oils, even at the same advertised viscosity different brands fall within the guidelins at different points. This means that 4 different 5w40 oils can have 4 different levels of actual viscosity.
  6. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
    no one has said anything about the quality of amsoil or agip
  7. EnzoXYZ
    EnzoXYZ Karting
    Jun 1, 2010
    76
    Chicago
    Who used other "cheaper" synthetics and have engine problems or blown up? NONE. You can drive 10k on the same synthetic and not have problems- proven endlessly.
  8. av2
    av2 Formula Junior
    May 22, 2008
    478
    S. California
    #8 av2, Aug 18, 2010
    Motor oils are designed to be changed every year or at certain amount of miles. As long as you keep up with your service, most name brand oils (Mobil, Pennzoil, Valvaline, Amsoil, Redline etc) with the right weight will be fine.
    Viscosity difference between brands is minor and I am sure most branded oils are within specs. What people should be concerned about is changing dirty oil out and use good practice when checking oil level. For example, I've seem cars with dirt around the dip stick cap area and getting particles into the system.
  9. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    ok so what is said about the other important fluids like f1 gearbox ...is there a better alternative rather than shell brands ??
