? Oil and Coolant Change 348 | FerrariChat
Discussion in 'Technical Q&A' started by mvespo348, Apr 3, 2004.
  1. mvespo348
    mvespo348 Karting
    Jan 5, 2004
    77
    North New Jersey
    Michael
    I'm going to change my oil and flush my coolant for the first time! I bought my 348 in Jan, 04. Here are my questions.
    1. If the previous owner used a synthetic type oil and I replace it with a regular oil, could I run into problems in the motor/seals or vice versa?
    2. What oil should I use and how much?
    3. Which is the best way to drain the oil and replace it?
    4. How do I flush out all the old coolant?
    5. Which type of coolant should I use and how much of it will I need?
    Thanks in advance for the help.
    Michael
  2. Ski Guy 348
    Ski Guy 348 Formula Junior
    Mar 29, 2004
    261
    Greenville, SC
    Jay M.
    Michael.... I own a 348 Spider and always do my own oil changes. If you can change the oil in a Honda, you can do the Ferrari!! I did not see what year 348 you have, however, I assume the fluid levels would be the same as my 94. It will hold 2.9 U.S. gallons of oil. I ALWAYS use Mobile 1 full synthetic. The original owner used "standard" oil. I had no problems with seals in my change over. This has been a debate issue in the past, however, it worked great for me. As for cooling system flush, I have this done by the F-Dealer when its in for service. I assume this would not be a major ordeal. It holds 5.28 U.S. gallons if you tackle it yourself. I would highly suggest you get your oil filter from a Ferrari Dealer or parts house. I have seen people that "match Up" filters from NAPA Exc. It may work, but I would not trust one of these on my car!! GOOD LUCK...Jay
  3. Ski Guy 348
    Mar 29, 2004
    261
    Greenville, SC
    Jay M.
    Oh Yeah......Be sure to drain the tank and sump!!! The plug is on the side of the sump...
  4. RAYMAN
    RAYMAN Formula Junior BANNED
    Mar 10, 2004
    315
    Oklahoma
    Raymond Santilli
    How bout flushing the brake lines too. The manual says once a year. Or at least suck out the old fluid with a large syringe and refill.
  5. davey_jones
    davey_jones Formula Junior
    Sep 28, 2002
    781
    wherever it's sunny
    Dave
    I heard doing a coolant flush may create more problems than it's worth.
    Doesn't that green "corrosion" or buildup also help to create a "seal" in the water pump?
    If you loosen all the stuff up, couldn't you inadvertantly create a leak?
    dave
    indy
  6. mvespo348
    mvespo348 Karting
    Jan 5, 2004
    77
    North New Jersey
    Michael
    I have a good idea now about the oil somewhat! Im still puzzled about the coolant. Does anyone have a service manual on CD rom for the 348?
    Michael
  7. davey_jones
    Sep 28, 2002
    781
    wherever it's sunny
    Dave
    Send NOELRP a message.
    He sent me a hardcopy of the manual when I sold him my tubi exhaust
  8. mvespo348
    mvespo348 Karting
    Jan 5, 2004
    77
    North New Jersey
    Michael
    Thanks Dave I will email him.
    Michael
