Oil and water temperature gauges have stopped working | FerrariChat
Discussion in '308/328' started by alistairw, Jan 2, 2025.
  1. alistairw
    alistairw Rookie
    Jun 14, 2023
    19
    La Serena, Chile
    Alistair Walker
    328 US version. So that I don't go down a wrong path again, the only thing I have done recently in the engine bay is to remove the water header tank so I could take off the additional air valve to check it (was OK). There are some wires in the vicinity but I am not seeing anything wrong that is obvious. Does anyone think I could have disturbed the feeds to the gauges? Otherwise I am not sure how both could stop working. There are two connectors onto the thermostat I did label these so they are not reversed. I hope.
  2. Steve Magnusson
    26,779
    Please confirm that you mean the oil temperature gauge and the water temperature gauge. (They seem fairly unrelated except for the wires of their senders both going thru the engine bay connector 169, but so does a bunch of other stuff so a bit odd it would be just those two things. And both of them are closely related to other things so odd those would still be working.)
    Is your clock working?
  3. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,217
    Gold Coast, Aust.
    Patrick
    Bad earth in the binnacle
  4. alistairw
    alistairw Rookie
    Jun 14, 2023
    19
    La Serena, Chile
    Alistair Walker
    Yes, the two temperature gauges both not working. Other gauges OK including the clock. Maybe a clue - I don't know what is normal behavior - but when they were working it would always take some minutes (at least five, maybe more) for the water temperature gauge to start moving, and then it would go quickly to a mid position on the gauge. This was long after the header tank was warm. But what always seemed a bit strange to me is that the oil temperature gauge would move at the same time. Well indeed, perhaps this is some grounding issue near the gauges, or perhaps even that there is short between the two signals.
  5. Steve Magnusson
    26,779
    The water temperature sensor is not in the header tank.
    Do you mean the oil temperature gauge also suddenly "jumps" from nothing to some higher value or that it just starts moving up from nothing?
    The 328 schematic shows that they don't share a too common ground, and both share a ground with other nearby things (that are working per Alistair).
  6. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,304
    Sergio Tavares
    Please tap the face of the gage when started sometimes this helps
    Steve Magnusson likes this.
  7. Rifledriver
    37,089
    Since both use sensors on the ground side do they not share a power source? Isnt the ground for the illumination only?
  8. alistairw
    alistairw Rookie
    Jun 14, 2023
    19
    La Serena, Chile
    Alistair Walker
    Apologies, I have been fooling myself, and after 3 months of not using the car (replacing suspension bushes) I am clearly not remembering well. So I just did the experiment of starting from cold, and holding at 2000 rpm. After 10 minutes the water temperature gauge starts to move. After 15 minutes it is at 170 deg. The oil temperature gauge also starts to move up slowly after 10-12 minutes and gets to around 170-180 deg or so. I don't recall it taking so long but never bothered to actually measure the time. So I am assuming all is OK - at least the gauges are working...
    2dinos likes this.
  9. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Sounds absolutely normal - water temp takes a while to come up; oil temp takes much longer. Works the same on any car...even Toyotas! :)
  10. Steve Magnusson
    26,779
    The ground at each gauge is for the illumination bulb and for the gauge itself, but, just like ground, both these gauges share +12V power with many other nearby things to themselves (and Alistair reports those are working -- but now seems all this is a non-problem).
  11. Rifledriver
    37,089
    Thats what I get from commenting on memory. I had not remembered that.
  12. Ferraridoc
    Jun 20, 2012
    17,217
    Gold Coast, Aust.
    Patrick
    Bugger me, I'd forgotten that! And if no other gauges are affected, it can probably be traced back to the plug! Clever.
  13. alistairw
    alistairw Rookie
    Jun 14, 2023
    19
    La Serena, Chile
    Alistair Walker
    Thanks for all the other useful information! However it is indeed warming up much slower than it used to, plus the engine is very down on power as I discovered this morning after finally getting the car out of the garage, and then having trouble getting up the hill from my garage to my house in first gear... So either something happened while the car was slumbering in the garage while I did the suspension bushes, or else I have inadvertently knocked something while doing the job.. It also now does a "soft fart" when being switched off, not a real backfire. Idles at 1000 rpm. I will start being a bit more systematic in troubleshooting now. There are some strange things with this car, like the pressure out of the right exhausts is more than the left pair, although when starting up the left is hotter. I thought this is "normal" and a function of the (US with cat) exhaust system, but maybe there is a block? Nothing would surprise me, after removing a very well made mouse nest (dating from the previous owner) from under the brake fluid container! And this on a car in really nice condition, history file from almost new, that I bought from a Ferrari Main agent..
  14. Sergio Tavares
    Nov 15, 2018
    1,304
    Sergio Tavares
    Tap the faces to bring them alive
    Congratulations on your new Italia Girlfriend is sometimes hot and sometimes not
    hahaha
  15. Alden
    Alden F1 Rookie
    3,600
    Central Florida
    Your water temperature really is coming up very slowly, sounds like your thermostat may be stuck open or missing entirely. Oil temperature does take a while to come up though, that's normal.
    Alden
    ChevyDave likes this.
  16. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    If the water temp is coming up slower than it use to and the car lacks power, check to see if both cylinder banks are firing - could be an ignition issue and would explain both symptoms. So could a clogged exhaust but since we used to stick potatoes in exhaust pipes to watch them blow out, I would think a mouse nest would pretty easily be expelled! ;)
  17. alistairw
    alistairw Rookie
    Jun 14, 2023
    19
    La Serena, Chile
    Alistair Walker
    Yes!! I replaced all the spark plugs with the NGK iridiums, before getting my timing light out. And indeed the front bank is not firing nothing when the sensor for the light is put on the wire from the coil to the cap. What threw me off the track is how smoothly the engine idles using one bank, given that my old Mustangs are horrible in such a situation, this is the difference between a flat plane and a normal crank I suppose. Reading old posts there is a confusing discussion on whether this fault could be caused by the crank annular sensor a/o the TDC sensor. But I gather that's a possibility for 308s and not 328s, so that would point at a failed coli or a short at the cap/rotor. Or an issue with the other coil connections The coils look old. The HT wires are relatively new, with few miles. Not sure about the caps, they look OK externally but I don't see them mentioned in the invoices, that go back to 1998.
  18. Steve Magnusson
    26,779
    #18 Steve Magnusson, Jan 14, 2025
    +1 - or the power module (power transistor) mounted on top of the coil. Ferrari sells it as a part of the coil assembly, but many F part suppliers (or an internet supplier) can supply it separately. You can swap components around and see if the no spark issue follows one of the components or not.
    MagnetiMarelli BKL3B = Transpo/WAI XM631
    (and might be Bosch 0227100137, but not 100% sure about that)
  19. alistairw
    alistairw Rookie
    Jun 14, 2023
    19
    La Serena, Chile
    Alistair Walker
    End of story I hope - I bought a new coil including power module from Superperformance, they describe it as Magneti Marelli but it isn't its a Bosch, it even has a label attached saying "Germany" which some might believe... I notice that US suppliers I looked at add a $500 core charge, refundable if you return your old coil, they want the heat sink. But since the Bosch unit doesn't look like the original coil, I transferred only the power module, and all now works! BTW the EBay power modules most/all say made in China, and are suitably cheap... And, given that it seems that all the usual suppliers I looked at describe the Bosch coil as "approved", I suspect that the original style is not available new, although Maranello will order it for you from the factory with delivery time maybe infinity. Eurospares have second hand coils at a reasonable price.
