Oil cap on CS... | FerrariChat
Oil cap on CS...
Discussion in 'United Kingdom' started by 599, Feb 25, 2008.
  1. 599
    599 Karting
    Mar 2, 2007
    107
    Surrey
    Marc
    mine keeps coming undone...does this happen to anyone else's CS...if so what have you done to remedy it...if theres no simple answer I guess I'll have to get it sorted under warranty...
  2. D8EAN
    D8EAN Formula Junior
    May 3, 2005
    354
    SE London
    i noted that some caps have a chain link holding them on..... seem that some do and some dont
  3. 599
    599 Karting
    Mar 2, 2007
    107
    Surrey
    Marc
    interesting...mine doesn't does yours?
  4. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    937
    Europa
    Bob
    probably you already do this, but if not try tightening the oil cap when it's hot (with gloves or a rag so as not to burn your hand). I've noticed on my 360M that if I screw it down cold then when it gets hot it all expands and gets loose. If I tighten it when hot then I don't get a problem. Anyway, could be worth a try...
  5. 599
    599 Karting
    Mar 2, 2007
    107
    Surrey
    Marc
    Thx ill try that
  6. Hud
    Hud F1 Veteran Lifetime Rossa
    Jan 26, 2005
    6,416
    Rob
    the later strads (like mine) have a drilled cap with a spring clip to prevent this, my previous strad suffered the same problem as yours :) As someone has said, tighten when cold, not hot , this will cure it for definite.
  7. 599
    599 Karting
    Mar 2, 2007
    107
    Surrey
    Marc
    Thx Rob...I think mine's a May 2004 when was yours 1st reg'd ?
  8. Hud
    Jan 26, 2005
    6,416
    Rob
    '54' plate, might have been a dealer mod?
  9. Hazy
    Hazy F1 Rookie BANNED
    Mar 12, 2005
    4,047
    England
    Adam
    I think robs is a mod. Tighten when hot Marc, as suggested, never comes undone then :)
  10. 599
    599 Karting
    Mar 2, 2007
    107
    Surrey
    Marc
    Rob says when cold you say when hot...now im confused ?!
  11. ninot
    ninot Karting
    Feb 7, 2004
    225
    Sunny Staffordshire
    Nino
    There's always gaffa tape!
  12. Radders
    Radders Formula Junior
    Jul 19, 2005
    421
    Mark
    most people will only ever open it when its hot anyway as there is little point when cold.
  13. stocky
    stocky Formula Junior
    Oct 25, 2005
    742
    Bolton , England.
    Andy
    i thought you are supposed to check the oil level when cold ????????
  14. Radders
    Jul 19, 2005
    421
    Mark
    nope, has to be running for about 15 mins 70c aprox. too hot and it will appear over filled, too cold and it will show under filled.
  15. Hazy
    Mar 12, 2005
    4,047
    England
    Adam
    Its when hot. Think about it, it expands when hot, loosening it, if its tightened when hot, it cant "expand loose". Robs brain is pickled at the mo...he knows this too ;)
  16. Hud
    Jan 26, 2005
    6,416
    Rob
    You dumbass.....
    Yes metal expands when hot............ which means you cant tighten it as much as it will go because its 'bigger'. When cold you can turn it further down its thread, which means when it gets hot it has absolutely no chance of loosening up. If you put it on when hot, the metal then contracts remdering it loose again....
    Jeez....you been sniffin diesel or summat :)
  17. 599
    599 Karting
    Mar 2, 2007
    107
    Surrey
    Marc
    ummm...I think I'll try both....when hot and cold...thx guys !
  18. Hud
    Jan 26, 2005
    6,416
    Rob
    No probs Marc :D
    Hazy has only had a couple of 360's so he's still wet behind the ears in all the quirks ;)
  19. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    I think you both should ask a grown up about this instead of bikkering with each other and letting everybody on here see how intelligent the mods on this site are
  20. Hud
    Jan 26, 2005
    6,416
    Rob
    Well its a step in the right direction i suppose................................. you starting to think before posting :D
  21. Hazy
    Mar 12, 2005
    4,047
    England
    Adam
    nope, still say its hot. :smug:
  22. Hud
    Jan 26, 2005
    6,416
    Rob
    You would ............ :smugger:
  23. steve f
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    ask the mechanics office boy
  24. Hazy
    Mar 12, 2005
    4,047
    England
    Adam
    Is this a glimpse of the old Steve??:D:D:D
  25. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    :D:D:D
