Oil change and oil weight | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Radiogeek1, Aug 18, 2009.
  1. Radiogeek1
    Radiogeek1 Rookie
    Jul 2, 2008
    31
    Pleasant Ridge, MI
    Bret Scott
    Hi, all-
    over the past weekend, I took my first long drive in my '83 400i, going from Virginia to Detroit to have fun in Michigan's Dream Cruise weekend. I'm happy to report that aside from weak air conditioning and an unfortunate meet-up between my front fascia and a tall parking block, the car performed well and was fun to drive.
    I'm planning to change the oil this week, and this is the first oil change that I've given the car. Any precautions I should consider? Also, my copy of the workshop manual calls for 10W-50 oil, which is virtually impossible to find locally besides perhaps motorcycle shops. I was planning to use more readily-available 10W-40, but was curious what everyone else is using. Any recommendations are appreciated.
    Thanks in advance for any responses.
    Bret
  2. aidanparte
    aidanparte Formula 3
    Jul 18, 2004
    1,231
    The 400 is a great long-distance cruiser.
    I use Castrol GTX 20W-50 as recommended by Bill Pollard. You'll need a large drain pan as the sump holds 18.5 quarts.
    Aidan
  3. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,242
    MA
    I've been using Mobil 1 Synthetic 15W-50 for the past few years.
  4. Ak Jim
    Ak Jim F1 Veteran
    9,617
    North Pole AK
    I am NOT an advocate of Wall Mart but they have 5qt jugs of Mobil 1 for $22.
  5. alastairhouston
    alastairhouston Formula Junior
    Apr 19, 2009
    575
    Largs Scotland UK
    Alastair Houston
    Have been using 10w60 fully synthetic, not an expert but have been told that you should definitely not go for a low viscosity 40 as these engines can operate at high temperature.
    Basically the bigger the range the better ie 10w60 or 10w50 and fully synthetic.
    Regards
    Alastair
  6. Radiogeek1
    Radiogeek1 Rookie
    Jul 2, 2008
    31
    Pleasant Ridge, MI
    Bret Scott
    Thanks all for the recommendations. I checked around and found a local source for Total Quartz 10W-50 full synthetic oil, and will be giving it a try. That, and a 5-gallon drain pan. :)
    Bret
  7. alastairhouston
    Apr 19, 2009
    575
    Largs Scotland UK
    Alastair Houston
    Phew
    very good idea going for even better than manufacturers recommended it being 'synthetic' 10w50
    the high end level of viscosity (50) must have been recommended by the manufacturer because the engine temperature would require that. Obviously something lower would mean that the oil would be too thin to cope! when at operating temp.
    Apparently (not an expert!) temp sensitive, these engines will operate through the min and max rev range without any problem for a long time without breaking! this is specifically what they were designed to do in other words they will handle much more brutal handling than a normal production motor would do under stress, for this they need a big viscocity range for the oil for sure.
    On the low end (10) i presume! (not an expert again) they recommend this because the oil when cool can get around the engine easier at start up a time when there is much potential wear. (maybe the modern oils have additives other than there stated viscosity that can reduce wear for cold starts) I would not take the chance and would for sure stick to the 10 for lower end.
    Please check the oil all the time, I go through a litre/quart every 300 miles.
    Good on you for the cruise just what these cars are for.
    Regards Alastair
  8. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    I use Red Line 15 W 50. On my first change I used 10W40 but leakage at front main seal was high. It was greatly reduced with 15W50 and the difference from 10W50 is negligible even for cold starts. Since I add oil in similar amounts to an earlier post and using an oil like Red Line intervals can be longer on oil but filter changes may be more important.
    Ken
  9. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,663
    Engine Bay, Georgia
    George C.
    A suggestion that was given to me was to turn the engine over a few times prior to start up when using a 15W. I this way you minimize start wear to almost nothing. Makes sense to me. M1 15W-50 European Formula full syn has 1300 ppm zinc and 1200 ppm phosphorus.
    Those are about the best numbers for ZDDP you can find in the market IMHO. My engine calls for a 15W-50.
    Would a 50 weight from the 70s-80s be the same as a 40 oil today? I'll have to run it by the Mobil guys.
    Ciao,
    George
  10. aidanparte
    Jul 18, 2004
    1,231
    If I changed my oil to a fully synthetic, would the seals leak more and would crud in the engine be loosened and cause other problems?
    Aidan
  11. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,663
    Engine Bay, Georgia
    George C.
    I have used 0W-40 M1 in the Merak - no leaks.
    Ciao,
    George
  12. Davidindallas
    Davidindallas Formula Junior
    Nov 5, 2003
    344
    I've used 5 w 50 synthetic in three cars with no seal or leak issues.
  13. aidanparte
    Jul 18, 2004
    1,231
    I'm going to switch to Mobil 1 15W-50. I was shocked by the price, though, at a local auto parts store - $101 for 6 quarts. Yikes! I found much better deals online - about $46/6 quarts. Where do you buy yours and what do you typically pay?
    Aidan
  14. Ak Jim
    Ak Jim F1 Veteran
    9,617
    North Pole AK
    Aidan, check out my post above. Wall Mart has 5gt jugs for $22. I bought several jugs a few weeks ago.
  15. aidanparte
    Jul 18, 2004
    1,231
    #15 aidanparte, Aug 31, 2009
    Jim
    What weight oil were they? 15W 50? I never shop at Wartmal, but I might make an exception in this case!
    Aidan
  16. Ak Jim
    Ak Jim F1 Veteran
    9,617
    North Pole AK
    They had Modil 1 in 15-50, 10-30, and 5-30. There might be other weights but I don't remember. I usually don't go to WM either, it will an interesting trip for you!
  17. aidanparte
    Jul 18, 2004
    1,231
    Jim
    Thanks for the info. I'm outta here!
    Aidan
  18. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    There has been much attention given of late to the requirement of anti-wear components within the oils that our older cars require due to the style of cams and tappets. Make sure that your oil has at least 1400-1600 ppm ZDDP(zinc) or you will get premature cam lobe wear.Dozens of posts within the last month or so. I have been using M1 15-50 but switched back to Valvoline VR 20-50..or Castrol GTX 20-50. They are made with this in mind. Or buy the ZDDP aditives for your synthetic...It was deleted from most "modern syns" since it is death on "cats". The trade-off may be a no-brainer since which is cheaper..cats or cam and tappet replacement. Will the usual suspects please chime in.
  19. aidanparte
    Jul 18, 2004
    1,231
    Jacques
    Thanks for your comments.
    According to Mobil's website, "Mobil 1 15W-50 is formulated with SuperSyn, an extra-high viscosity synthetic fluid, plus extra anti-wear additive to provide extra protection for severe service applications such as towing, hauling and racing. Mobil 1 15W-50 is recommended for high performance vehicles including turbocharged and supercharged engines where a thicker oil film is desired.
    Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles. Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines. "
    The 15W 50 oil contains less than 2.5% Zinc dithiophosphate according to the Material Safety Data Sheet, although it doesn't state what its actual concentration is.
    Any thoughts anyone?
    Aidan
  20. jacques
    May 23, 2006
    877
    Los Angeles/Florida
    Excellent.. Also Royal Purple..Mobil 1 Extended Wear 15-20 may have even more ZDDP..just buy its own definition. I'm going to check out Royal Purple again as my particular 1980 400i's oil temp. was consistantly 10 degrees F cooler..also the water temp always showed left of center (90C) when I ran it, but my
    mechanic didn't have it , so. noooo he used M1 because it was handy..don't you just hate it people foist their own personal agenda upon you..especially at these prices.
  21. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    Royal Purple as well as Redline have been recommended by reputable consultants here on FChat.
  22. Radiogeek1
    Radiogeek1 Rookie
    Jul 2, 2008
    31
    Pleasant Ridge, MI
    Bret Scott
    I decided to stick with my original choice, the Total Quartz Racing 10W-50 oil. After having read the most recent posts last night, I contacted Total this morning and was a bit surprised to receive a response back from their US lubrication manager before lunch. While this particular weight has a typical Zn content of about 1050 ppm, it has other ingredients designed to reduce wear, and it is certified to the European ACEA A3/B4 standard, which is said to have stringent wear requirements that help ensure backwards compatibility with older engines.
    Bret
