Oil Change Anomaly | FerrariChat
Oil Change Anomaly
Discussion in 'Technical Q&A' started by oldcoin, Aug 29, 2010.
  1. oldcoin
    oldcoin Formula Junior
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    Something just happened during an oil change on my 400i. When changing the oil filters, the front filter came off normally and I caught the usual 3 drops from the filter with a paper towel. When removing the rear filter, a LOT of oil came spilling out. The filter was the correct filter (Fram) with the stand-pipe. I have changed oil on this very car several times and this has never happened before. Any thoughts?
    Tony
  2. Steve Magnusson
    26,932
    #2 Steve Magnusson, Aug 29, 2010
    This is an indication that the anti-drainback valve inside the filter that "a LOT of oil came spilling out" from wasn't properly closed (and the other one was OK). Here's a jpeg of a "bad" anti-drainback valve (which is just a flap of rubber that should seal against the steel plate when pressurized oil isn't entering the circle of holes) stuck in the open position inside a Fram PH2804-1:
  3. oldcoin
    May 1, 2006
    258
    Reno NV
    Tony Mitchell
    Steve, Thanks for the info. I had hoped it was the filter. You have put my mind at ease
  4. Steve Magnusson
    26,932
    No trouble. The Baldwin's anti-drainback valve is the same, rather unsophisticated technology, but, since you are in the US, you should be using the Baldwin B253 ;)
  5. f355spider
    f355spider F1 World Champ
    18,055
    +1. Baldwin and UFI are the only filters to use in place of the Fram PH2804-1. The Fram is not worth risking your engine over. Does anyone still have the jpegs of the Frams used on the 328 that collapsed around the standpipe and lost complete oil pressure? Scary stuff.
