Oil Change BB 512, Difficult? | FerrariChat
Discussion in 'Boxers/TR/M' started by TridenteFury, Oct 1, 2015.
  1. TridenteFury
    TridenteFury Karting
    Sep 28, 2014
    78
    Ciao Tutti,
    Was wondering if there are any specifics (difficulties) in performing a self oil change/filters on a BB512 ??
    Motlo Grazie
    Carlo
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,540
    romano schwabel
    no problem
    but before you put on the new ones make a little oil on the rubber seal
  3. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
    Piece of cake...
  4. 365boxer
    365boxer Formula Junior
    Sep 30, 2004
    403
    La Drova, Spain
    Nick
    Fill the oil filters with oil before you fit them and as correctly said already lubricate the seal first.
  5. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,032
    I've accomplished a few, but NOT neatly. It's an amazing capacity of oil it holds, and so far, I've always managed to spill some. Ideally, it would be nice to control the oil from the filters when they come loose - be prepared - - - -twice!
    Otherwise, it's pretty straight forward.
  6. TridenteFury
    Sep 28, 2014
    78
    Thanks for the heads up...
    For the oil change, since it's a dry sump, I wasn't sure if it had any specifics... If it's straight forward, I should be able to do it...
    Cheers
    Carlito
  7. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,032
    The workshop manual is pretty helpful.
  8. Guegangster
    Guegangster Karting
    Apr 24, 2014
    58
    France
    Julien Guegan
    How often should we change oil for a car that is driven very little. Like 1000km per year?
  9. ferraripete
    ferraripete F1 World Champ
    is it like a Porsche? drain the dry sump tank and then drain the engine sump as well?
    If so, can someone please post a pic of the engine sump drain plug?
  10. TridenteFury
    Sep 28, 2014
    78
    If I'm not mistaken, for sure at least every 2 years, no matter how many miles/kilometers you drive, that is with classics... You could also do it at least every year if you're picky...
  11. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    What was that?
  12. Guegangster
    Guegangster Karting
    Apr 24, 2014
    58
    France
    Julien Guegan
    Ok, thanks. That's what I was doing, but wanted to check...
  13. mikael82
    Nov 18, 2007
    869
    Finland
    Mikael
    #13 mikael82, Oct 5, 2015
    I am just now removing engine from my car and took photo for "what is coming"
    Oil starts to come out as soon as you loose filter, half a liter is around number, so get that pucket ready!
    left side filter needs to be tilted to get it out and expect some more oil from there.
  14. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,032
    Ohhhh Yeah!!!
    You always remember your first time! :)
    I drained all the other spots, and (foolishly) assumed that was most of it. Then I pulled one of the filters, and it was a deluge of oil. I had a pan ready, but wasn't expecting the volume. 45 minutes of cleaning later - - - - - - - - - I thought, well both filters are on the same oil galley, so that must have been the bulk of it. Wrong! The second filter seemed to be holding back as much as the first. 45 minutes of cleaning later! Subsequent changes have been slightly neater.
    How we love them so!!!!
  15. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    before you loosen the filter punch a hole in the bottom of each filter and wait until there is no oil coming anymore, or nearly no oil.
    this for me is absolutely normal and I have not mentioned it in my post no. 2 here
  16. 512man
    512man Formula Junior
    Jun 27, 2014
    337
    Sweden
    Tobbe
    Good advice...especially when the filters is mounted like that.
    Will try it next time....Intelligent Romano :)
  17. ferraripete
    anything specific you use to punch the hole? obviously not a drill.
  18. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    a screwdriver and a hammer
  19. LightGuy
    LightGuy Four Time F1 World Champ
    45,669
    Texas
    David
    I don't know.. how long has oil been underground ? ;)
    As far as I know oil doesn't have an expiration date. It has a contamination and detergent breakdown limit.
    Of course the dealer will tell you otherwise.
  20. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    once a year I change the oil in all of my cars, even if only driven 500 km.
    if you only drive such a little km and then also only short distances the oil temperature never will get high so that the condensation will never go out of the oil. and condensation is water, and water means rust and less lubrication.
