Oil Change: filter screen screws | FerrariChat
Discussion in '360/430' started by Spurkey, Jul 16, 2017.
  1. Spurkey
    Spurkey Karting
    Jan 15, 2010
    54
    Nanaimo, BC
    #1 Spurkey, Jul 16, 2017
    When changing the oil in my F430 I continually have problems removing the 4 tiny screws holding the filter screen flange in. They always seem to require a monumental amount of effort to remove despite being torqued to a small amount when they go in (6 Nm/4.5 ft-lbs/53 in-lbs). Changing the oil again tonight I got only one out before I managed to twist a good spiral into yet another Allen key. I quit for the night before stripping one of the screws.
    Any advice?
  2. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    Bit hard to tell from the pic but from memory they are countersink cap heads. They lock on the taper. I have seen smoke and sparks when they "crack" undone. Get better allen keys. Some are too soft and twist. Some are too hard and snap. The trick is to crack them undone with one fast sharp movement. Don't slowly increase pressure.
  3. CrazyMD
    CrazyMD Formula Junior
    Mar 10, 2012
    404
    Southern California
    Tap them lightly with a brass hammer and then try to loosen them.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Get a matching bit from an socket allen key kit, like the previous post says, give the bit a tap with a small hammer. Once you have them out look to fit some stainless allen screws as a replacement, they are a harder material and the allen key will not chew out the hex.
  5. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    I had the same issue. A sharp rap to break them loose is good. Or apply some heat.
  6. Spurkey
    Spurkey Karting
    Jan 15, 2010
    54
    Nanaimo, BC
    The problem is that you don't know until you've gotten home that they're garbage... I've got 3 sets of keys, plus a set of socket-drive keys. Stupid socket-drive set stops at 4mm, these allen screws need a 3mm.
    I don't have a lift so using a torch on the engine while lying on my back with minimal escape space has so far kept me from trying that. I'll have to try it when the wife's not watching. :)
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Get a paint heat gun to warm them up- the latest 2kw ones come with some metal attacments to direct the heat. About £22 here for a black and decker make. Good allen keys are made by unbreako, but a socket version is best- see if you can source snap on make
  8. Motob
    Motob Formula 3
    Nov 11, 2003
    2,368
    Frederick, Maryland
    Brian Brown
    A good manual impact driver (you hit it with a hammer) will get them right out. I recommend using a new hex bit with sharp edges. If the inside of the hex bolt is loose/starting to strip, you can hit it with a flat punch, driving the material back towards the center of the fastener until the hex bit is a tight fit. I get it tight enough so I have to tap the hex bit into the fastener.
  9. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    Stainless is considerably softer than the heat treated steel that cap screws are made from.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    True, but they dont react with the alloy casting and get jammed in place.
  11. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    Yes that could very well be true. I have experienced hundreds of these screws that will only come undone with a hammer and centre punch. You can barely nip them up one day and the next they will undo with a loud crack and a sore hand.
  12. Jgivoo
    Jgivoo Formula Junior
    437
    New Jersey
    Go to amazon and type in 3mm hex socket. There are plenty available
  13. Spurkey
    Spurkey Karting
    Jan 15, 2010
    54
    Nanaimo, BC
    #13 Spurkey, Jul 18, 2017
    Indeed there are plenty on Amazon, doesn't mean any of them are any good. Tonight's update: 1 more bent key (bringing the total to 3), 1 twisted socket bit, 2 screws successfully removed, 1 stripped screw, 1 screw left alone. The pink key is a brand new Bondhus hardened key. It is always the smallest jobs that are the most aggravating.
    As for applying heat, how much heat are we talking about here? The cap gets in the way, I assume you're heating up the engine block underneath the cap somehow to get the hole to expand a touch.
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    If you use a nickel based grease on the threads it stops a lot of the problem, i used to work on a seacat fast ferry and we had all sorts of problems with Alluminium and steel fittings corrosion.
  15. CrazyMD
    Mar 10, 2012
    404
    Southern California
    Did you try tapping them with a brass hammer? That always loosens them up
  16. Aeroman
    Aeroman Karting
    117
    DFW Texas
    I spoke to my Metallurgist and he recommended a corrosion inhibitor that meets MIL-PRF-16173, Grade 2. There is a commercially available product call LPS2 that comes in a spray can that meets this specification. He recommended to coat the bolt threads and the shoulder of the bolt to prevent moisture penetration.
  17. Spurkey
    Spurkey Karting
    Jan 15, 2010
    54
    Nanaimo, BC
    I tried tapping them with a hammer, yeah, all I had nearby was a claw hammer. I applied heat using a propane plumber's torch for about a minute to the general area of the screw I was working on, gave it 3 or 4 medium taps with the hammer, then tried to undo it.
    Thanks for the info, there are a few local distributors that claim to carry that stuff I'll see if I can find some. Also: you have a metallurgist?! Man, I didn't know that was a thing one could get in life, I have so many questions... ;):)
  18. Aeroman
    Aeroman Karting
    117
    DFW Texas
    Well, it's not like I bought and paid for him....that would be sooooo wrong. Besides, I couldn't afford to feed him.
    If you google that MIL spec, you will find places you can order the LPS2. Or LPS3. Apparently, it's just thicker.
