Oil change intervals on 360s | FerrariChat
Discussion in '360/430' started by Fomart, Apr 1, 2010.
  1. Fomart
    Fomart Rookie
    May 24, 2004
    12
    How often do you change the oil on your 360???
    I got an oil change yesterday on my car. The dealer is recommending an oil change every 3,000 miles, despite the use of synthetic oil.
    My previous car was a Porsche Boxster, and the recommended oil change interval was 15,000 miles with use of synthetic oil.
    What is the real world oil change interval for you guys on the board who own 360s???
    Thanks in advance for your input.
  2. MC DOUG
    MC DOUG Karting
    Mar 7, 2010
    65
    White Rock,BC Canada
    Doug
    Change it once a year, keep it between the holes on the dipstick checking it with the engine hot and the dipstick cap "resting" on top of it's threads. unless your putting lots of miles on it (over 5000/year) that should do. Have Fun!
  3. mr_bock
    mr_bock Formula 3
    Oct 27, 2006
    1,373
    FL full time
    +1
    Even if the miles are low, there is condensation, acids, etc... that can pit the internals just sitting there.
    Best to 'drive' that baby and get it up to operating temp and drive it like it was ment to driven.
    Above all, Enjoy that car!!!!
  4. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,454
    i change mine every 3000 miles and change at least 2 xs a year,also like others said ck oil level between changes,change more often cheap insurance imo
  5. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    If driving say <7-8,000/year I'd do once per year. There's no way the oil gets broken down enough in 1 year putting low miles on it.
  6. Under PSI
    Under PSI F1 Rookie
    May 13, 2005
    4,240
    Phoenix
    Jim
    I thought you had to fully tighten it to check the oil, not just on top of the threads. Have I been wrong?
  7. zippyslug31
    zippyslug31 Formula 3
    Sep 28, 2007
    2,075
    PDX
    Kevin M.
    It's always been my understanding, and practice, to simply leave the cap lying on top of the threads too.
  8. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    Yes you have been wrong, check the manual- fully warm, flat surface, car idleing, cap resting on neck not screwed in.
  9. Rifledriver
    37,103
    Do you think the extra 1/4 inch it goes down when screwed in place makes any difference?
  10. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    Heck, it may actually be a good thing as extra margin to not overfill the car! If people don't check with oil fully warm it may be overfilled as soon as the car gets up to temp (I know I had to take at least a full quart out of my car from the prior owner's overfill)
  11. wopner
    wopner Rookie
    Mar 10, 2010
    15
    Indianapolis Area
    There is a company out here in Indiana that does some very thorough oil analysis, blackstone labs. They will even correlate your tests over time so you can see the results for a particular car as time goes on, they also provide access to all your reports online.
    This may help you guys determine the correct change interval for your specific driving habits and oil brand.
    http://www.blackstone-labs.com/
    They have samples reports here:
    http://www.blackstone-labs.com/report-explanation.php
    Just FYI
  12. MC DOUG
    MC DOUG Karting
    Mar 7, 2010
    65
    Doug
    If you measure the thread count on the filler cap inset (female side) and compare the length against the distance between the holes on the dipstick, you will see that you would be putting almost 1/3 litre more than full-If you topped right up. Some of this oil could get up and into the "air system" and cause some minor smoking issues. The owners books (- the bad english) are quite informative.
  13. DesmoRob
    DesmoRob Rookie
    Jun 3, 2009
    47
    Penticton, BC
    RobGH
    If you don't mind me asking, what are you guys paying to have your oil changed? Anyone know what the cost would be in Canada? Thanks
    V8coupe likes this.
  14. Syntax73
    Syntax73 Rookie
    Mar 28, 2018
    8
    Mike Miller
    If you plan on driving a 360 every day how often should I change the oil?
  15. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    389
    Covington GA
    Tam V.
    I would do 7.5k miles or 6 mos
  16. tazandjan
    39,170
    6 mos is a waste of money.
  17. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Once a year is fine, assuming everyday driving keeps you under 10,000 - 12,000 miles.
  18. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    628
    Eden Prairie, MN
    Matt
    This
  19. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Oil change interval in the manual is annual or 6250 miles.
    360trev likes this.
  20. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Yes, which translates pretty closely to 10,000 km.. 10,000/1.6093 = 6,214 miles.
    You guys do know that the factory recommendation is to also do the gearbox/diff oil at the same time as the engine oil too?
    I'd also recommend doing the corrosive coolant regularly too as if its left to rust this can lead to premature failure of the oil cooler...
    E60 M5 and Skidkid like this.
  21. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    In that case, go with that. I usually end up needing to change on time, not miles.
  22. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    Change all of the fluids at least once a year.
