Oil change pricing? 10W60 vs 10W50? | FerrariChat
Discussion in '612/599' started by doctorj!, Dec 29, 2011.
  1. doctorj!
    doctorj! Formula 3
    Aug 3, 2010
    1,509
    Jersey
    AJ
    So I went to my local dealership today to drive the car with their main technician. Again, no noises heard, no problems found. All they said was that the car needs an oil change as its been a year and a half. That along with a brake fluid flush is $850 plus tax. Just want to make sure this sounds right. Its pricey, but I guess it comes with the territory.
    I was told that the oil was changed when the car was delivered to me by Ferrari of Newport, but according to Ferrari of central Jersey, the last time it was done was in May 2010, so well overdue. So either Newport was BSing me, or Central Jersey doesnt have the correct info.
    A local but reputable shop quoted $500 for the same service, but I know they do not use the same grade racing oil. The dealer uses Shell 10W60, while the local shop uses 10W50. Any thoughts on this subject? Does one make a difference vs another? At the end of the day, I want to do what is best for the cars longevity.
    AJ
  2. zackspeed
    zackspeed Karting
    Nov 4, 2003
    67
    AZ
    Zack
    Go with the dealer. Changing oil on a 599 is more involved than you think. The 10w60 oil is what is required for that engine. Also there is an oil additive that needs to be added at every oil change.
  3. tazandjan
    39,166
    Ankur- 599s (and 612s) had owners complaining about lifter noise on start-up, so they have snake oil they use to quiet the lifters. I would stick with the recommended oil viscosity (10W-60), and having an FNA dealer service your relatively new car will make it worth more when you trade it for the 599 replacement. Annual service on a Ferrari runs $1000-2000. We just have to learn to live with it. Remember, your engine is a slightly softened Enzo engine, so needs to be well kept.
  4. doctorj!
    doctorj! Formula 3
    Aug 3, 2010
    1,509
    Jersey
    AJ
    Thanks for the input! I went with the dealer. No plans to trade the car in the near future.
    I just love the car....
    AJ
  5. Ferrari 360 CS
    Ferrari 360 CS F1 Veteran
    Dec 4, 2004
    6,888
    Cape Town,SA
    Jacques
    Great advice as usual! Interesting even the GTO has slight lifter noise for a few second after start up, its not a big issue, these engines will never be Lexus quiet anyway and it would be a shame if they were.
    I wonder how much the noise would increase if the additive wasnt added.
  6. tazandjan
    39,166
    Jacques- Not much. Ferrari used the same design lifters (different part for the 599, similar design) on the 550, 575s, and 612s and and never received complaints on the Maranellos. Once the 612 and 599 came out, though, they did get complaints. This is probably due to less underhood noise in those newer cars (even though the early 612 has essentially a 575M engine), so the lifter noise was more easily heard.
    Personally, it would not bother me since I know what would be causing it. US manufacturers figured out how to make lifters that do not tap decades ago, but their engines did not turn 8300 rpm, either.
  7. FJerry
    FJerry Formula Junior
    Dec 1, 2004
    933
    United States
    Dont mess around with this. The oil isn't just a matter of weights its also a matter of what additives they use. I don't know this but I would not be surprised to find out that the oil Ferrari uses contains additives that are from motorsport. Think of it like this- if you damage the motor from an inadequate oil, how cheap will that factory authorized oil change look then? :)
  8. doctorj!
    doctorj! Formula 3
    Aug 3, 2010
    1,509
    Jersey
    AJ
    Those were my thoughts exactly. Can't be cheap with cars like this.
  9. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    looking at those viscosity numbers for the oil made me think ( ooops )
    on current race engines that use that weight oil we need ( engine builder recommendation )to heat the oil close to operating temperature before turning them on. You could try a dipstick or radiator/engine block heater to bring up the oil temp, it is easy enough to try. It would verify lubrication issue during a cold start. lf the noise goes away with heated oil, then you know it is a cold start lube issue and need to go easy until temps come up. Then look for an oil / additives that best address the issue.
    I have issues with using any racing oil in street cars... racing oil is always dumped after an event... racing oil does not have the additives to condition oil and control contaminates in normal use of a car... it could be your issue here... It may be cool to say that you use racing oil, but... do a bit of internet research on the topic, you may have similar conclusions that racing oil is best for racing
  10. tazandjan
    39,166
    Cheesy- Not a problem with a 10W-60 oil. On start-up the 10W-60 oil flows just as well as a 10W-30 oil, but is considerably stouter once it is warm.
  11. Ferrari 360 CS
    Dec 4, 2004
    6,888
    Cape Town,SA
    Jacques
    As an aside the GTO just returned from an annual service today, was astonished at how much oil it takes, cant recall off hand but was around 18 litres or some high number.
    Lifter noise is still present at idle for the first few seconds, not really an issue because the exhaust drowns out any lifter noise unless one is standing at the front of the car.
  12. tazandjan
    39,166
    Jacques- The owners manual says they take about 12 liters but those are not always correct, so the amount could be considerably higher. My manual says 10 liters for my 575M, and it takes at least 12 to fill it.
    Now you know why it takes a while to warm the oil. I am with you on the tappet noise. Once you know what it is, no big deal. Mine has it too, but the underhood noise is so high you only hear it standing near the engine with the hood/bonnet open at start.
  13. Ferrari 360 CS
    Dec 4, 2004
    6,888
    Cape Town,SA
    Jacques
    Will have a look at the invoice to confirm the actual amount but was interested to see air filter change is also part of the annual as well as a 2.5 hour inspection, all under carriage panels are removed, suspension components are checked among other things.
  14. tazandjan
    39,166
    Jacques- The filter change you saw may have been the environmental filter, which is changed annually. The engine air filters are normally done at 15,000 mile intervals.
