oil change | FerrariChat
oil change
Discussion in 'Technical Q&A' started by procure95, Dec 17, 2006.
  1. procure95
    procure95 Formula Junior
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    Anyone know what oil to use in a 1988 TR? It calls for 10w-50 but no one carries this brand. can any one recommend an alternative?
  2. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Welcome to Ferrarichat. :)
    Use Redline engine oil. It rates highly in paps book. ;)
  3. Dino2010
    Dino2010 F1 Rookie
    4,852
    Belgium
    Well, I just go for what ferrari recommended themselves in those days:
    the holy saint: AGIP SINT 2000!
  4. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Hi,
    10W-50 (10winter-50) is obviously not the brand, but the viscosity.
    Any well known brand of the same viscosity will do (Castrol, Mobil, Shell, Valvoline, Quaker, Pennzoil, etc. etc.)
    Ferrari recommends Agip, an Italian brand that here is either impossible to find or if you do you get gauged for: it is not better than any of the above!
    Good luck.
    Saluti,
  5. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    Yes I realize 10w-50 is the viscosity not the brand but no one manufactures this viscosity motor oil that I can find. Can any one recommend an alternative viscosity and brand name for this vehicle? Should I use synthetic oil too? Thanks for your help.
  6. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    Ok but what viscosity? I cant find 10w-50. Can any one recommend an alternative viscosity and brand name for this vehicle? Should I use synthetic oil too? Thanks for your help.
  7. testarob
    testarob F1 Rookie
    May 13, 2006
    2,504
    Debary, Florida
    Rob
    Are you sure it's 10W50? My 86TR owners manual says Agip SINT 2000 SAE 10W40...
  8. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    My says Agip SINT 2000 SAE 10W50 but i downloaded the owner manual from ferrari owner's site and that manual does say to use Agip SINT 2000 SAE 10W40. What does SINT 2000 stand for? Do you use synthetic oil? thanks for you help. John
  9. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
  10. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    SINT *means* synthetic in Agip lingo...
  11. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Somebody link to AEHaas' motor oil bible... I used to have it bookmarked, but that was on my old computer, and I can't seem to find it anymore. It's a great read, though.
  12. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    Do not use the owners manual to select an oil. In fact, I find that even new cars of today are a cycle behind in what the owners manual recommends. You have to find better oils. Do not use a 1960’s oil if a 2006 oil is available. A 10W-50 oil of the 1980’s may thin to a 0W-30 in as little as 1,000 miles. The engine manufacturers knew this and made the appropriate recommendation. Therefore the engine can in fact run with a 20 or 30 wt. oil assuming there is no excessive wear. Today's 10W-40 oils will stay that way and may even be too thick in the long run.
    Read the following then make an informed decision:
    http://theoildrop.server101.com/forums/showflat.php?Cat=0&Number=258506&an=0&page=0#Post258506
    If you are not racing the car on the race track then many people may use a 5W-40 or better yet a 0W-40. I used 0W-20 Mobil 1 in my Maranello 575 and oil analysis showed less wear than with the manual’s recommended 5W-40 Shell Helix Ultra. My Enzo manual recommends 10W-60 Helix Ultra yet I am not racing the car. The oil never gets above 180 F. I am using a 0W-30 wt. oil.
    Synthetic in Italian is sintetico.
    aehaas
  13. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Ya gotta just love good ol' Ali.
  14. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,826
    Cerritos, CA.
    I am using Amsoil 10-40 100% synth. right now on my 84 308 QV and it's about low 28 to high 49 deg. F, is this OK for winter?
  15. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,284
    Illinois
    Amsoil is very good stuff. If you are going to experience cold temps of about 20F and below, I would consider changing to 5-30W. If the temp is going to be frequently higher than 20F, then I would stick with the 10-40W. Just make sure the car gets warmed up a bit before driving it hard.
  16. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    Ali
    Thanks for the info. I don’t race the car but I do drive it fast for short periods of time and I don’t drive it often. I live in PA and the weather can get cold but I don’t plan on driving the vehicle in bad weather. I just bought the Testarossa in October after I purchased a 1989 348TS two weeks prior. It is so great having both of them in my garage. Driving both of them gets you to appreciate each one and it would be hard to decide which one to sell if I had to make a decision. Do you recommend a lower viscosity for my purpose? I could not log on to the site you pointed too. Thanks for you help. John
  17. procure95
    Dec 17, 2006
    587
    PA, USA
    Giovanni (John)
    Ali
  18. miketuason
    Feb 24, 2006
    15,826
    Cerritos, CA.
    Yes I do warm it up for about 5 to 8 min. before driving it. Thank you John
  19. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    "Yes I do warm it up for about 5 to 8 min. before driving it."
    This is not good. You should start the car and go lightly on the gas. It is better to use minimal throttle and yet warm up the engine faster by driving.
    I think a good start would be a 0W-40 such as Mobil 1. You should really sign up for the web site if that is required and read the chapters. I may just re-post them here.
    aehaas
  20. blmjumper
    blmjumper Formula Junior
    Jun 18, 2006
    341
    Boise
    Ty
    I switched to Mobil One 0W-40 upon reading Oil 101 and my 328 is much happier...temps don't get too cold in town (avg 40F-ish).
    Another note...since I switched, and started driving this car like I beleive it should, no more leaks...
  21. mg54
    mg54 Rookie
    Jan 12, 2005
    48
    Massachusetts
    Michael Gardner
    The AGIP Oil that ferrari recommends is available at American Agip.com. They will sell it to you but it will take them a month to give you a customer number.
    It is an Egyptian Oil company, not Italian as someone above mentioned. Sint 2000 is their replacement for the 10-50 original. It is a 10-40 grade.
    Also a company called ferracci.com will ship it to you. very dependable.
    I use Castrol 20-50 blend. I have notice fewer to no drips after switching, and good oil pressure etc. Get it at Advance Auto supply..
    Good luck
  22. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Hi,
    At the end of the day I believe you got more than you bargained for, or enough info to get drunk from it.
    In an effort to stay away from being pedantic or prolix, since I am not a professor, but a simple engineer, I will give you the following suggestions:
    1-use syntetic as it is the best oil to withstand heat
    2-use a multigrade oil (i.e. 10W-40)
    3-use as low W viscosity rating as you feel comfortable of doing for the area where you live (i.e. 0W; 5W; 10W) to get as good lubrication at start-up as possible
    4-if you do not find a 50 viscosity rating, a 40 will do and even a 30 will do no harm if you do not abuse your car (i.e. race it).
    Finally, Agip is Italian and definitely not Egyptian.
    I know because I used to buy fuel from them.
    Good luck,
    Saluti,
  23. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
  24. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    BMW knows what's best !
    Saluti,
    A.
  25. Glassman
    Glassman F1 World Champ
    How on earth can it not be good to warm up your car at idle before driving it?
