oil Change | Page 2 | FerrariChat
oil Change
Discussion in '348/355' started by trestlenewport, Jun 27, 2013.
  1. ClydeM
    ClydeM F1 World Champ
    12,137
    Wayne, NJ
    Clyde E. McMurdy
    IMHO : maybe pull the cooler pipe on your very first oil change in case the PO neglected the car or it was sitting for a while. But that pipe wasn't designed to keep going on & off. Leave it alone.
    If you change your oil regularly, don't worry about 1qt in the system.
    If you drive in detrimental conditions, just change it more frequently.
  2. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,026
    PA
    Kevin
    As someone who has done several 355 oil changes, I cannot imagine this would be a practical solution. You'd wind up with half a gallon of used oil on the top side of the undertay. A nightmare for sure.
  3. trestlenewport
    trestlenewport Karting
    Dec 9, 2010
    195
    North Bay Ca
    Thanks. Gear box oil next.
  4. Volair
    Volair Karting
    Apr 11, 2013
    241
    Carmel, Indiana
    Bart
    If the hose is the lowest point in the system couldn't one just disconnect it and drain all oil via that hose? Would eliminate the need for removing trays, etc.
  5. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Honolulu - Seattle - Okinawa
    Steve
    Not sure actually. I imagine you would have to isolated places where the oil would hide in a none running state. In the sump, where the oil drains to from the oil tank when not running and in the oil cooler where this extra quart of oil is hiding that requires line removal to completely purge all the oil.
    Maybe saying it is the low point in the system is technically inaccurate. There is oil that sits in the oil cooler/line than would have to travel upwards and against gravity to drain out the oil tank or sump when both plugs are removed. The same would probably be the case if you just removed the oil line. You would have oil in the tank/sump that would need to travel upward to find it's way out of the system.
    Keep in mind this is not fact, just me thinking out loud.
  6. Volair
    Volair Karting
    Apr 11, 2013
    241
    Carmel, Indiana
    Bart
    I'll find soon enough as I'm getting ready to my first oil change in my new-to-me 348.
