Oil consumption | FerrariChat
Oil consumption
Discussion in '348/355' started by Labman, Aug 7, 2011.
  1. Labman
    Labman F1 Rookie
    3,799
    Long Island, NY
    Steve
    What is the norm for oil consumption in a 1998 355? Is it normal? I needed to add a quart of oil recently and I want to be sure this is normal or is there a problem. Oil changed about 1500 miles ago.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    1 to 2 liters per 1000 km is the spec.
    Looks like you're just fine.
  3. billyfitness
    billyfitness Formula Junior
    Feb 14, 2006
    581
    Overland Park, KS
    Bill Leavitt
    Don't wait until you have to add a quart to add oil. Check it and keep it btwn the lines frequently.
    I check mine every 200-300 miles and consumption has not changed at all in 6 years.
    I'm at 1/2 qt every 650 miles.
    Mine is a '97 F355 w/ 48K miles.
    -Billy
  4. AceMaster
    Feb 6, 2009
    34,762
    Ontario, Canada
    I believe the manual says to check every 500 miles
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,660
    Mine, with 61K miles and 5K race track miles, never consumed a single drop (in the typical 3K mile OCI).
  6. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    My 1999 F355 Spider burns Zero oil. Not sure what is normal. But I have had this machine for 5 years. Put 11k on her. Never has it burnt an ounce. Just my experience. I am a firm believer of lubrication. Oil changes at no later than 5k or 1 year. I use Royal Purple 5W-40 Synthetic.
    I know there is a spec for oil burning. Just thought I would share my experience.
  7. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    What type and weight of oil do you run?
  8. Mitch Alsup
    Nov 4, 2003
    9,660
    I run and have run:: M1 5W-40 T&SUV, M1 5W-40 TDT, RedLine 5W-40, RedLine 10W-40, AMSoil 5W-40, Redline 5W-30, and a couple of others.
    I am currently running 10W-40 Motorcycle oil (for the ZDDP levels).
  9. mike_747
    mike_747 Formula Junior
    Dec 15, 2008
    794
    Seattle
    My 1995 seems to burn none or very little. haven't had to add any between annual changes.
  10. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    It's toast. The junk yard will give ya 500 bucks for it. Count your blessings.
  11. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    Junkyard will give ya 600 bucks. Count your blessings.
  12. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    The wrecking yard will give you 700 bucks. It's not too late to start over.
  13. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    Take it to your closest Junk Yard. Get at least 800 bucks for it. You are all set.
  14. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    #14 mpodgor, Aug 9, 2011
    1995 F355 from what I understand has valve guides that prematurely wear.
  15. mike_747
    Dec 15, 2008
    794
    Seattle
    Fr your information "clueless" all 355's have valve guides that wear prematurely.
    Mine were replaced years ago, previous owner.
    Get a life half wit.
  16. benny355
    benny355 Karting
    Jul 20, 2010
    184
    Mine consumed oil before... and now still does after full motor rebuild!
    I am quite curious in regards to this... I wonder if how you drive the 355 dictates how much oil you burn or if oil pressure has anything to do with it? I drive frequently and do hit upper range of RPM's every drive.
    I'm no Ferrari mechanic but to be honest, I may be concerned if mine burnt zero oil - I thought that it is supposed to.
    If any pro would like to chime in here - would like to hear your opinions!
  17. m5guy
    m5guy Formula 3
    Aug 17, 2008
    1,627
    Ventura, CA.
    Greg
    How much oil is your car burning now, after the rebuild?
    Have you or your mechanic done a post-rebuild compression and leakdown check on the engine?
    I am not a pro and have never rebuilt a Ferrari engine, but most pistons have 1 ring that functions as an oil scraper/wiper. When installed upside down, they don't function very well.
  18. benny355
    benny355 Karting
    Jul 20, 2010
    184
    I'm burning (+/- 100ml) 1L (qt) per 1000 miles. I was burning more prior to rebuild but guides were shot and one valve was burnt. Compression has been checked since but I have not had leakdown performed.
  19. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    You are a dumb ass. Why do you advertise it so much? Did you not know Ferrari changed their valve guides? Because they noticed the "little malfunction". My 1999 #19 Fiorano burns ZERO oil. I take care of my machine to the point of being......insane. Take your meds. I just took mine.
  20. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    I am curious as to what year your 355 is?
  21. benny355
    benny355 Karting
    Jul 20, 2010
    184
    I will steer clear of the mud throwing here but I am curious.....How often do you drive your car? And when you do drive it do you cruize or DRIVE it? I am just having trouble rationalizing burning zero oil. I have updated valves and guides superior to OEM and I still burn some oil. These engines are rated to consume oil by factory specs.
    Also, I can't validate this info - but I was told that Ferrari did change the valve guides on the later model 355's.... but these valves can still wear out and are inferior to replacement valves available today.
    I would really appreciate if someone would chime in here that can properly explain the mechanics of oil consumption in the 355.
  22. benny355
    benny355 Karting
    Jul 20, 2010
    184
    Its a 1995
  23. m5guy
    m5guy Formula 3
    Aug 17, 2008
    1,627
    Ventura, CA.
    Greg
    #23 m5guy, Aug 11, 2011
    Here are the specs for oil consumption as stated in the factory manual. Max consumption of .44 imp gallons per 600 miles = 2.1 quarts. Yes, that would seem like a lot for any other car, but hey -- it's a Ferrari! Over-consumption is synonymous with the brand.
  24. Mitch Alsup
    Nov 4, 2003
    9,660
    One thing I noticed in my F355 is that it will consume oil if the oil level is above the mid-point on the oil dip-stick. Then as the oil gets to the mid-point, oil consumption stops. I noticed this on a 3000 mile trip a few years ago. Starting out wiht a full load (max) it consumed a quart in the first 1000 miles, then not a drop on the second 2,000 miles.
    I suspect that the level and the odd way the oil-vapor system works allows the engine to pull oil mist (as opposed to vapor) until the oil level is sufficiently down in the dry sump. From this point onwards, the mist stays in the sump, and the oil level constant.
  25. benny355
    benny355 Karting
    Jul 20, 2010
    184
    Interesting! Checked it tonight after ride and it's at the midpoint.... I will leave it there and see if there is any difference rather than keeping it at the top line.
    Thanks!
