Oil Cooler Hoses Replacement - Drain Oil? | FerrariChat
Discussion in '308/328' started by Imatk, Jan 31, 2024.
  1. Imatk
    Imatk Formula Junior
    May 6, 2007
    773
    I have to replace both the upper and lower oil cooler hoses (like pretty much every other hose on this car).
    Does the oil need to be drained to do this job... or I guess I should say, SHOULD it be drained?
  2. Rifledriver
    37,108
    No real need. You will probably be taking off the oil filter to do it so does make some sense. Remove cooler with hoses attached and try to get them free from cooler on the bench. Damaging the cooler getting hoses off was so common that back in the day when it was all available and not stupid expensive we decided which to keep and just cut the other off.
    Imatk likes this.
  3. Imatk
    May 6, 2007
    773
    Thanks for the tip man, will do!
