OIL DIPSTICK LEVER QUESTION | FerrariChat
Discussion in '360/430' started by fastguy1012, Dec 20, 2012.
  1. fastguy1012
    fastguy1012 Rookie
    Oct 30, 2012
    40
    SO. CAL.
    ANTHONY
    I just changed my oil. Per Aldous Voice instructions,
    I made sure I noted how much oil I removed. Car had been stitting parked for about 2 weeks. I changed filter, added close to what I originally removed...
    upon warming motor for about 20 minutes, i checked oil many times as engine ran....very little oil showed at very lowest tip of dipstick.
    I know I put back in what I took out.....also...had white exhaust coming out for a few minutes...unsure if it was smoke or steam...
    So now my dipstick is just barely showing oil and I dont want to overfill engine...
    it is running good, temp. normal...oil temp slowly moving up...so far added about 8 quarts
    Any advice? how about opinions on LUCAS SYNTHETIC ADDITIVE?
    Thank You
    ANTHONY [email protected]
  2. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    You need proper oil tempreture before checking the oil. If the ambient is low the oil may well not be warm enough....
  3. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    As Eddie says, the oil needs to be hot - you wouldn't believe how much it expands when it heats up.
    You need to be very careful of overfilling the oil as it can find its way up into the air intake system and into your engine - this is usually followed by clouds of smoke. The problem with overfilling is that you need to clean out the entire intake system and check your MAF's for damage. This is why I like to measure what I take out and put back in a little less to begin with.
  4. fastguy1012
    fastguy1012 Rookie
    Oct 30, 2012
    40
    SO. CAL.
    ANTHONY
    Thank you for the help.
    I do not think I overfilled it yet.
    I think I will actually drive it for 10 miles or so to get it real warm.
    im still learnin!
    Any comment on that LUCAS OIL ADDIDTIVE?
  5. DrDon
    DrDon F1 Rookie
    3,627
    Infractionville
    Armando Decredenza
    RTFM
    I didn't check the oil correctly shortly after I got the car and in a panic added a liter.
    No smoke though.
    Then I read the manual and found out the oil had to be hot (not just warm) when you check it. I don't have the manual in front of me, but I seem to recall a 20 minute drive as the way to bring up the temperature.
    Ouch.
    I spent an hour with a turkey baster extracting the overfill.
    No residual damage other than there seemed to be some slight seepage which dried up after the excess oil was removed.
  6. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    Anthony- if it's not a warm or even hot day drive it for even longer than 10 minutes..I'm no expert on what temp it should show on the gauge, but get the oil as hot as you can driving (within reason- I'm not saying you need to go for a 3 hour drive :) ). Even then, aim for no more than the oil level between min and max...on a really hot day with some vivid driving it will expand even more so may as well leave some room! Being between min and max is plenty of oil anyway.... That's also what I shoot for with my 360 and also shot for in prior 911's I owned (which are also dry sump motors that held lots of oil like the 360- no point trying to get all the way up to Max and then have no room for further expansion...)
  7. PFSEX
    PFSEX Formula Junior
    Jun 30, 2006
    843
    Las Vegas
    John Ratto
    did you consider how much oil was in the filter??????
    If you drained the oil properly and you changed the filter - putting in 8 quarts is not enough. Whenever I have had mine changed - and been there watching the tech do the work at Wynn (Dealer), it has always taken about 10 quarts. Always.
    And really - does oil expand that much when it gets hot. I think not. In fact, these high tech multi-viscosity oils claim to get THICKER as they heat up. Getting thicker and also increasing greatly in volume sounds quite impossible to this guy.
    So, run the car up to operating temp...park on level area...leave the engine running - wear a glove or use a rag - it be hot...remove the cap...and wipe the oil...DO NOT screw the cap on - just sit it on the filler neck - (no screwing!)... and pull it off and take your reading...if OK, then you can screw the cap back on...if not, add some oil ...or remove if you really messed up.
  8. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    The filter doesn't hold much oil in it due to the orientation.
    I have tried to explain the importance of the oil level here: Link
  9. av2
    av2 Formula Junior
    May 22, 2008
    478
    S. California
    If you added 8 quarts, it's safe to drive the car and let the engine warm up. For ///M & Porsche cars (equipped with dry sump), it takes about 5 miles of driving to be able to do readings on oil level through the computer. As for oil additives, why would you want to use it? Major motor oils have their own additives in the oil already and there is really no need to add any other aftermarket stuff to it. I am doubtful that you will see any benefits, and there is the risk that you will do more harm than good. I say no.
  10. Bendrover
    Bendrover Karting
    Dec 18, 2005
    189
    Tulsa, OK
    This happen to me when I changed the oil in my Scud. You will have to drive it longer then 10 min. I had to go for a long drive (45 min.) before mine warmed up and showed a reading between the lines. Scared the crap out of me, but I knew I put the right amount of oil in.
    Go for a good spirited drive!
    Later
  11. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    Monitor the oil temp gauge. I like to read oil level when it is at least around 190 F (90 C).
  12. donho
    donho Karting
    Oct 11, 2006
    154
    Naples, FL
    Michael
    The oil needs to be HOT before you check the level. HOT.
  13. fastguy1012
    fastguy1012 Rookie
    Oct 30, 2012
    40
    SO. CAL.
    ANTHONY
    Thank you for your help...I really appreciate your time on my Ferrari issues!
    Well,
    I refilled the engine with a little more oil than I removed.
    I tried just letting it idle for 30 minutes but the dipstick showed oil just at the very lowest tip... So I drove the car for about 45 minutes...up hills...on the freeway...I checked the oil 3 times while out driving...with oil and water temp. at normal operating temps....the oil was still at the bottom of dipstick...I checked it once I got home...still low...I added a little oil...it went up a tiny bit on the dipstick...im close to 9 quarts now...but still at the lowest point on the dipstick...not between the two markings.
    Car is running great! but is it safe to drive? how can I get it between the dipstick markings? By the way...I see no oil bubles, got no exhaust smoke...motor is hot as I lean over it to check oil..again..
    any comments on LUCAS OIL SYNTHETIC ADDITIVE?
    Thanks for any advice!
  14. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    If you are sure you are taking the reading correctly then add some more to get the level half way between the "max" and "min" marks.
  15. Arnie
    Arnie Formula Junior
    Oct 5, 2011
    465
    New Jersey
    I know you probably checked the oil with the engine running correct? The reason it takes so long is because it has a dry sump. Once it warms up a valve opens to the oil tank and all the oil; circulates not just the oil in the engine. As everybody states it takes a while. On my Porsche when the temp. is 40 it takes 15 minutes for the sump to open before I check the oil level. Even longer for my Ferrari be cause of the coolant circulates before the oil .
  16. fastguy1012
    fastguy1012 Rookie
    Oct 30, 2012
    40
    SO. CAL.
    ANTHONY
    Thanks for everyones expertise!
    Yes I did drive the car 30 to 40 minutes...on freeeways too.I checked oil 3 different times during the drive and once upon arriving home.
    The oil level was at the bottom of the dipstick.
    I feel its wierd it is so hard to get a normal reading.
    I KNOW I REPLACED A LITTLE MORE OIL THAN I REMOVED...ABOUT 9 to 9.5 QTS.
    MOTOR WAS HOT! Car ran great!
    Any advice?
  17. fastguy1012
    fastguy1012 Rookie
    Oct 30, 2012
    40
    SO. CAL.
    ANTHONY
    Any advice?
  18. Arnie
    Oct 5, 2011
    465
    New Jersey
    Since the engine is running when checking the oil there is a known foaming issue of the oil which makes it difficult to get a true reading just have to diligent and remove the dip stick slowly.
  19. fastguy1012
    fastguy1012 Rookie
    Oct 30, 2012
    40
    SO. CAL.
    ANTHONY
    THANKS...GOOD ADVICE... ACTUALLY I TAKE IT OUT VERY CAREFULLY....WHAT IS WEIRD IS THAT THERE IS VERY LITTLE OIL RESIDUE ON THE UPPER PORTION OF THE DIPSTICK...BETWEEN THE TWO MARKERS...
    There is only visible oil at the very tip...BUT I know I have enough oil....
    Very confusing! But I will check it again once it is nice and hot...and pull the dipstick out ever so slowly....
    Hope that clears this mystery up!
    I feel like I am the only person who has had this kind of issue...it figures!
  20. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    FWIW my records show that the oil change on my '07 F430 takes 10 qts with a California oil filter. The level then reads about halfway between the marks on the dipstick when the oil is hot (200 F) and after screwing the dipstick cap down before unscrewing it again and withdrawing the stick to read it. I have never checked the oil without screwing the dipstick cap down first and it is possible that it will read low if you do not do so.
  21. fastguy1012
    fastguy1012 Rookie
    Oct 30, 2012
    40
    SO. CAL.
    ANTHONY
    Thanks...I screw cap all the way down each check.
    I remove dipstick slowly....added about 9 to 9.5 quarts of new oil...
    Drove car....30 to 45 minutes...on freeway...hills...
    Motor was hot...checked it about 4 times...oil at very bottom of dipstick...
    Car runs great! Dont want to drive with low oil.....deathly afraid of overfilling!
    What is a guy to do?.....i know it cant be that complicated...
    The oil change itself was a cinch!
  22. Skidkid
    Skidkid F1 Veteran
    9,539
    Campbell, CA
    John Zornes
    You aren't supposed to screw the cap on to take the oil level. It is taken with the cap sitting on the tank.
  23. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    #23 Noblesse Oblige, Dec 23, 2012
    Then reluctantly one must conclude that you are slightly underfilled, possibly due to not fully emptying the oil containers into the tank.
    Suggest a conservative approach of adding 1/2 quart, driving and remeasuring. That should give you a sense of where you are at without overfilling.
  24. Bendrover
    Bendrover Karting
    Dec 18, 2005
    189
    Tulsa, OK
    It's late, and I'm not 100% sure, but I believe it takes 10-10.5 quarts for an oil change. Look in the owners manuel and it will tell you what it takes.
    Later
  25. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    I believe that's right. If so he is running slightly low and will not risk overfilling by adding 1/2 qt to start with and remeasuring.
