Oil drain plug gasket | FerrariChat
Discussion in 'Technical Q&A' started by Vito, Apr 17, 2005.
  1. Vito
    Vito Formula Junior
    473
    Dutchess County, NY
    Does any one know of a ready source & price for the copper crush gasket/washer that is used on the oil pan drain plug for a 1982 308/Mondial motor? I'd like to have several on hand when it's time for oil changes. Also, is this the same gasket/washer that is used for other drain plugs such as the gear box drain? Thanks for your help with this search.
  2. dm_n_stuff
  3. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    RicambiAmerica has them for 58 cents each. Click Here.
  4. Ricambi America
    Sponsor Owner
  5. dm_n_stuff
    #5 dm_n_stuff, Apr 17, 2005
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,448
    San Carlos, CA
    Mitchell Le
    Global metrics, Belmont, CA.
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    BTW, all 3 sumps (oil,trans, & xfer case) all take the same washer: 21mm ID.
    The Stat-O-Seal is a fancy brand name for a fairly common 'sealing washer' or 'O-ring washer'. While metric sizes are scarce, given the large flats on the sump covers & heads, I think a 7/8" sealing washer would work fine.
    Google turned up a lot of hits...
  8. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    My NAPA stocked the Cu washers. Verell, I thought 22mm rather than 21?
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    In antique aircraft, I remember many folks re-annealing copper crush washers by heating them up very high, then flash cooling them in water.
    Would this work for these?
  10. Steve Magnusson
    26,622
    Yes, but the final softness is not significantly dependent on the quench rate for Cu materials -- so water or air cool is OK.
    The key word in your post Russ is "antique". I.e., if I don't have a new one easily available, I'd reanneal myself -- but by the time you hassle with that, and cleaning-up the oxide film, buying a fresh handful from Global Metrics or the odd one or two from any F parts supplier (even for $1 each) seems smarter IMO/E.
    22 mm ID x 27 mm OD x 1.5 mm thick Cu is the "308" engine and gearbox oil size just for other's reference (since it hasn't come up lately, and using "search" seems to be so difficult ;)). I know I wouldn't mind finding an extra 5 or 10 in the toolkit so getting 20~50 at a time from Global Metrics was my ex-MO. The TR is even worse -- more sizes, some difficult sizes, and more places -- so I still shop Global Metrics quite often even from CO.
  11. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    I could see doing this in a pinch but at 1.00 or less, why bother?
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    I could be off a mm, don't have a spec, so used calipers to measure the thread ODs of my plugs & a couple of old washers that I keep around for reference. Definitely measured 21mm.
    Either 21mm or 22mm should work fine as the shoulders are pretty large on both the plug & hole.
    BTW, in a pinch I've just used an o-ring instead of a crush washer & avoided crushing/pinching it by tightening the plug finger tight using a 1/2" drive allen socket. Back then I didn't know the annealing trick. Guess the risk is that the plug might vibrate loose s it isn't torqued down.
