Oil drain plug torque | FerrariChat
Discussion in 'Technical Q&A' started by WaltP, Nov 8, 2006.
  1. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,512
    Cape Canaveral/Atlanta
    Walt P
    Is there a torque value for the drain plug on my 1980 308 and if so what is it? I did a search and went to the Owners Site with no luck.
    Thanks in advance.
  2. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    When I did mine I used 24 ft/bls. Read that in an article that Carl Rose did on 328 oil changes. Would think a 308 would be the same. Used a new copper crush washer and no leaks, that was 1,200 miles ago.
  3. blmjumper
    blmjumper Formula Junior
    Jun 18, 2006
    341
    Boise
    Ty
    24 ft/lbs is what I used on the 328...seemed to be the consensus
  4. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,293
    Colorado
    Dave
    Whatever you do, don't use too much force. The steel plug can pull out the aluminum threads. I also know of one owner who split his oil pan by over tightening. Fortunately, it was not too big a job to get it off and have it welded. People tend to overtighten oil plugs, even dealers. One time I was changing the oil in my wife's Subaru after a dealer had done it before. I had trouble with the plug, so for grins I got out my torque wrench to measure how much force was used---120lbs! Fortunately, this is steel on steel.
    Dave
