Oil Filter and coolant antifreeze change data | FerrariChat
Discussion in '308/328' started by Saabguy, Dec 3, 2021.
  1. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Hi guys, I can't find simple info on this so I am asking:
    Oil capacity with filter change: 10 quarts right?
    Coolant volume ??
    Thanks,
    Lester
  2. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
  3. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    For my car, fluid *change*:
    Coolant: just around 5-5.5 gallons, I believe.
    Oil: 10 quarts will be overfill; refill is closer to 9 qt.
    absostone and Saabguy like this.
  4. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Thank you kind sir, that looks like the factory manual but I could find no such page. Where oh where was it hiding??
  5. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,808
    Cerritos, CA.
    Start with 8.5 quarts of oil and check it from there after you have warmed up or driven the car.
    Thorn is right 10 quarts is too much. You only use 10 quarts if have taken your engine apart or
    After you have rebuilt your engine as in bone dry of oil.
  6. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    But 10 quarts is easy to buy. ;-)
  7. miketuason
    Feb 24, 2006
    15,808
    Cerritos, CA.
    It’s ok to have extra, You can save that and use it for later. When I buy my oil I always order them by the case of 12 quarts, only use what I need and save the rest.
  8. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Yeah, I buy two 5-qt containers. It all gets used eventually.
  9. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    From dry the cooling system holds 5 gallons.
    Saabguy likes this.
