Oil filter for 400i? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by bernadette, Mar 16, 2014.
  1. bernadette
    bernadette Karting
    Mar 6, 2014
    76
    Does anyone know if K&N are OK oil filters and would you know the part number?
  2. Steve Magnusson
    26,786
    Not the best alternative for a 400i -- as the K&N lacks the internal standpipe of the Baldwin B253 (and the Fram PH2804-1, but the Fram has other problems) for an inverted mounting application. JMO -- try a search on "Baldwin standpipe" for more threads.
  3. bernadette
    bernadette Karting
    Mar 6, 2014
    76
    It shows on their site that it has the anti drainback valve?
    K&N HP-3001 - Oil Filters, Oil Filter
    Can you verify?
  4. bernadette
    bernadette Karting
    Mar 6, 2014
    76
    How? about the Fram HP1
  5. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,240
    MA
    Buy Baldwin (very inexpensive) and forget all those others.
  6. bernadette
    bernadette Karting
    Mar 6, 2014
    76
    Where can I buy in Toronto?
  7. Schumi
    Schumi Formula Junior
    Jun 5, 2002
    866
    Missouri
    Daren
  8. Steve Magnusson
    26,786
    #9 Steve Magnusson, Mar 17, 2014
    Almost all modern oil filters have an anti-drainback valve (but the quality of construction varies) -- it's the anti-drainback valve working in conjunction with the internal standpipe that helps trap a larger volume of oil inside the oil filter case after engine shutoff for a longer time. The sketch in post #18 in this thread explains how it works:
    http://www.ferrarichat.com/forum/308-328/293732-using-k-n-hp-3001-oil-filter-308s.html
    It's not like using a more conventional oil filter without the internal standpipe will cause immediate failure, but, if the filters are about the same price, there's technical upside for using an oil filter with an internal standpipe on engines with gasket-end-down oil filter mounting.
    I believe, no internal standpipe.
  9. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,674
    Whats wrong with just using the OEM UFI Filters, readily available from Ricambi / local dealers / Eurospares / Ferrari UK etc etc. ?
    M
  10. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    cost! The Baldwins are $6
  11. Steve Magnusson
    26,786
    +1
    Now that UFI has (correctly) improved the sealing o-ring area on the smaller F oil filter, I'd be happy with either Baldwin or UFI, and go with which on had the lower "cost + hassle-to-get" factor.
  12. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,674
    I recall the UFI sealing issue was a long time ago, like 10 years or so, wasnt it. ?
    M
  13. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,674
    Ok, but that's a drop in the ocean in the overall cost of running a 4xx series car.
    I can get the OEM's for around $38 here, Baldwins are ~ $20 and hard to get.
    M
  14. Ashman
    Sep 5, 2002
    33,240
    MA
    Actually around $15 now but still way less expensive than the UFIs, which I soured on after their sealing ring defect problems several years ago. Never heard a discouraging word about Baldwins and their cost advantage makes it an easy decision for me.
