Oil for 430 | FerrariChat
Oil for 430
Discussion in '360/430' started by roccoriley, Nov 2, 2007.
  1. roccoriley
    roccoriley Karting
    Jun 24, 2007
    230
    So Cal
    The operators manual says to use Shell Helix 5-40 oil. I understand that for topping up, any good synthetic (Mobile 1) would be fine. Is this correct? What do you use? Is Helix available in San Diego?
  2. f355spider
    f355spider F1 World Champ
    18,047
    You can get the Shell Ultra Helix at any Ferrari dealer and also some independant Ferrari repair shops. You can top up with Mobil 1 0w-40...but it would be preferable to stick with what is already in there. Be sure you read the manual and that you are checking the level correctly. (check when hot, and right after shutting off the motor)
  3. kerns577
    kerns577 Karting
    Oct 21, 2007
    89
    Sarasota Florida
    Sean Kerns
    Your 430 is most likely still under warranty.
    Your engine warranty should state something to the effect that if you use any oil other than Shell Helix in your engine, you will void the warranty.
    This warranty covers only the first two years, and unlimited mileage. There are extended warranties of an additioanl year through Ferrari participating dealerships, (so I hear)
    After the first two years, Mobil I, or Royal purple are fine.
    The only other place to find Shell Helix outside of a Ferrari authorized dealership is Ricambi, that I'm aware of. For uite sometime Shell Helix was sold at the dealerships for as much as 30.00/ quart! I don't believe this the case anymore, and I knwo it's less than that at Ricambi
    Sean
  4. Tarek K.
    Tarek K. F1 World Champ
    10,798
    Cairo - Egypt
    Tarek K.
    Wrong.........check oil level when hot while engine is running at idle speed, just after the radiator cooling fans come on.
  5. Ricambi America
    Sponsor Owner
    #5 Ricambi America, Nov 4, 2007
