oil gauge 'wacko' after oil change! | FerrariChat
Discussion in '308/328' started by carb308vt, Aug 15, 2006.
  1. carb308vt
    carb308vt Karting
    Apr 12, 2005
    122
    NYC/Vermont
    Craig M
    Just got my oil changed and new spark plugs, idle jets cleaned at my sevice shop. Have never ever had a problem with the gauge-always 80lbs at speed (or pointing in the middle straight down)
    Now gauge is bouncing around and even stays pegged while driving over to "0". Red light does not come on though and I am assuming that it's just a faulty reading. What could have happened during the oil change that could have caused this? Please help. Thanks
  2. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    I believe the oil pressure sensor is located next to the oil filter, I suspect the wire from the oil pressure sensor is loose.
  3. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
  4. Jdubbya
    Jdubbya The $10 Trillion Man
    43,182
    PNW
    Make sure they didn't drain the gearbox and overfill the oil!
  5. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Good idea, it may have been bumped off/loose when they did the oil change. :) Although Ferrari are reknowned for poor quality gauges, maybe it is at fault and this oil change is coincidental. :p
  6. Jdubbya
    43,182
    PNW
    Any update?
  7. carb308vt
    carb308vt Karting
    Apr 12, 2005
    122
    NYC/Vermont
    Craig M
    I went ahead and took the car on a 400 mile vacation this weekend. Interestingly enough, when the car starts-the gauge is fine, it is only when its in gear that the problem starts. i'm taking her in on Friday to the shop and will post update. Thanks to everyone for submitting replies and good advice. cheers
