News
Oil in Air Wrench
Discussion in 'Technical Q&A' started by UroTrash, Aug 8, 2009.
  1. UroTrash
    UroTrash Three Time F1 World Champ
    Jan 20, 2004
    33,785
    Purgatory
    Internet Poseur
    Easy question.
    what oil do you put in your air wrenches?
    I've used the oil that I have for my air nailers and I've used "3-1" but the wrench spits oil on my car wheel when I'm shooting the lugs off..
  3. Rifledriver
    Rifledriver Two Time F1 World Champ
    27,139
    Austin TX
    Air tool oil is good, so is Marvel Mystery oil. They will all spit out the exhaust port after oiling. I hold a rag over the exhaust port and hold the trigger wide open for about 5 seconds after oiling. That will get about 95 % of it.
  4. the_stig
    the_stig F1 Rookie
    3,360
    Ummm, I use whatever they had next to the air tools when I bought them... sorry, there is nothing on it about viscosity or much else. Sorry.
  5. UroTrash
    Jan 20, 2004
    33,785
    Purgatory
    Internet Poseur
    Thanks guys. Maybe I'm just a bit of a neurotic hyper-oiler.
  6. dm_n_stuff
    dm_n_stuff Global Moderator
    Global Moderator Lifetime Rossa Owner
    Dec 10, 2003
    36,883
    Babcock Ranch, FL
    Dave
    Nah, you? Neurotic?? Never.
    And you DAMN well better not be using that gun on MY FRIGGIN' DINO LUGS!!!
    And at work, we use whatever came with the tools. I can check for ya, if you promise not to use it on the Dino.
    DM
  8. flipdowt
    flipdowt Karting
    Dec 13, 2008
    204
    Mahopac,New York
    John Flip
    marvel mystery oil for me also. make sure you have a drier on your line, this can also cause a problem with some moisture mixing with the few drops of oil that you drip into the fitting before use.
  9. UroTrash
    Jan 20, 2004
    33,785
    Purgatory
    Internet Poseur
    Um......no, this air wrench is only for Swedish and Japanese applications.
  10. beast
    beast F1 Veteran
    May 31, 2003
    8,965
    Lewisville, TX
    Rob Guess
    MM Oil or Mac air tool oil has been my choice for years. I have a 1/2" impact gun that is over 20 years old now and still going strong without a rebuild.
  11. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    +1.
  13. miketuason
    miketuason F1 World Champ
    Silver Subscribed Owner
    Feb 24, 2006
    14,305
    Cerritos, CA.
    Air tool oil from Sears or home depot is good.
    Also add an oil/water separetor.
  14. fastradio
    fastradio F1 Rookie
    Professional Ferrari Technician BANNED
    Apr 26, 2006
    3,652
    New England
    David Feinberg
    Same here...And after a good lube job, my air impact wrench seems to have much more "break away" torque for those pesky "Dealer-installed to specs" Audi lug bolts.
  15. beast
    beast F1 Veteran
    May 31, 2003
    8,965
    Lewisville, TX
    Rob Guess
    This is correct as the oil is forming a liquid seal of the vanes to the housing. Same concept of squirting some oil into the spark plug hole of an engine that has low compression. If the copression goes up it points to the rings as the oil is helping them to seal to the cylinder walls,
