Oil leak developed from not being driven. Help identify. | Page 2 | FerrariChat
Discussion in '348/355' started by Eric C, Feb 25, 2015.
  1. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    #26 Eric C, Feb 25, 2015
  2. Eric C
    11,136
    St. Louis, MO
    Eric
    Crap. Upside down pic!
  3. WATSON
    23,934
    WI
    #28 WATSON, Feb 25, 2015
  4. phrogs
    phrogs F1 Veteran
    7,359
    Kzoo Michigan
    #29 phrogs, Feb 25, 2015
    Yes it has, and it apears it's more from the line and not the union.
    The Pic is of the gasket/washer from the Union to oil pan. This gasket is not between the hose and union/fitting connection, there isn't a gasket between the hose and union.
  5. GTSNJ
    GTSNJ Formula Junior
    Jan 18, 2015
    478
    You can get that fitting off with a huge vice grip wrapped in a soft cloth it won't mar it at all.
    I don't remember a gasket ever being present when I removed mine. That looks like oil is wicking downward pull back the sheathing and check integrity of the end crimp.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    That is a leaking oil line..Take care of that soon.
    The line goes into a compression fitting, which screws into the oil tank. That gasket is between the fitting and the tank.
  7. Eric C
    11,136
    St. Louis, MO
    Eric
    So, the line itself is leaking. Got it. So, is there a company that rebuilds these? Just looking around on ebay, I can't believe what people are selling a hose w/ 2 fittings for. Geez.
  8. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,919
    Richmond
    Pete
    If you can find a good hydraulic shop, they may be able to do it.
  9. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Eric I have an outfit that may be able to.
  10. Eric C
    11,136
    St. Louis, MO
    Eric
    I'll take any leads you guys can give. If I can mail it out, the better.
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
  12. yelcab
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    A myth. They don't in the SF area.
  13. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Any luck with those guys Eric?
  14. ready321now
    ready321now Formula Junior
    Jan 5, 2013
    503
    New Jersey
    Same here! same leak, same situation. The car sat for a month, then the leak. but WHY would the oil leak be MUCH DARKER OIL than my other leaks???? Perhaps old oil stuck in there at the leak point? Now the leak has the same color as my other leak(s).
  15. Eric C
    11,136
    St. Louis, MO
    Eric
    Backed it off half a turn, tightened it an extra 1/8 turn. Bone dry after a 10 mile drive.
  16. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,757
    Boston, MA
    John E. Kenney
    Excellent! My tank had a crack at the small pipe with fitting. Shop welded it and saved me more than a grand!
  17. GTSNJ
    Jan 18, 2015
    478
    Very good tightening worked. Keep an eye on it in a few months. Its not like it will explode instantly if there was a leak on the hose.
    Alot of these cars weep and drip when not used. I keep mine in a heated garage. Let any car sit outside in the cold enough and you have potential to see a nice lil puddle until you start using it again!
    Apparently f1 is notorious for this but mine never gave the actuator leak luckily.
  18. John_K_348
    Sep 20, 2013
    2,757
    Boston, MA
    John E. Kenney
    Guess what? Starting my first solo oil change and tank pipe is bone dry. BUT I found oil on fittings under the engine near the pressure bolt cover bolt. That was kinda chewed up too but not bad. For 2 years I have seen NO oil stains on the ground. When I did the shift cable last year after the major I don't remember it being oily. Also, tank was bone dry even while running on 2 short warms up! Yikes, I let it go after the major. Pressure and engine temp were fine all along but oil temp as still on the peg just then. Not sure it was hot enough. Stick was oily but not coated at first. Stayed dry after wiping. I have the 12mm allen socket on order but will make due with my close matching T120 torque socket. The star matched the hex and with one wrap of fireproof aluminum tape it fits snug in the bolt. I hope it will take 30 ft lbs required. Also got a filter universal strap wrench set. So many fiddly frustrations but I WILL get this done.
  19. ready321now
    Jan 5, 2013
    503
    New Jersey
    My cold weather leaks have cleared up a bit. January? Drips of oil. APRIL? A LOT LESS.
