oil leak from bell housing 348 | FerrariChat
Discussion in 'Technical Q&A' started by tallzim, May 3, 2012.
  1. tallzim
    tallzim Rookie
    May 3, 2012
    17
    montreal quebec cana
    denis bissonnette
    oil leak from bellhousing 348 where it come from? thanks to reply i m new in your world .
  2. Ricambi America
    Sponsor Owner
    Do you mean the fluid is coming from the drilled inspection plate, or someplace else?
  3. tallzim
    tallzim Rookie
    May 3, 2012
    17
    denis bissonnette
    yes all around
  4. Ricambi America
    Sponsor Owner
    Fluid is leaking from every seam, joint, and inspection plate on the entire bellhousing? :eek:
    Maybe a picture would help? Is it gear oil? Hydraulic fluid? flywheel grease?
  5. tallzim
    tallzim Rookie
    May 3, 2012
    17
    denis bissonnette
    only in the inspection plate its not grease but light fluid thanks again to help me
  6. SEAN@TEAM AI
    SEAN@TEAM AI Karting
    Sponsor
    Sep 22, 2006
    201
    Charlotte, NC
    Sean Smith
    #6 SEAN@TEAM AI, May 3, 2012
    Denis
    If you can check your fluid levels. Transaxle, brake fluid resvoir. Is one low on fluid? Have you been checking them on a regular basis? This can help you determine what is leaking. A man much wiser than me taught me how to use a small amount of water on a leak to distinguish brake fluid from oil or gear oil. Brake fluid will dissolve quickly when sprayed lightly with water. Oil gear oil will not.
    The area of your leak is Very common on your car. It can be a few things. Gear oil by the tripple seals from the gear box. Possibly mixed with klubber grease from the flywheel, or brake fluid leaking from the Clutch release bearing or flange.
    Diagnosis is everything.
    I would highly suggest you use parts from Daniel at Ricambi. He has the best parts (Hill Engineering) for fluid leaks on your car.
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    If it's oil, then the seals in the throw out bearing are probably shot. That's my best guess. Run a search of the archives for the how-to on the seal replacement.
  8. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,728
    The throwout bearing is leaking, the fluid is brake fluid from the shared brake/clutch reservoir.
  9. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    D'OH!!
    Good catch Mitch. I used the wrong word, not oil but BREAK FLUID.
  10. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    You used the wrong spelling too! :eek::eek:
  11. fdekeu
    fdekeu Formula Junior
    631
    Belzium
    Frank
    So if it is leaking brake fluid then the throw out bearing needs to be replaced?
    Just asking because mine is also leaking a few drops under the inspection plate I noticed yesterday
    Is it wise to drive??
  12. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    AH! DANG IT!
    Yes, yes I did.
  13. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    In my opinion no.
    You can replace the seal in the throw out bearing to fix the leak.
    The throw out bearing would need to be replaced if the casting blows out. If yours isn't blown then no need to replace it.
  14. tallzim
    tallzim Rookie
    May 3, 2012
    17
    denis bissonnette
    ho thanks, for all the answers, i check today, and the oil pass throw the plate..... and i put a little bit oil on my top finger ,and it came down fast..... i put a white paper under it and the oil look, light green. amasing thanks to every body for answers and if its fuild brake what i have do, take of the bell housing all the problems come from the inside it is a big job? tallzim....
  15. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
  16. fdekeu
    631
    Belzium
    Frank
