Oil leak | FerrariChat
Oil leak
Discussion in '365 GT4 2+2/400/412' started by Part Time, Jul 3, 2014.
  1. Part Time
    Part Time Formula Junior
    500
    Port St. Lucie, Fl
    Gary Shore
    #1 Part Time, Jul 3, 2014
    To anyone in general......the oil switch ahead of the oil filters....is it the "oil light switch" or the "fuel pump safety shutoff switch" ? I believe the oil gage sender is at the rear of the block. Anyone have a part number or even better a supplier or alternate fitment ?
    Thanks....mine is leaking.
    Gary
  2. DaveO_48
    DaveO_48 Karting
    Jul 29, 2013
    184
    Henderson, Nv
    David Odland
    Search part # 110664 on F-Chat. It's a part used on other European cars available easily.
    Good luck with the leak repair.
  3. Zanny1
    Zanny1 Formula 3
    1,134
    Arizona
    Gary, on the C/4 the oil pressure sender is at the rear of the block.
    You could always disconnect the switch pictured and see what shows on your instrument panel.
  4. Part Time
    500
    Port St. Lucie, Fl
    Gary Shore
    Thanks, guys...searching other thread entries the switch seems to be the Fuel Pump Safety unit, I will check with my local vendors first before buying one from Superformance in the UK, it looks to be a common unit for several vehicles.
    Thanks, Gary
