Oil Leak | FerrariChat
Oil Leak
Discussion in '308/328' started by Aimhii, Apr 22, 2019.
  1. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    Hi Guys:
    Just picked up car from heated storage today......Had oil changed just prior to storage.
    Drove it home today and noticed a bit of blue smoke and smell being me. Pulled over found some oil underneath filler cap...thinking it was loose. It wasn't so i wiped all i could reach and noticed more dripping around the belt area and down to floor.
    Any idea where it may be coming from?
    Checked level and seems normal, and still dripping. Wondering if its a seal....but afraid which one?
  2. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    405
    PA
    Alex
    Smoke/mess on first drive after an oil change could mean it was overfilled. You said the level was ok... was it checked using the owner's manual procedure? (Warm engine, 15 minutes after shutting off...)
  3. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    yup - absolutely
    Then let it cool and drop another hour and pretty sig drips
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    How long did the car sit in the storage before you drove it home today?
  5. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    About 4-5 months
    miketuason likes this.
  6. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    cam drive? Was it in my case with similar symptoms. Also after a longer winter storage.
    Best Regards
    Martin
  7. Alex308qv
    Jul 1, 2016
    405
    PA
    Alex
    Mine did not leak that much, but odor and some smoke wafting out the right engine cover vent was from (1) improperly installed front bank cam cover seals, and (2) worn main oil seal. Drips in that area can land on the exhaust manifold causing the smoke. If not run for 4-5 months maybe the main seal dried and "stuck" to the crank and was damaged upon restarting? Remove fender liner and you probably can spot the issue.
  8. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Some UV dye might be helpful.
  9. miketuason
    Feb 24, 2006
    15,811
    Cerritos, CA.
    Luba, just to make sure, the blue smoke you saw is not coming from the exhaust while the engine is running, rather, it’s coming from the engine bay, correct?
  10. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    Hi Guys - thanks again
    Oil not coming from exhaust but do see something dripping from behind the belts on the exhaust - if it’s a can seal or main seal - is that an engine out repair?
  11. Rifledriver
    37,106
    Find the source before formulating a course of action.
    waymar likes this.
  12. Alfer
    Alfer Formula 3
    1,360
    NH/the Netherlands
    Menno
    Please check the oil level as mentioned above it could be overfilled especially if the oil change is done by no expert of this type car who might have swiched the sumps of gearbox and motor. The logic choice for no experts is to remove the plug from the gearbox.
    This would mean the gearbox is out of oil!
  13. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    Cam seals are not an engine out procedure but also not a procedure that is viable as a stand alone, meaning you'd have to seriously consider valve clearances, belts and tensioner bearings while you are in there. It's not a matter of just popping the covers off, there are four seals up front plus the four o-rings for the seal carriers and three seals at the back end. There is also a fiddly bit of sealant required where the split cover gaskets abut to the carrier seal o-rings.
    You have to weigh all of those factors in deciding how much of an oil leak you are willing to live with at least for an interim but, as noted, first determine just exactly what the source is. This in itself can be a task, UV dye is very good at aiding with it. You don't have to clean anything up prior just add it to the oil, run the engine and watch with the light where it appears.
  14. Alex308qv
    Jul 1, 2016
    405
    PA
    Alex
    Not at all. Engine in. And, if you're due for timing belts, take care of these seals and check on the water pump while in that area of the motor.
  15. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    Thanks - Will do......Just not sure I'm ready for the news...Just got the car last year and was all checked fine and good!
  16. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Do not start taking things apart until you've identified where the leak is coming from.
  17. Martin308GTB
    Jan 22, 2003
    4,259
    Martin N.
    #17 Martin308GTB, Apr 23, 2019
    Are the belts wet on the inner toothed side? Can you see the belts or does your car have cam cover back covers? One of mine was dripping wet, when one of my cam drive seals failed. And I mean cam-drive seals not cam seals. Want to say, the lower ones for the drive pulleys right and left next to the main seal.
    What year is your car? There are different cam drive designs regarding seal and bearing layout. The earlier design was more prone to failing bearings, which also contributed to leaking seals. A seal in front of a wiggling bearing can't seal any more.
    A leaking cam seal (the upper) should be easy to diagnose.
    Best from Germany
    Martin
  18. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    Thanks Martin....Yes it has rocker covers. From what I can see it is wet in behind there on the belts. So I am assuming it has to be one of those seals. I hope I can drive 100km to get it to my guy to look at it. Oil level seems ok - not over filled and in between dipstick lines
  19. Martin308GTB
    Jan 22, 2003
    4,259
    Martin N.
    #19 Martin308GTB, Apr 24, 2019
    I think after 23 years of ownership I got less paranoid about my car. Nevertheless I would not drive 100kms, because you told, that your problem creates smoke coming from the engine compartment.
    If it is actually a cam drive seal leaking so bad, that it drips, it creates a spray of oil all over the engine compartment... and the exhaust.
    To make a long story short. My workshop was 160kms distant and I had my car flatbeded. It was 20 years ago, but would do it again that way.
    But please don't rely solely on my theory. It's just based on my experience, which showed very similar symptoms though. Maybe it's still a different leak source. But smoke from the engine compartment means oil spraying or dripping onto the exhaust and would prevent me from driving longer distances.
    Best from Germany
    Martin
    Rifledriver likes this.
  20. Rifledriver
    37,106
    Oil can catch fire.
  21. Martin308GTB
    Jan 22, 2003
    4,259
    Martin N.
    Thanks for this addition Brian. I actually thought, it wouldn't be necessary to mention it.
    Best
    Martin
