oil level on a 328 | FerrariChat
oil level on a 328
Discussion in 'Technical Q&A' started by Rod, Feb 8, 2009.
  1. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Sounds like a daft question but checking the oil level on a 328. is it done with the engine switched off? my porsche was a dry sump so always checked with the engine running!
    Thanks in advance
  2. bill brooks
    bill brooks F1 Veteran
    6,081
    waynesburg,pa
    bill brooks
    you should consult your owner's manual in situations such as this.
    if you don't have one, consider purchasing one.
    it contains invaluable information on your car.
    let your engine cool for 15min. read the dipstick and make sure the oil level is at/near the topmost mark.
  3. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Thanks Bill..
  4. EP328
    EP328 Formula Junior
    622
    Northern California
    Ed
    echo Bill's recommendation. The manual for my '86 says that after engine / oil at normal operating temp, shut off and let cool for 15 minutes then read. Vastly different readings if you wait to engine is "cold."
  5. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,861
    Where wife tells me
    Sam
    I usually check right after shutoff and then around ten-fifteen minutes.
  6. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Sam
    Do you get much of a difference in the reading?
    Rod
  7. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,284
    Illinois
    Yes, can be a very big difference. For example, right after shutoff, mine shows no oil on the dip stick. After 2 minutes I have about 1/4 of an inch showing on the dip stick tip. At 10 minutes, the oil is above the bottom "low level" mark and at 15 minutes, the oil is at the top level mark.
  8. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,557
    NY/SC
    David
    I'm not Sam but I ran two tests for checking on my 328. Checked every 5' for 20' after a drive, and from immediately after shutdown to 15' I saw about a quarter difference.
  9. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    So is the true measurement after 15 minutes? Ie this is howmuch you have in the sump? I am assuming after 5 mins the oil is still around the engine so you end up not getting a true indication?
  10. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    More oil after 15 mins yes? and this is the true measurement?
    UOTE=ducowti;138406108]I'm not Sam but I ran two tests for checking on my 328. Checked every 5' for 20' after a drive, and from immediately after shutdown to 15' I saw about a quarter difference.[/QUOTE]
  11. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,557
    NY/SC
    David
    Right, more at 15'.
  12. JohnnyS
    Oct 19, 2006
    15,284
    Illinois
    Yes, higher level after 15 minutes. If I check the oil after the car sits over night, the oil is about 2 inches above the upper oil level mark.
  13. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    #13 Paul_308, Feb 10, 2009
  14. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    It'd be interesting to see where all the oil sits if the graph is a true representation. There are few possibilities, and there is an awful lot of oil in that wet-sump. Flow back from the heads must be extremely slow, but how many liters can hide in there?
    It would also explain the surge in long right hand corners, as there is very little left in the sump to suck up.
    It must be a marginal thing, as over-filling the sump with 1 litre at first cold measurement cures the surge.
  15. Rifledriver
    37,288
    Most of the drain back comes from the oil cooler and plumbing, oil filter and main oil gallery. The heads retain very little.
  16. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Ah yes, I forgot about the oil-cooler.
    Still, it;s a lot of oil 'hanging in mid air', and I find I more or less consequently overfill by at least half a litre, when goinbg to the track by a litre, and I haven't experienced surge, nor am I able to detect any other negative effects.
    Would love to dry-sump it and forget about the whole problem.
  17. Gerry328
    Gerry328 F1 Rookie
    2,514
    Home
    Gerry
    Very impressive, not only identifing the issue, but producing a graph. Way cool!
  18. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Well... Just rechecked the oil levels...
    Before started and cold the oil level is just over the min mark by about 2mil?
    Heated engine up to temp... turned off and checked the level immediately... Zero reading! ouch...
    5 mins later... oil registered at the end of the dipstick. about 2mil
    after 10mins... half way between end and min mark..
    15 mins.. almost at the min mark!
    20 mins.. just over the min mark again by 2 mils...
    So it reads just above min level mark when cold... I guess that I need a top up, would It be doing any harm as is?
  19. JohnnyS
    Oct 19, 2006
    15,284
    Illinois
    It could but I think any harm was probably very minimal if any at all unless you were tracking the car. So I wouldn't worry about it. In my owner's manual, it states: the oil should read between the marks 15 minutes after the engine was turned off. I stick to what the manual states.
  20. Glassman
    Glassman F1 World Champ
    At 15 minutes you are at the min. mark. So add a little bit of oil and try it again.
  21. Rifledriver
    37,288
    328 has a bad reputation for starving in RH turns. If my oil is a little low it is pretty common to see zero pressure on a freeway cloverleaf.
    Do not let it get low.
  22. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    ok...
    after 15-20 mins the level was about 3ml below the min mark, I topped up with approx 1.8ltres... Now after 15-20mins the reading is approx 3mils over the max mark.. Dor!!!
    Too much or ok would you say?
    Oil pressure sits just over the 85mark at 80plus MPH...
  23. DGS
    DGS Seven Time F1 World Champ
    72,853
    MidTN
    DGS
    #23 DGS, Feb 21, 2009
    The oil pickup was changed via service bulletin to deal with the starvation issue.
    But, for a little perspective: The 328 holds almost three *gallons* of oil.
    On most Italians the "min" mark is two liters below max.
    Measuring oil to the milliliter isn't all that significant.
  24. Rifledriver
    37,288
    Typical Ferrari fix. Didn't fix anything. They still starve in right hand turns and still blow up.
    The "Fix" was the 348 oiling system.
  25. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Thanks...
    Any areas to keep an eye on?
