Oil level | FerrariChat
Oil level
Discussion in '206/246' started by Bobj, Oct 5, 2014.
  1. Bobj
    Bobj Formula Junior
    Aug 12, 2013
    486
    Sorry if this has already been discussed but what is the correct process for checking the oil on a 246 gts?
    Mine looks a bit high when cold. Prob about 1cm above the max. Is this likely to be a problem? I've probably done 300-400 miles in it since it was filled at service (not by me) - I was just checking to see if it was down on oil - obviously not!
  2. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    That seems high, Bobj.
    Andy
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Full is the top mark when warmed up. Looks like you're a bit above it.
    If you've gone 300 miles without a problem, it's probably not a problem.
  4. Edward 96GTS
    Edward 96GTS F1 World Champ
    BANNED Silver Subscribed
    Nov 1, 2003
    11,097
    remeasure after warm.
  5. Glassman
    Glassman F1 World Champ
    I would suggest reading the owners manual and following the suggested procedure for checking the oil. That will confirm if the car is overfilled.
  6. Bobj
    Bobj Formula Junior
    Aug 12, 2013
    486
    I don't have one of these?
    Is there a copy on line or failing that would anyone be able to tell me what is says?
    Will check when warm, thanks for the posts
  7. abstamaria
    Feb 11, 2006
    2,668
    Andres
    Bobj, I'm away now and can't check the manual. However, I think what is important is that the oil be allowed to drain into the pan. That means not measuring right after shutting off. I would want 10 minutes. Anytime after that, the temperature of the oil shouldn't matter.
  8. simonc
    simonc Formula Junior
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    You can download an owners manual from this link All Ferraris towards the bottom of the page
  9. Bobj
    Bobj Formula Junior
    Aug 12, 2013
    486
    That's a great site! Thanks for that!
    Doesn't seem to say so I guess it's fine to check it cold in which case I guess I need to drain a little
    Can't believe how much maintenance the car needs... Looking at this book it looks like a full time job if you were to do it yourself!
  10. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    Oil does expand when hot especially when you consider the almost 9 litres the system takes this expansion does have value. I check the oil when the car is up to temperature and immediately after shut down. Oil in the engine drains to the bottom almost instantly but the oil cooler takes much longer to drain which is why a cold check can yield an abnormally high reading.
  11. Bobj
    Bobj Formula Junior
    Aug 12, 2013
    486
    ok thanks, that helps, will definitely check it warm before I drain anything then
  12. abstamaria
    Feb 11, 2006
    2,668
    Andres
    l believe you're right, Nuvolari, regarding warm oil. l suppose the question really is what the dipstick is marked for. Ferrari tended to say ''warm" but most of the rest of the world specify ''cold." I must read the manual. In any event, Bob's high reading when cold seems to indicate a slight overfilling.
  13. Glassman
    If you need to suck some oil out there is an easy way. Get some clear plastic tubing that fits down the oil dipstick tube. Save an old pump from a bottle of shampoo. Attach the tubing to the pump and you can suck a bit out at a time till you are happy. This is providing you do not have a dry sump.
  14. abstamaria
    Feb 11, 2006
    2,668
    Andres
    Good idea, Glassman. l have one af those special.purpose pumps for draining through the dipstick hole (handy for boats), but yours should work as well.
    Bobj's query wasn't a simple one, it seems. It will be good to pour in the prescribed (8 liters?) of oil, check the dipstick 1. cold, 2 hot immediately after shutting off, and 3 hot I5 minutes after. And compare.
    l just serviced the Stratos and wish I Kept track of the quantity poured in (Redline comes in quarts , and I didn't convert to liters).
    Andy
  15. abstamaria
    Feb 11, 2006
    2,668
    Andres
    #15 abstamaria, Oct 10, 2014
  16. abstamaria
    Feb 11, 2006
    2,668
    Andres
    It seems then that, at least here in the tropics, it doesn't really matter when to measure oil.
    To be perfectly sure, the best procedure would be to pour in the recommended volume of oil and then measure. The most consistent result should IMO be 10 minutes after shutdown - oil has flowed down, and the temperature is consistent.
  17. racerboy9
    racerboy9 F1 Rookie
    2,651
    "To be perfectly sure, the best procedure would be to pour in the recommended volume of oil and then measure."
    This is what Dennis McCann told me years ago. He said the dipsticks weren't always correct.
