Oil levels on the TR | FerrariChat
Discussion in 'Technical Q&A' started by MS250, Aug 20, 2004.
  1. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,571
    Avvocato
    If covered before I apologize, wondering on the oil level of my TR, I check it every 1,000k and add if needed. Question is at times when I check I notice it is below the Min level and then add my 1 to 1.5 quart to top up, is there any harm being done if it runs on Min or under for awhile. On the 348 memebers were talking about sometimes over the max with no harm being done.Feedback to this please.
    Thanks.
  2. Steve Magnusson
    26,785
    No worries IMO for just rational street GT use -- as long as the oil that's entering the engine from the pump is clean and at the right pressure and temperature it doesn't know that the total volume held is 14 quarts and not 16. I actually run a few quarts low in the winter just to get it to heat up more quickly on my short commute (I'm resisting doing a project to add a thermostat valve to bypass the oil cooler, but it could use one). Look at a 300HP Mustang -- it's only got 5~6 quarts of oil total when it's full. The only reason for the big oil capacity is sustained use at very high power output to keep the oil temp in bounds. Just my 2 cents...
  3. vlamgat
    vlamgat Formula Junior
    Jan 9, 2004
    776
    I am not sure that what you are suggesting makes sense. Firstly it depends on whether we are talking dry sump or wet sump. My understanding of the difference is that in the latter the oil always ends up in a catch tank, the sump, where a sperate pick up repumps it into the engine. That pick up must be immeresed at all times or the pressure will drop, cavitation may ensue and lubrication will cease until the flow is resored.
    On the dry sump, the pump is recirculating the oil through a sealed system and requires a minimum level before which the pump will be sucking air. Leaving oil out of that system should not make much difference to pressure or temperature until the pump is sucking on nothing but air whereupon you get no pressure and high temps, even if momentarily. With that said, I think the oil aggregates in smaller pools around the system as opposed to being a solid flow (as the water in a swimming pool might filtration system might look in a diagram) so a reduction in oil quantity would quickly reduce those pools to the point that even centrigugal force would leave you without lubrication.
    Aircraft engines are usually dry sump and oil levels below minimum spells potential disaster.
  4. colo348
    colo348 Karting
    Nov 1, 2003
    143
    Colorado
    Jim
    Big Red,
    When you check the oil level are you letting your TR warm up to the factory recommended oil temperature? Correct temp should be around 145-158 degs. (see your owners manual) before checking. Once the car has reached this temp. turn engine off, take out the dip stick and check. I find that after 600 miles of normal driving (normal Ferrari driving) I have to add about 1/2 quart of oil. If you drive yours harder then may be more.
    If the engine is cold then the oil level will be incorrect and you might add too much oil. If the oil is below the min line once the engine has reached the oil check temp then I would think you could damage the engine.
    Good luck,
    Jim
  5. Rifledriver
    37,090
    Don't go below the minimum mark. I have experienced even dry sump Ferrari's starve for oil in high G turns (freeway cloverleaf ramps) with a complete loss of oil pressure for a few seconds when they are not too much below the min. mark.
  6. MS250
    Dec 10, 2003
    26,571
    Avvocato
    I do check as per manual, car warmed up and then check, also check when engine is running and hot. As for dry sump in the car not sure. DOes anyone here know what the 86TR is ? I usually add about 1 litre of oil for top up a season after doing about 3,000kms, it does not burn much at all. Not nearly as much as the manual says or others of fcars Ive talked too. On average I usually have the oil marked inbetween the min and max.This time when I checked it was below the min. Added a litre and drove it this morning and closer to the min mark. Gonna change oils soon for service. Just wandering if you run them below min, not pushing hard if there is any potential for any kind of damage anywhere.
  7. Rifledriver
    37,090
    If you read the owners manual it says to check a few seconds AFTER turning off the motor. This is very important. It is a dry sump car and on many of them the return hose sprays the oil dipstick so an accurate reading is not possible with the motor running. Also note it does not say with the motor warmed up but with the oil warmed up, an important distinction. It takes much longer for the oil to warm than the water. Oil expands greatly and an accurate reading cannot take place until that expansion has taken place.
    Ferrari put those max and min marks on there for a reason, don't second guess them, just follow their recommendations. Oil is cheap, motors are not.
  8. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,948
    The Cold North
    Tom
    Rick.... Your car is a dry sump engine. By doing just regular driving around and the occational high speed run will not damage the engine if you find the oil at the minuim mark on the stick. That is why it is stamped minimum. In other words Ferrari has determined that your car is safe to run at this level under normal driving conditions. If it drops a little below that mark it's not a big deal either. But if you pull the stick and it reads no oil then you may have a problem.
    As far as checking the oil in your car,do as suggested in the owner manuel..engine at operating temp (usually I go by one cycle of the cooling fans..comming on then going off) You can shut the car down to check it,but I have been told my numerous Ferrari trained techs that the best and most accurate way to check the level is with the enigne running. They told me that Ferrari tells people to shut the eninge off before checking,due to saftey concerns for the client who bought the car. Ferrari does not want a law suit because some careless soul stuck his finger in a moving part.
    In other words nothing to worry about. Just keep doing as you do and you will be just fine.
  9. Rifledriver
    37,090
    Actually that is not Ferrari policy, as I noted before on many, many Ferrari dry sump motors the return line sprays directly on the oil dip stick and on others it causes so much turbulance in the tank that a correct oil level reading is not possible. I too have been factory trained and with many years of experience and Ferrari was always adamant about it, check it with the motor off. On the 360 They were equally adamant about it, it is supposed to be checked with the motor running. It has nothing to do with liability, it is the method Ferrari dertermined was a repeatable accurate method for that particular oiling system when the car was designed.
  10. MS250
    Dec 10, 2003
    26,571
    Avvocato
    Thanks to all for the advice, I have done it both ways, and it was mon either way,actually alittle lower than Min with the engine of after a warm up. I added a 1litre this afternoon and looks like its in the middle of min and max. A little less tan half(closer min) when engine is off. Either way, is there any damage that one must worry about if used at the min mark ?
    Thanks for the help !!
  11. John Dillinger
    John Dillinger Karting
    Nov 13, 2003
    68
    Clearwater Florida
    what if you run at or above max - will that do any harm ??????
  12. MS250
    Dec 10, 2003
    26,571
    Avvocato
    Apparently Max, or a touch over max is fine without damage. Hence the word a touch over max.
  13. benjet
    benjet Formula 3
    Jan 14, 2001
    1,217
    San Francisco, CA
    Ben Lobenstein
    Someone (PO) over oiled my TR (not sure what levels they were at) but there was oil in the blow-by, intake runners and the air measurement plates. It wasn't pretty.
    Less is more.
    -Ben
  14. John Dillinger
    Nov 13, 2003
    68
    Clearwater Florida
    but did it do any other damage besides cause a mess ?
