Oil lights fault F430 | FerrariChat
Discussion in '360/430' started by ralphuk, Apr 19, 2012.
  1. ralphuk
    ralphuk Rookie
    Nov 14, 2011
    25
    Cambridge
    Ralph
    When I drive the car a F430 the oil temp light comes on and shotts to the red and oil presure drops to zero. The a few seconds later reverts to normal. I am guessing it is a lose connection as the tempture wouldnt drop by 50 degrees in 2 seconds. Any ideas ?
  2. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    I would be concerned with this condition. I would advise not driving the vehicle until this is sorted out. This is because although you are correct that this is likely an indication issue, not an oil pressure issue, the risk of driving without oil pressure is too high.
    I do not know what the oil temp would report if hot oil stopped flowing. The oil temp is not the concern as you are correct it cant cool quite that fast. The issue would be if the oil was low, sump clogged, pump failing, etc, and the flow stops flowing past the temp sensor.
    *I dont know where the oil temp is picked up on the 430, not had the pleasure. Because I can not find a specific part for it i will have to "assume" it is integrated with the pressure sensor, part 52 below. If anyone knows definitively, please correct me or give me my daily affirmation.
    Oil Pressure Transmitter: [part 52] http://www.ricambiamerica.com/parts_catalogs.php?M=FE&P=&V=diag&I=114200
    Interesting I can find 2x water temp sensors, but not the Oil Temp Sensor :
    TEMPERATURE SENSOR [ part 30 ] http://www.ricambiamerica.com/parts_catalogs.php?M=FE&P=&V=diag&I=112018
    Water Temp [ part 6] http://www.ricambiamerica.com/parts_catalogs.php?M=FE&P=&V=diag&I=112020
    **Thanks Ricambi!
  3. ralphuk
    ralphuk Rookie
    Nov 14, 2011
    25
    Cambridge
    Ralph
    I have spoken to the dealership who says it must be a lose electricial conection, simply as it can not loss heat that quickly, there must be a lose conection. I was just hopeing someone else had had this issue. Thanks for the advice though. I did have a lot of issues with the e-diff and can not help to think it has not been put together right when they rebuilt it
    Opinons please ?
  4. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    Check the connection, sure. Click Ricambi link, look at pictorial, find item, check connection.
    I have some pics of my hand on it if you need photographs? You can reach it with a little arm twisting without disassembly. It has a tactile snap lock, if its loose it might be obvious.
    *still assuming part #52 is both pressure and temp.
  5. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
  6. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,548
    Charleston, SC
    Curt
    Agree w Trent. I would put my money on the lower of the two temp sensors above. I predict they use this one to sense the oil temperature and the upper sensor on the water pump for coolant. IIRC the oil flow in the engine on the bottom part of the air/oil separator is being measured by the lower sensor.
  7. radix
    radix Karting
    Dec 2, 2010
    234
    I think you are correct - the 360 oil temp sensor is in the same place near the starter/diff as that lower one. The oil pressure sensor is also in the same place on the 360 up by the filter, so these part locations may be carryover.
    It does seem strange that both the temp and pressure are going crazy if their really are two sensors though... any other of your gages going flaky at the same time - batt, water temp, ??
  8. ralphuk
    ralphuk Rookie
    Nov 14, 2011
    25
    Cambridge
    Ralph
    Oddly has fixed itsself, but car still going in next week to check
  9. hakankuy
    hakankuy Karting
    Jun 15, 2010
    127
    Earth
    Did you manage to fix it?
    What did cause this erratic gauge readings?
    Thx
