Oil pan wave washers | FerrariChat
Discussion in '308/328' started by Irishman, Apr 25, 2015.
  1. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    Anyone have a source for the oil pan cover wave washers? I'm fairly certain sometime in the past I have just used the part number in the catalog and received a washer that fit, but was not a wave washer.
  2. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    McMaster-Carr?
  3. dm_n_stuff
    Dec 10, 2003
    43,716
    26.806311,-81.755805
    Dave M.
  4. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    ACE hardware where I got mine! Cheep and readily available.
  5. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    Great idea. Will definitely look there.
  6. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    I just dropped my pan and the washers were neither wave nor Bellville - just plain flat steel washers about 1mm thick. They look fine, so I'm going to reuse them, but I am replacing the nuts with stainless steel nylocks from Mr Metric (Mountz Torque Tools | The Torque Tool Specialists) Part # M50353.
    The camshaft cap studs/nuts are also M6x1 and call for 6.5 foot-pounds, but do use Bellville washers. So for the pan I'm going with a new gasket, a very thin coat of Hylomar, flat washers and the nylocks at 6 foot pounds.
    If you are going to drop the pan don't forget to remove the oil temp sensor and the dipstick guide tube. Tough to do with the engine in the car, but otherwise you'll never get the oil pan out. And if you don't replace that 30+ year old gasket you'll never cure any leaks.
  7. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
  8. Rifledriver
    37,090
    It really doesn't matter. Ferrari used both wave and Belleville washers and I have seen flat used many times.
    None had anything to do with leaks or lack thereof.
    Use whatever pleases you.
  9. The Kook Abides
    The Kook Abides F1 Rookie
    Jan 4, 2011
    3,459
    Stat-o-seal washers worked better for me. McMaster Carr has them.
  10. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I used the same along with SS Nylok nuts. Same on the cam covers. Worked great.
