oil pressue gauge | FerrariChat
oil pressue gauge
Discussion in '308/328' started by ragtop1, May 30, 2010.
  1. ragtop1
    ragtop1 F1 Veteran
    5,225
    Ontario
    Larry Warren
    #1 ragtop1, May 30, 2010
    My oil pressure gauge is not working. ('79 GTS)
    - brand new gauge
    - brand new oil pressure sender
    - power to gauge ok, as red red comes on pre-ignition and briefly stays on after start up.
    Thanks in advance for any trouble shooting tips
  2. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Ground the wire at the oil filter housing that goes to/come from the wiring harness for the oil pressure transmitter. If the gauge reads "nothing", then you have a wiring problem with that lead. If the gauge reads full scale, then lilkely you have a real oil pressure problem. This can be easily verified with a mechanical oil presure gauge.
    David
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,783
    Cerritos, CA.
    +1 or you can have bad sender.
  4. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Know that the oil pressure warning light circuit and oil pressure gauge are two entirely separate circuits.
    Warning light wires from engine to dash are grey with yellow stripes. Gauge wires from engine to dash are light blue. However there are connectors at each end where colors change again. Warning light sensor on engine is further toward the filter than the gauge sensor.
    GL
  5. ragtop1
    ragtop1 F1 Veteran
    5,225
    Ontario
    Larry Warren
    #5 ragtop1, May 30, 2010
    I disconnected harness wire (red) from oil pressure sending unit and grounded it. Generator light came on & then the fuse blew for all the gauges.
    Then I disconnected the yellow lead from the oil pressure transmitter, grounded it & the red lite on the gauge came on, but the needle didn't move
  6. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    As I mentioned above, that isn't the oil pressure sender but the oil warning sensor. Those two circuits are quite separate and unrelated.
    Please check the wiring diagrams.
    __________________________
    http://www.FerrariDiagrams.com
  7. ragtop1
    ragtop1 F1 Veteran
    5,225
    Ontario
    Larry Warren
    thanks Paul, I better do my homework.
    Larry
  8. Steve Magnusson
    26,620
    #8 Steve Magnusson, May 30, 2010
    Sounds to me like you've got the wrong wire connected to the oil pressure sending unit -- this wire should be HN (grey/black) in color. The R (red) wire might be the +12V line that is supposed to run the electrovalve that removes vacuum from the air intake box flap actuator to open it when the key is "on" (so grounding this red wire with the key "on" would naturally blow fuse #2). Is your air intake box flap system still intact, or might this red wire be available to be misused ;)?
    You're probably OK here, but this wire, for the oil pressure warning light, should really be HG (grey/yellow) in color as Paul mentioned -- not the greatest contrast so maybe not so noticeable.
    Actually, the oil pressure warning light system and the oil pressure gauge system use the same +12V power source for operation, but since you report that the warning light works, that confirms that this +12V is present for the pressure gauge operation (i.e., if both systems were dead, then this +12V power source would be suspect, but that's not your problem).
  9. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Sounds like you grounded a hot (+12V) wire there and blew the fuse at the box.
    I'm no electrician but I'm guessing that if you've put in a new gauge, a new sender and you have power at the gauge with the ignition on then you have a grounding problem for the gauge. I don't know the color coding but often there's a common ground wire for several of the gauges but that may not be the case here (separate/dedicated ground).
  10. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    #10 Paul_308, May 31, 2010
    I am an electrician and methinks he replaced the warning sensor, not the oil pressure sensor.
    http://www.FerrariWiring.com
  11. ragtop1
    ragtop1 F1 Veteran
    5,225
    Ontario
    Larry Warren
    #11 ragtop1, May 31, 2010
  12. ragtop1
    ragtop1 F1 Veteran
    5,225
    Ontario
    Larry Warren
    #12 ragtop1, May 31, 2010
    Thanks Steve
    The wire was not connected to the grey /black. corrected , the gauge now works
    cheers
  13. ragtop1
    ragtop1 F1 Veteran
    5,225
    Ontario
    Larry Warren
    Thanks for all the responses guys. After the engine out service was performed, seems we were colour blind on the connections. red looks like grey/black. LOL :D
    I guess I have a spare oil pressure gauge & sending unit. Anyone interested ?
  14. Steve Magnusson
    26,620
    Glad to hear that you got it sorted out without any (unnecessary ;)) additional expense.
