Oil pressue low? | FerrariChat
Oil pressue low?
Discussion in '308/328' started by Lektronimo, Oct 9, 2015.
  1. Lektronimo
    Lektronimo Karting
    Dec 31, 2012
    143
    Franklin Square NY
    Stefano
    #1 Lektronimo, Oct 9, 2015
    Here is a pic of the oil pressure gauge, took the pic after a ride, fully warm at idle, is this low?
    I checked the oil last week and it seemed fine, perfectly clean too
    Thanks!!
  2. Steve Magnusson
    26,834
    I wouldn't panic for that at fully-warm idle if the value seems reasonable at higher RPM (per the spec in your OM). What viscosity oil are you using?
  3. Lektronimo
    Lektronimo Karting
    Dec 31, 2012
    143
    Franklin Square NY
    Stefano
    I'm using 5w 40
  4. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    I run 20W50 and my oil pressure is like that at idle when fully warmed up. Been like that for 10 years.
  5. MarkJ
    MarkJ Formula Junior
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
    Keep in mind that you can't trust your gauge for an accurate reading.
  6. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    That is perfectly normal. When the engine is cold, the pressure will be higher at idle as the oil is thicker and actually not lubricating as it should. As the oil warms and thins the pressure will drop at idle. It should be just under halfway (just under 85) under normal load.
    Somewhere there is a reference for the expected lbs/1000rpms but I do not have time to get it right now. That is the guide you should use when the oil is at operating temp.
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    I think as a general rule, it's 10lbs for every 1000 rpm.
  8. ntb308gtsi
    ntb308gtsi Karting
    Nov 17, 2013
    82
    South Africa
    Nick B.
    For years had a similar problem , the replacement of the oil pressure sender unit cured the problem. Also using 5W 40 currently.:)
  9. 87 GTS
    87 GTS Karting
    Dec 24, 2013
    216
    Sevo in Australia
    Glenn Hamnett
    same as mine at hot idle
  10. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    That's what I've heard as well.
  11. Glassman
    Glassman F1 World Champ
    If you read the owners manual all will be exposed.
  12. Lektronimo
    Lektronimo Karting
    Dec 31, 2012
    143
    Franklin Square NY
    Stefano
    Thanks guys, just making sure, have the car a little over two years now and loving it!
    If anyone is in NY come over for an espresso!
    lol, thanks again
  13. Rifledriver
    37,108
    If in fact your gauge is reading correctly that is still around 30lbs. That is more than enough at idle.
    Also I have tested many with mechanical gauges and I remember very few that read as high as they actually were.
