Oil pressure gauge f355 | FerrariChat
Discussion in '348/355' started by FerrariLund, May 17, 2018.
  1. FerrariLund
    FerrariLund Rookie
    May 16, 2018
    8
    Henrik Lund
    Hello, I have some issues what my oil gauge shows in my f355. When ignition on the red light is correctly on, but when start the gauge goes up as long it can, over 10 psi. Temperature is fine and the car have had this issue two years. Anybody have an idea to solve? New gauge or new sender or maybee rep?
  2. FerrariLund
    FerrariLund Rookie
    May 16, 2018
    8
    Henrik Lund
    Forgot to say. When engine is warm the pressure fall a little, about 8-9 psi when idle and goes back to full(over 10) when it takes rpm?
  3. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,732
    OK, something is wrong::
    Oil PSI should be in the 50-80 PSI range I've seen cold PSI in the 95 range
    OR
    Oil pressure should be in the 3.5-6.0 BAR I would have been able to see cold in the 8 bar range.
    So, is the gauge PSI or BAR?
  4. FerrariLund
    FerrariLund Rookie
    May 16, 2018
    8
    Henrik Lund
    Sorry, it's bar ofcourse.
  5. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    Put a mechanical gauge in to check. The terminals get corrosion also which can give a false reading
