Oil pressure question | FerrariChat
Discussion in '206/246' started by nis1973, Aug 26, 2016.
  1. nis1973
    nis1973 Formula Junior
    Jan 19, 2013
    493
    NYC/CT
    I am a relatively recent stratos owner and noticed that after a 30-40 minute spirited drive (mostly staying in the 5000-6000 rpm range, occasionally going to the readline, occasionally cruising ar lower rpm) oil pressure drifts a bit lower. It still seems fine but definitely a bit lower. Is this normal? I figured the dino forum is the best place to ask. Thanks a lot in advance!
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,639
    Toronto / SoCal
    Rob C.
    Very normal. As the oil heats up the viscosity drops and it is not uncommon at idle for the oil pressure to be very low. As long as you maintain about 10psi per 1000 rpm you are very safe.
  3. nis1973
    Jan 19, 2013
    493
    NYC/CT
    Thanks!
