Oil Pressure Reading Varies With Lights ON / OFF... | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by 71Vette, Jun 18, 2025.
  1. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    Hi!
    On my 400i S2, the oil preassure seems to very slightly, depending on whether the headlamps are on or off...
    The preasure being higher if the headlamps are on!
    Any idea of what could be causing this?
    Cheers
    Esben
  2. Steve Magnusson
    26,779
    Yes, the grounding of the gauge is not perfect (i.e., the wires are not huge, and the connections are not perfect = they have small resistances), and it shares a ground with the dash lights. When you turn "on" the exterior lights, that ground "floats" up to a slight non-zero voltage (due to those small resistances). If the needle motion is about 1 needle width = sort of normal situation. If it's a lot more needle motion than that = might be useful to clean/redo the ground connection to that gauge and/or add another ground wire in parallel to the existing ground wire going to that gauge.
  3. Zanny1
    Zanny1 Formula 3
    1,133
    Arizona
    Exactly. You may also notice that with the ignition on, motor not running, the oil pressure gauge will move to the right. PITA to get behind there. I just learned to live with it on my C/4.
    71Vette likes this.
  4. 71Vette
    71Vette Karting
    Oct 24, 2023
    212
    Stuttgart, Germany
    Esben
    Thanks!
    I'll try running a parallel ground!
    Cheers
    Esben
  5. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,665
    Argent/Brasil
    Guido
  6. raemin
    raemin Formula 3
    Jan 16, 2007
    2,339
    Lyon (FR)
    R. Emin
    There is a ground post on the lower left side of the speedo cluster. Close to the iso accessory plug. When the dashboard is out that's an easy upgrade. (Unfortunately, any serious work on the electric ancilaries requires to drop the dashboard.)
    71Vette likes this.
