Buy
Oil pressure relief valve cap - leaking
Discussion in '308/328' started by Peter, Apr 24, 2011.
  1. Peter
    Peter F1 Veteran
    Rossa Subscribed Owner
    Dec 21, 2000
    6,417
    B.C., Canada
    #1 Peter, Apr 24, 2011
    This is one of the few items I have never touched on this engine, and probably has never been touched by anyone else prior to my ownership and has been dry up until this point. As I'm in the midst of doing my annual oil change, I've been poking around underneath and there was a sizable drop of oil clinging to the bottom of this cap (I wiped it up before I took the photo).
    Can I remove this cap in situ? I know there's a spring and piston behind it, but is that spring exerting a tremendous amount of force (in other words, is it going to poke my eye out when I remove the cap)?
  3. fastradio
    fastradio F1 Rookie
    Professional Ferrari Technician BANNED
    Apr 26, 2006
    3,652
    New England
    David Feinberg
    Sure can, just be aware of the spacer shim which is typically "stuck" inside of the cap. The spring tension is minimal in that you'll have no safety issues removing the cap.
  4. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,417
    B.C., Canada
    Thanks!
  5. pad
    pad Formula 3
    Sep 30, 2004
    1,409
    Tequesta, FL
    Paul Delatush
    I had a B^#$# of a time removing that cap even with an air gun. I ended up soaking it with penetrating oil for a few day before it would move. Hopefully, you'll have an easier time.
    waymar likes this.
  6. spgribben007
    spgribben007 Karting
    Nov 11, 2010
    196
    Frederick, Maryland
    Steve Gribben
    Can you post pics of this cap removal? I have to do my first oil change and would enjoy not to have any surprises.
  8. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,476
    Cape Canaveral/Atlanta
    Walt P
    I think it would be a mistake to remove "this" cap for an oil change.
  9. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    13,212
    Dumpster Fire #31
    SMG
    spring loaded bypass valve, there's a spec for the free length on them. the shim is 2mm thick and the 2v spring is 76mm long free length and the Qv is 74mm, I don't recall the tension force to length off the top of my head though.
    check to make sure it's within spec and moves freely, you can also move the piston internally to see if it holds a seal. you'll get a bit of oil dribbling out when removed so have a rag handy.
    the only adjust-ability would be via shims, and that's not something I'd recommend for the avg DIY as this controls the oil pressure in system and you don't want to blow seals or wipe bearings with the wrong pressure.
    If you're concerned about the pressure it's a good idea to check it with a mechanical gauge.
  10. Robz328
    Robz328 F1 Veteran
    5,856
    ATL, Georgia
    Rob Hemphill
    I wouldn't remove until I verified the leak was coming from the cap. The oil could be from elsewhere.
  11. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,417
    B.C., Canada
    Sure.
    I'm not doing it just for the oil change. Like I said, I've had no reason to remove this before, only now because it's leaking.
    DEFINITELY leaking. Everywhere else was bone-dry
    Thanks for the hints/tips.
  13. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,417
    B.C., Canada
    #10 Peter, May 1, 2011
    Okay, I tackled this on Saturday morning. It couldn't have been any easier. It was seriously tight - couldn't budge it with a 24" breaker bar - so I used my 1/2" electric impact wrench. The hex size was 32mm (although an 1 1/4" socket fit perfectly). It didn't take much using the impact. I allowed it to rattle it a bit and then it free-spun quite quickly. I stopped it about three threads short of it coming off. I spun it off by hand and there was only a slight pressure behind it. As my car has been sitting a while, the oil had drained out so I didn't spill a drop.
    Now the problem. It seems to be that the sealing face (either the cap or the casting) is not perfectly perpendicular to the threads. You can see the wear pattern and the staining on the copper gasket of the uneven contact. My next step is to confirm using blue layout dye to see where the unevenness is. I'm not sure at this point how I'm going to remedy this, but I can say one thing, I ain't hauling out the engine for this! I'd rather just use either teflon tape or Hylomar on the threads as a bandaid, or try to make a facing/lapping tool (like lapping in valves into their seats) at the most... This car has to be done by the end of May (or preferably sooner) as I have a club event I'm organising, so I can't get too involved in this repair.
    The piston moved very easily, although you can see some polishing on the piston. Also on the spring where it sits in the piston. The shims don't appear to be accurately made - certainly not like a valve shim but stamped out like a washer. The free length of the spring is 73.86mm.
  14. magaoidh
    magaoidh Karting
    May 12, 2009
    220
    Check the thread is not crossed and fit a new copper washer,its not rocket science!
  15. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,476
    Walt P
    Steve, My my post was directed to Steve, sorry I wasn't clear on that.
  16. Rod
    Rod Formula Junior
    Jan 18, 2004
    865
    South Derbyshire
    Rod
    Agreed. I recently uprated the spring with the later item as mine my oil pressure reading was starting to drop... The later spring sorted the problem. As for the seal, mine was the same, a new copper washer will do the trick...
  17. 85QVEuro
    85QVEuro Rookie
    Jan 15, 2021
    37
    NYC
    Joe
    I have an 85 308 QV Euro Mondial. My front cover is apart now to change the cam drive pulley bearings and I also removed the plug, piston and spring for the oil pressure. However, I did not find a shim in there and I don't believe this car was taken apart before. TAV 16 of the spare parts catalog shows the shim as item #30 or part # 106238.
    Two questions: 1) is it possible this car came with no shim? 2) why does the poster above (Peter) show two shims in his photos? Thanks for the help
  18. Rifledriver
    Rifledriver Two Time F1 World Champ
    28,182
    Austin TX
    I have no idea why he has 2. It is supposed to have one. You should too. In 1986 Ferrari made a change to increase oil pressure in the 3.2 motor and it was too high. Cars were blowing oil hoses off and blowing up oil coolers. They did a recall and in addition to installing better hoses were were told to remove the shim. All 3 liter engines should have a shim and all 3.2 engines should not.
    tuttebenne and smg2 like this.
  19. 85QVEuro
    85QVEuro Rookie
    Jan 15, 2021
    37
    NYC
    Joe
    Rifledriver - Really appreciate the quick response. I'll get a shim (will look first in the bolt/cap)
  20. Rifledriver
    28,182
    Austin TX
    Make sure because they stick in the cap due to the oil.
  21. waymar
    waymar Formula 3
    Sep 2, 2008
    1,197
    Northeast, PA - USA
    Wayne
    I have yet to succeed in removing the cap. Afraid it will break something off. Guess I will have to soak it......
  22. Rifledriver
    28,182
    Austin TX
    I use a 1/2 inch air gun to remove. I really doubt soaking will do anything. Rust isn't holding it on.
    waymar likes this.
  23. 85QVEuro
    85QVEuro Rookie
    Jan 15, 2021
    37
    NYC
    Joe
    Thanks Rifledriver - you are spot on here - the oil stuck the shim to the cap
  24. Rifledriver
    28,182
    Austin TX
    Good. Glad someone said something that reminded me of that.
    tuttebenne likes this.
