Oil Pressure Sender Dimension | FerrariChat
Discussion in '206/246' started by celestialcoop, Oct 19, 2007.
  1. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    Greetings to all.
    I've searched & read some very good stuff here on the infamous Veglia oil pressure sender. However, I was unable to find the answer to my question.
    So..., anyone out there with a new or used sender avail to measure the OD of the threaded shaft that screws into the adaptor on the block? And..., same question for the OD of the adaptor, if you also have one handy. (My car is not on campus; I can't check it out for myself.)
    For those of you who have all of the specs stored in memory, a measurement won't be necessary. I'll gladly receive your input, too!
    'appreciate the help.
    Cheers,
    Coop
  2. rwk360
    rwk360 Formula Junior
    Aug 26, 2005
    394
    Pebble Beach, CA
    R W Kenton
    Excuse my naivte' on this, but why is the sender any more infamous than any other Dino part? Have been on F-chat/246 for over 2 yrs and this is the first allusion I've heard on this subject. Am I missing something? BTW, my oil press gauge never registers more than about 1/3 of total range (1/3 up from zero), even when fully warmed; is this abnormal (car runs cool w/ no known engine probs currently)?
  3. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Coop, my two Dinos both run low indicated oil pressure. One-third gauge reading is about right at operating termperature. The idiot light does not come on when, at idle, the oil pressue reading is close to zero. This suggests to me that the oil pressure is correct, with the analog meter providing incorrect data. I believe that this is standard operating procedure, and may be related to the rumored mismatch in impedance between the gauge and sending unit. Someone has suggested that the factory provided the wrong sending unit for the gauge (perhaps the Daytona unit, which I suspect is no different than the Dino unit).
    Anyway, a shunt resistor from the transducer to ground of approximately 500 ohms (as per John Corbani's post of years past) will make you feel better. It does nothing for the oil pressure, but at least you see proper gauge reading.
    It is sort of like the old coffee machines (that filled a cup) with the extra cream, extra sugar buttons. There were no wires connected to those buttons. You pushed them and felt better because you thought you were getting something extra.
    Jim S.
  4. dm_n_stuff
    Dec 10, 2003
    43,746
    26.806311,-81.755805
    Dave M.
    I replaced mine some time ago with the part that Mike had at superformance. Now you all have me wondering.
    What is the "correct" oil pressure for the Dino, warmed up at idle? How about at 3-5K rpm.
    Just looking for some calibration.
    Dave
  5. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    1/4 scale at 1100 idle, half scale above 2500. Very little upward change with RPM. My oil pressure regulator works just fine. I used a nice round dial gauge to set my reading when I replaced the stock sender with a Nissan unit. I had to add a resistor in series to get mid-scale dead on. 85 psi as well as I could measure, just like the gauge says. Been fine for 10+ years. Only required a brass metric pipe adapter that I got at the local Pep Boys. Don't remember the sizes and didn't save the old sender. Now I save virtually all the dead bodies. Will be useful eventually. Live and learn.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Good luck getting anyone to answer your question.
    You have ignited another debate on what the right oil pressure should be.
  7. billg
    billg Formula Junior
    Jun 7, 2006
    307
    New Orleans
    Bill Grady
    If this contributes anything, I have a lowly 400A with the same readings: near zero at idle, rarely above a third anytime.
  8. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Just rebuilt my engine with new oil pump gears as the originals were pretty worn out.
    Runs the best i have ever known it, but the oil pressure gauge still shows exactly the same as it did before regardless of the new pump, synthetic or mineral oil used (running mineral at the moment for the first 1000miles)
    At 50mph the gauge is just below the 85psi, at idle it is about 1/3 up.
    If you haven't got a problem why invent one!!!!
  9. dm_n_stuff
    Dec 10, 2003
    43,746
    Dave M.
    I can echo what Tony says.
    Did a little road research this AM. At idle, warmed up mine is about 1/2 way between 85 and 0.
    At 4-6K rpm, under load, warmed up, a touch over 85.
  10. marcjh
    marcjh Karting
    Aug 14, 2004
    91
    A Land Far, Far Away
    Marc Hollander
    I had my motor rebuilt about 1100 mi. ago. I paid attention today and at idle oil pressure is about 2/3 of the way to 85. Around 3-4.5k rpm it is around 85. At higher rpm my gauge reads almost half way between the 85 and 140. High?? Not sure, but no oil drips, smoke, nothing. Runs like a top. I guess I'd rather have too much rather than too little oip pressure. Marc
  11. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Post #11
    Nobody has apparently read your question.
    I don't have one to measure and I don't think you really want a guess.
  12. Timo04
    Timo04 Karting
    Jul 2, 2007
    198
    S.F. Bay Area
    Tim
    #12 Timo04, Jul 15, 2009
    Greetings,
    A friend of mine, who is not an F-chat member, is searching for the correct oil pressure sending unit for his 246 Dino. He told me, and "swears" that, the sending unit on his Dino's block has 12mm x 125 size threads. After calling several Ferrari parts houses they all told him that the thread size is 14mm and even a size larger, a size that I can't remember at the moment.
    At any rate does anyone on the board know where the CORRECT sending unit for a Dino can be sourced? Is the Dino oil pressure sending unit really the same one as used on a Daytona? Lastly is the correct thread size really 12mm x 125? I am simply posting this as a favor for a friend and know nothing about this subject. Any help and advice will be greatly appreciated.
    Thanks in advance,
    Tim
  13. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    There is only one who has a lucid, deeply researched & well thought out explanation to this- JSelevan. Pay attention!!
  14. Timo04
    Timo04 Karting
    Jul 2, 2007
    198
    S.F. Bay Area
    Tim
    Thank you. I believe that I made an error in my previous post. The Dino may actually be a 206 since it is, from what I have been told a '67 model year. Did the 206 (2L engine) use a different oil pressure sending unit as compared to the 246? This may explain 12mm x 125 threads?
  15. daviekj
    daviekj Formula Junior
    486
    #15 daviekj, Jul 16, 2009
    Tim,
    attached photo shows the one I took off my car a few years ago. I am fairly confident that this is original (comprehensive history of all work done by previous original owner). I still have the sender and just checked the threads. They are as shown.
    there was nothing wrong with this sender, other than the plating being a bit warn, and the oil pressure reading looking low on the dial even though engine was in top condition (about 1/3 from zero at normal driving speed). I understand from many, this was a common issue.
    I replaced mine with the sender from superformance. The pressure needle was more 50% across the dial (i.e vertical) for the same driving speeds. I am happy.
    I just looked at this sender in the engine. Looks to me like the superformance sender is one part, i.e. without the thread adapter, M16x1.5 straight into the head.
    Kevin
  16. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    The sender to the block adapter is 12mm (assuming re-using the adapter) and can be bought for under $38 (p/n OP682)
    http://www.centerlinealfa.com/products/images/pages/electrical.pdf
    I thought we had this in the 206/246 spare parts sticky thread, but can't seem to find it so will add it.
  17. Timo04
    Timo04 Karting
    Jul 2, 2007
    198
    S.F. Bay Area
    Tim
    Gentlemen,
    Thank you so much for this information, I will pass this on to my friend for sure! The photo is very helpful as well. As they say "a picture is worth a 1000 words".
    All the best,
    Tim
