430 - Oil Pressure Sender - Preventative Maintenance | FerrariChat
430 Oil Pressure Sender - Preventative Maintenance
Discussion in '360/430' started by JM280z, Jun 28, 2024.
  1. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    878
    Jake
    Hey All,
    I have 2 F430s and each had oil pressure flash to zero momentarily then back on. A year ago I replaced a sender on an 07’ with 12k miles and just now on an 05’ with 22k miles for the same reason.
    I think it’s beneficial to replace a cheap part (~$200) in 15 minutes with a mere 24mm wrench because if you see low oil pressure it could be a more serious issue so might as well eliminate a common problem that gives false readings.
    Here is the oil pressure sender (with the connector taken off), view is from the rear passenger quarter panel looking forward and underneath the MAFs and Throttle Body area:
    Here is the connector, which required you to gently pull out on the tab while pulling it up/off: Image Unavailable, Please Login
    I used an open end 24mm wrench; it was a bit tight to get a wrench in there but not bad. Be cognizant of the other sensors/wire aft of it, don’t hit it with the wrench. I tightened it until the copper crush washer compressed. I then marked it with a yellow paint marker for easy inspection if it were to come loose.
    Very easy cheap fast job. Might as well do it as preventative, considering I’ve had a false low pressure alarm on 2 F430s now…
    I order almost all my parts from Scuderia Car Parts. Shipping is cheap, and despite being in England I get parts in around 3 days from ordering (wow… global logistics are getting great). I talk to Chris at Scuderia Car Parts when doing bigger jobs to make sure I don’t miss little things like clamps and washers; [email protected]
    Qavion, Kerwind and AandSC like this.
  2. GogglesPisano
    GogglesPisano F1 Rookie
    3,207
    East Bay, California
    Joe
    why do you have two F430s? coupe/spider so you get the best of both worlds?
  3. JM280z
    Aug 22, 2020
    878
    Jake
    Because I’m fiscally irresponsible and immature & a friend sold his that I knew was in great shape and he needed the money quickly.
    GogglesPisano and mwstewart like this.
  4. Qavion
    Qavion F1 World Champ
    14,284
    Ian Riddell
    It's good to know that the sender is accessible without removing the intake runners.
    Fortunately it's at the back of the engine, not the front.
  5. JM280z
    Aug 22, 2020
    878
    Jake
    Sj_engr and CoreyNJ like this.
  6. JM280z
    Aug 22, 2020
    878
    Jake
  7. DrPaul
    DrPaul Karting
    Dec 27, 2018
    67
    Grand Rapids, MI
    Paul M. Strickler
    I also own two F430s. :)
    JM280z, jerbear27 and GogglesPisano like this.
  8. GogglesPisano
    3,207
    Joe
    Man, I’m behind here. I’ll have to start shopping for a second one :D
    JM280z, jerbear27 and AandSC like this.
