Oil pressure sender unit | FerrariChat
Discussion in 'Technical Q&A' started by Riddler55, Aug 31, 2023.
  1. Riddler55
    Riddler55 Rookie
    Feb 14, 2023
    16
    Robert Ridley
  2. wmuno
    wmuno Formula Junior
    522
    Wilmette, Illinois
    Bill Muno
    Have you tried the parts department at a Maserati dealership? That would be the first place I would try.
  3. Riddler55
    Riddler55 Rookie
    Feb 14, 2023
    16
    Robert Ridley
    Well I could but I generally find dealerships have neither knowledge or any interest in classic models!
  4. raemin
    raemin Formula 3
    Jan 16, 2007
    2,306
    Lyon (FR)
    R. Emin
    Our cars are usually M18 not M12 (this being said on the 308 forum some do report odd sizes). Why don't you just buy a VDO sending unit with the same ohm range and use an adapter so as to match your M12 thread?
    https://www.ferrarichat.com/forum/threads/348-parts-thread.50339/page-17#post-141327290
    If you cannot find a sender with the proper ohm range, you can use a "gauge wizard", that will allow you to perform a 5 point calibration and match any sender to your gauge.
    moysiuan likes this.
  5. Riddler55
    Riddler55 Rookie
    Feb 14, 2023
    16
    Robert Ridley
    Thanks! I’ll maybe contact them and look into that as a possible solution if I can’t find a sender that is right.
  6. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,865
    The Cold North
    Tom
    Possible Mercedes unit could do the trick. Looks very similar. GM also used a unit like that I think in Buicks of the 70's..
  7. raemin
    raemin Formula 3
    Jan 16, 2007
    2,306
    Lyon (FR)
    R. Emin
    There was also a discussion on how to use modern units.
    From personnal experience, these units are reliable, but they do not like long restoration projects. My car sat for 9years, it took a couple of hundred of km for the sticky resistor wiper arm to move freely again.
    Unlike the fuel sender, the winding does not crumble.
  8. Riddler55
    Riddler55 Rookie
    Feb 14, 2023
    16
    Robert Ridley
    OK. - you seem knowledgeable on these. If you were able to point me towards such a sender that would be brilliant. Particularly as I am in the UK not the States as I am guessing you are?
  9. raemin
    raemin Formula 3
    Jan 16, 2007
    2,306
    Lyon (FR)
    R. Emin
    Superformance.co.uk does have them with the 18mm thread, Ricambi may have the older types with the odd thread size.
    Replacements are now made by VDO, you may get in touch with them?
  10. dennis_maine
    dennis_maine Karting
    Sep 11, 2007
    196
    ME
    Dennis Haines
  11. Riddler55
    Riddler55 Rookie
    Feb 14, 2023
    16
    Robert Ridley
    Thanks for your help. Who are VDO?
  12. raemin
    raemin Formula 3
    Jan 16, 2007
    2,306
    Lyon (FR)
    R. Emin
    VDO is one of the oldest manufacturer of gauges & senders. Most of the vintage veglia senders do have a VDO substitute, so that's what our suppliers are now selling us.
    Just like Michelin Classic, if you send an email about a particular need, they usually reply. Not all manufacturers are so helpfull...
  13. Riddler55
    Riddler55 Rookie
    Feb 14, 2023
    16
    Robert Ridley
    Thank you. I have just emailed them now with pictures of my existing unit. Rob
  14. dkbluec4
    dkbluec4 Karting
    May 29, 2006
    52
    Northampton UK
    Neil Lefley
    You might try MIE Corp or McGraths in the UK.
    Neil.
  15. Riddler55
    Riddler55 Rookie
    Feb 14, 2023
    16
    Robert Ridley
    Thanks. They were the first two I tried without success.
  16. Dockboy
    Dockboy Formula Junior
    561
    Maryland
    https://www.ferrarichat.com/forum/threads/modern-oil-pressure-sensor-kit-for-3x8-mondial-etc.567312/
    I put one in my '77 GTB. Awesome to have the gauge actually read the correct pressure!
  17. Riddler55
    Riddler55 Rookie
    Feb 14, 2023
    16
    Robert Ridley
    Thanks for your reply but I don’t think that will work in the Maserati.
  18. Dockboy
    561
    Maryland
    #18 Dockboy, Sep 6, 2023
    Why not? What is the pressure range of the Maserati gauge? If it is 0-170 psi, or close to that, it will work.
  19. Riddler55
    Riddler55 Rookie
    Feb 14, 2023
    16
    Robert Ridley
    It is not the pressure rating it is the fit. Mine has a thread of M12x1.25. And it fits so close to the body there is very little room for an adapter.
  20. Dockboy
    561
    Maryland
    Gotcha. You would need a M12x1.25 male to 1/8" NPT female adapter for the sending unit.
  21. raemin
    raemin Formula 3
    Jan 16, 2007
    2,306
    Lyon (FR)
    R. Emin
    I'd rather use a VDO 360-081-029-013K as it has the proper thread size.
    Then if need be a gauge wizzard module so as to match the ohm range expected by the instrument panel.
    As an alternative to the wizzard, one could also calibrate the sensor at 6bar using a resistor. Kind of oldschool but should be good enough.
