Oil pressure warning light switch missing | FerrariChat
Discussion in '206/246' started by simonc, Oct 30, 2013.
  1. simonc
    simonc Formula Junior
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    #1 simonc, Oct 30, 2013
    I have a 73 246GT 'E-series' and the oil pressure warning light switch is missing - a bolt has been inserted into the hole in place of it. I can buy another switch easily enough but I cannot see any loose wire that will connect to the switch.
    Does anyone have a photo of this switch and it's associated wire and where the wire comes from? The switch is shown as 65 in the TAV below.
    Before anyone makes the obvious comment - I have checked the oil pressure with a mechanical gauge and it is fine.
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    Don't have a photo at the mo but the wiring comes from the loom running near the dizzy. My sender unit was not connected when I bought the car and found the single wire strapped to the loom. If you remove the rear wheel arch you can see the loom very clearly from there.
    Sender units are available from superformance uk
  3. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    #3 dignini, Oct 30, 2013
  4. Yves Delhaye
    Yves Delhaye Rookie
    Apr 3, 2008
    25
    France
    Hi,
    Sorry but what is the purpose of the Oil pressure warning light switch?
    Thanks.
    Del.
  5. Yves Delhaye
    Yves Delhaye Rookie
    Apr 3, 2008
    25
    France
    Forget about my stupid question above. I should have think twice before posting it.
  6. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    Thanks. Found the wire, now off to buy a switch from Superformance.
