Oil pump chain tensioner, where can I get one of these? | FerrariChat
Discussion in '348/355' started by Headrips, Jun 30, 2010.
  1. Headrips
    Headrips Rookie
    May 24, 2010
    49
    Orlando
    Scott
    #1 Headrips, Jun 30, 2010
    Hi guys, I have a 1990 348 ts in the middle of a major svc and having difficulty finding this oil pump chain tensioner bearing in the U.S......any ideas?
  2. markgllc
    markgllc Karting
    Dec 25, 2008
    179
    Fairborn, OH
    This is the tensioner shown...not sure what bearing you might be refering to but I think our good sponsor Ricambi has/can get the tensioner. Unsure of what Dan has in stock...
    http://www.ricambiamerica.com/product_info.php?products_id=205496
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #3 2NA, Jun 30, 2010
    The OP has shown a picture of the timing chain tensioner #147338 (yes the 348 has a timing chain AND a belt). Currently unavailable from the usual sources. Unless yours is worn down to nothing you'll probably need to reuse it.
  4. Ricambi America
    Sponsor Owner
  5. markgllc
    markgllc Karting
    Dec 25, 2008
    179
    Fairborn, OH
  6. Headrips
    Headrips Rookie
    May 24, 2010
    49
    Orlando
    Scott
    #6 Headrips, Jun 30, 2010
    Thanks guys, I didn't mean to write 'bearing'....it's number 5 on the diagram....the tensioner is pretty bad, can't reuse it unfortunately...any ideas?
    Was hoping to have my car ready for the holiday weekend but it's not looking good!
    Scott
  7. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    These seem to be unobtanium at the moment - send Dave Helms (davehelms) a PM as he is working on a solution.
  8. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    If the surface is worn, Weld it back up and grind it back to shape.
  9. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Just to clarify, are you in need of the oil pump chain tensioner (as you said), or the timing chain tensioner (as in your picture)?
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The worn surface is a hard rubber/plastic material, welding isn't an option.
    I've thought about machining a replacement wear surface for them. The real question is choice of material. It would be good to know what the OEM part was faced with.
  11. Headrips
    Headrips Rookie
    May 24, 2010
    49
    Orlando
    Scott
    I guess it's the timing chain tensioner, just got the car (my first Fcar) and I'm still trying to learn what's what....what I do know is the part I need is in that photo and the part number is #147338....until an hour ago I didn't realize this engine had a belt and a chain!
    ....the bearings that surround the shaft and sprocket that drive the oil pump were loose and if it weren't for that my tech would have never seen this worn out guide.....problem is the dead end finding a replacement......
    Any help would be greatly appreciated!
    Scott
  12. Headrips
    Headrips Rookie
    May 24, 2010
    49
    Orlando
    Scott
    Thanks will do!
  13. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Dave found out what it is and that's the solution he is working on - IIRC he said the stuff was around $1,200 sq/ft for the raw material, a proprietary blend of nylon/plastic :eek:
  14. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    #14 davehelms, Jul 1, 2010
    Started at $977.53 but ended up at $1500 by the time I had it in my hands. I now have enough to make more tensioners and Vintage 12 cyl. chain guide pads then there are cars on the road. Incredible how much the plastic technology has progressed in time... it is not easy to work with and requires just the right speed to cut but once that was identified the finish cut is beautiful. This material was designed to be injection molded but being up to my neck in the molds for the fuel pump rubber parts.... not going there again anytime soon. I was able to locate the same material in billet form from one supplier in Europe and am working from that as I suspect there will not be a high enough demand for these parts to justify making molds.... hence why the part was dropped from production about 4 years ago by my research.
    The first new tensioner pad should be done by this evening, I will post a photo. The process of setting up to machine the arc of the wear surface required I make a few fixtures for the mill turn table but those are now done. Once the prototype is done and tested (I made a chain jig driven by an electric motor running an old 250 chain where I will run it highly over loaded over the long weekend with no lubrication). If it passes this test my machinist will cut them up on his CNC using my jigs and we will be done with this....
    My race engine's for the 348 IMSA and a good friend's 348 have been both waiting on this project for many months now. Based on how this material cuts on the mill I suspect it will be the last one we will ever need to make, it is quite impressive.
  15. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    A high durometer synthetic rubber, I had a materials lab reverse engineer that in my search for the best material for this application. It wasnt up to the heat or RPM of these engines, nor was the first generation of the plastic's used as a replacement for the oil pump chain tensioner... I have a few failed samples of those in hand as well.
  16. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    It is hard to tell which bearings you are speaking of but make sure the roller bearing on the back of the driven shaft is replaced with the updated ball bearing. This is the source of many bent 348 valves over the last few years.
    We have also finally perfected to our satisfaction a welding and replating process for the belt drive gear fences, another area of concern you will want to look closely at. Ferrari didnt see fit to do this until well into the 360 engine production. I will post photo's of this when I get to the shop.
  17. Jamie H
    Jamie H Formula 3
    Aug 28, 2009
    2,425
    Puslinch,ON
    Jamie
    Dave,
    As always my hat it off to you !!
  18. Ricambi America
    Sponsor Owner
    Been there, bent that. Mrs. JRR is still buying shoes to extract revenge for the damage to our savings account (and marital harmony!) when my engine blew up.
  19. Jamie H
    Jamie H Formula 3
    Aug 28, 2009
    2,425
    Puslinch,ON
    Jamie
    I feel your pain my brother. I am now into a new mortgage for a similar type of incident-my wife isn't a shoe shopper.
  20. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    #20 davehelms, Jul 1, 2010
  21. chas-3
    chas-3 Formula 3
    1,281
    Colorado
    Chuck
    #21 chas-3, Jul 1, 2010
    Welcome to my world. I've been sitting back the last few months wondering when someone else was going to hit this problem. I've been hinting at the fact that part is unobtanium in other threads and not getting much reaction. For instance, http://www.ferrarichat.com/forum/showpost.php?p=139699986&postcount=3 Looks like your post has opened some eyes. At least your wait is going to be shorter than mine. ;-)
    Rest assured once Dave has this part tested out it will be bullet proof.
  22. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Honestly Dave, what are you paying these guys? ;)
  23. Ricambi America
    Sponsor Owner
    Invent something "bullet proof", and rest assured somebody in the Ferrari world will employ a howitzer.
  24. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    LOL!
  25. TheItalianJob
    TheItalianJob Karting
    Dec 20, 2006
    91
    Hamilton, Ontario
    Daniel
    i will need one also.
